Question about WYSE Winterm 9455XL Network Terminal
How do you unlock a wyse 9455xl - WYSE Winterm 9455XL Network Terminal
How to reset to factory default on a WYSE thin client 1125se
The simplest and most often used method is using Wyse Simple Imager in a PXE setting. This is how most large enterprises deploy images to Wyse terminals.
If this is not an option, there are some other options available. Please refer to this website for some home-brew solutions:
http://www.freewysemonkeys.com/modules.php?name=News&file=article&sid=55
Oct 03, 2012 | WYSE Winterm 1125SE Network Terminal
How to unlock usb port at wyse s10
WYSE WTOS OS is the most secure OS and one can not play around with unlocking USB ports
Dec 03, 2009 | WYSE S10 (90210501) Network Terminal
Start Wyse S90 takes a long time
Try updating the OS from the Wyse website (using WSI, the new USB imaging tool, or WDM). It might simply be that the current image is corrupt. 10 minutes is excessive. It should boot in under 2 minutes easily.
Apr 15, 2009 | WYSE S90 THIN CLIENT KB/MSE XPE...
Ho do the wyse winterm s50 worck? and ho do i, or can i use the?
There is documentation available for free from the wyse website on the knowledgebase. This will detail the full usage of the S50.
It can be used as a local web terminal, or linked to an external server, via RDP (terminal services) or ICA (citrix).
The admin guide (from wyse.com) will help you figure this out :)
Mar 24, 2009 | WYSE Winterm S50 Network Terminal
The wyse 50 terminal does not work properly
Wyse 50/60/150/160 monitors were my specialty!
From what you were explaining it seems to me that you have a bad internal battery and it needs to be changed and a factory reset/ calibration needs to be performed.
I can repair wyse terminals at my facility if you like. The repair cost is not that high and we can also perform the regular repair and adjustments on all wyse monitors if needed.
Please contact me if you have any questions.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Mar 18, 2009 | WYSE 50 Terminal
How can i reset the bios password of my wyse vx0 machine?
wyse model no vx0 bios pssward remove videos
Jan 09, 2009 | Computers & Internet
Wyse S10 and Windows 2008 Terminal Services
The Wyse S10s require a firmware update to connect to Windows Server 2008. This is due to lack of support for RDP 6.1.
The update I've found to work best is 6.4.0.18.
The only way to get this update is to contact Wyse. However, I have deployed it on numerous clients (our entire base is S10s) and had great success.
Nov 12, 2008 | WYSE S10 (90210501) Network Terminal
Reimage Wyse S90 with XPE
U probably already know but...U need to use the Wyse Device Manager info found here http://uk.wyse.com/products/software/rapport/
Feb 10, 2008 | WYSE S90 THIN CLIENT KB/MSE XPE...
Jumper settings to bypass password
Default passsword is Fireport (note: case sensitive)
To get set password to default unplug power, open case and find jumper next to battery (mounted vertically) on motherboard.
Put jumper to other position. Plug in power, wait ten or so seconds. Unplug power, put jumper back, and voila.
Jan 13, 2008 | WYSE Winterm 9455XL Network Terminal
WYSE Winterm 9455XL Network Terminal Logo
59 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
