Question about Microwave Ovens
I bought a chefmate electric can opener -- it is brand new--i took it out of the kitchen cabinet to use today (i bought it two weeks ago -- i do not have a receipt or box) can use please reimburse me $9.99 plus tax model no CN-8 120 vac 60 Hz 1.5A thank u donnamarie corbett 1-718-792-9123
3 Suggested Answers
SOURCE: Le moteur de mon aspirateur
Bonjour M. Grenier, le probleme ce situe dans la carte électronique de votre aspirateur central Duo Vac. C'est probablement le relais qui est défectueux. Il peut rester en position ''on'' ou autant en position ''off'' lorsqu il devient capricieux. Contactez nous au www.aspirateursenligne.com pour des renseignements et les pièces
Bonne chance
Posted on Feb 04, 2011
tbreeze47
  • 3083 Answers
SOURCE: I have a Kitchen Aid
Hi Joe,
Since 6 gage wire is heavier duty (thicker) than 8 gage, it will be more than sufficient to supply the oven. I'm not an electrician, per se, but have obtained permits to add wiring to additions years ago, so I know some things. The important issue is to check to make sure it meets or exceeds code, for insurance purposes, and you can verify that your wiring meets code by calling the permit people in your area, just to be safe. Any electrical contractor in your area should be able to verify this.
I think you'll be fine.
Posted on Sep 09, 2010
Started tripping circuit breaker. It's on a 15 amp circuit, we bought it two years ago and it only started doing this last week. It first did this 7 minutes into cooking a frozen meal. Then four minutes, 3...
The problem could be a failing magnetron or control board. The tingle may be traceable to a faulty receptacle installation - one with a floating ground or incorrect wiring such as reversal of the hot and neutral lines. The vibrating sound seems to be one of the quirks of GE microwaves.
Apr 28, 2017 | GE JES1358 Microwave Oven
If I had a GE model# JVM1650WH02 and want to switch to Model# JVM1750DPWW. Do the hole match on top when I am mounting to the cabinet above the oven?
I had a GE JVM1651WB 005 from 2001 that died a few days ago. I replaced it with GE JVM1750DPWW today. The 3 old holes from the cabinet to the microwave fit perfectly, so did the old mounting bracket. I only had to make a hole for the plug and chord in the cabinet because the location changed by a few inches diagonally compared to the old one.
Dec 20, 2010 | Microwave Ovens
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
2 months old. bought brand new. and just stopped
These things will happen. You are aware that these appliances have a 12 month warranty so return it to where you purchased it from.
Feb 17, 2010 | Microwave Ovens
Died completely, no power, no panel, disgusted, 2003, brand new, mad and unscrewing model
Find the main fuse on the floor of the device near where the poser cord comes in to the cabinet. Probably needs a 20 amp ABC rated fuse available where electric parts are sold.
Don't be disgusted, you got 6 years out of it so far. As kitchen appliances go, the microwave is probably the most reliable. Treat it well and it will run for many years. Don't open the door while it is operating to protect the door safety interlock switches.
Thanks for your interst in FixYa.com
please vote
Dec 20, 2009 | GE Profile Spacemaker Over-the-Range...
Clock and timer on Whirlpool GH7155XHS micro/hood are running slow. Clock loses about 10min/hr and kitchen timer countdown is slow.
I've just fixed a very similar problem with a 10-yr-old NEC microwave oven.
Disconnect AC power, take the top cover off, go through the unit and tighten all screws, particularly those connecting ground wires to the chassis and those fixing major components like the power transformer and magnetron to the chassis.
May 28, 2009 | Whirlpool GH7155XHS Microwave Oven
Flashing 88:88 display - no keypad response - no light
See if there is a hard reset for unit to restore it to factory default. Contact the manufacturer for the hidden code to accomplish this. Otherwise, it is ng.
Sep 02, 2017 | Sharp R-1500 Microwave Oven
Installation
I just took out the range and made an outlet out of the existing wiring.
Jun 25, 2008 | Microwave Ovens
Microwave Ovens Logo
174 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
