Question about ASUS M4A785TD-V EVO Motherboard
I have an Asus M4A785TD-V EVO I have added an AMD Quad Core Processor II 4X, ATI (Saphire) HD4850 Video Card with one 4GB of Ram (Kingston KVR1066D3Q8R7S/4G). The machine is not posting.Power & HDD lights and Sound do not work either. I think it is a compatability issue. I wnnt through Asus's tech online and they had no solution. I upgraded the case to a 400 Watt Power Supply. Does It need to be a 500 Watt? I also have one of those. help!
4 Suggested Answers
  • 46 Answers
SOURCE: Motherboard not work as it should work
Is this the 1st time your using Vista? Vista currently runs very slow. Vista service pack 1 or SP1 is addressing those issues. SP1 is due out at the end of the month if i remember correctly. I'm running the beta SP1 and it fixed alot of my slow issues.
One thing you can do to compare your pc to others is download PCMark and run a test. It will compare your stats to other computers to give you an idea if your computer is slower than normal or not.
You can also try a vista built in benchmark called Winsat. Go to control panel, then Performance information and tools, then click on the advanced tools, then click Generate a system health report.
Hope this info helps!
Brad Nelson
Posted on Mar 15, 2008
damnor01
  • 1179 Answers
SOURCE: Power keeps shuting off while installing Windows
It sounds like some-thing is overheating, an over stressed power supply or poor ventilation could be your problem.
See your power supply is Max 300W that's peak not continuous power output. I think it will only be able to continuously output around 250W of power. Which is below specifications for your computer mainboard.
The Cooler Master Extreme Power Plus range of Power supply's are an excellent choice.
I would recommend a 460Watt with 120mm fan at least.
damnor01
Posted on Jan 29, 2011
SOURCE: M4A785TD-V EVO Motherboard: Just installed a m4a785td-m evo motherboard, and i...
I have same problem too, stess....!!!!
Posted on Apr 17, 2011
No video after boot up
Ahem.
Driver: Small piece of software that allows the Operating System to communicate with a device.
The device in question is the graphics chipset.
The Operating System is now Windows 7 64-bit.
You were running Windows XP -> 32bit
(Have you got audio? Sound)
This is why I repeatedly try to tell people;
LOOK TO SEE IF DRIVERS ARE AVAILABLE,
before trying to upgrade to frickin Windows 7!
http://support.asus.com/Download.aspx?SLanguage=en&m=M4A785TD-V+EVO&p=1&s=24
Yes sir; sure are.
+ VGA (3)
Suggest use the oldest version -
AMD VGA driver V8 631.0.0
http://en.wikipedia.org/wiki/Integrated_circuit
The reason Windows XP blue screened is because the Integrated Graphics of the Asus M4A785TD-V motherboard couldn\'t handle the game.
You need a graphics card. A PCI Express graphics card inserted into the BLUE PCI Express x16 expansion slot, on the motherboard.
(Remember; Install the software F-I-R-S-T, then unplug from power, FOLLOW Anti-Static Precautions; and THEN physically install the graphics card.
Software; The Installation Disk for the graphics card.
Has the Drivers, and user interface.
User Interface: Catalyst Control Center for ATI graphics cards;
Nvidia Control Center for Nvidia graphics cards)
Regards,
joecoolvette
Dec 25, 2012 | ASUS M4A785TD-V EVO Motherboard
P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/#specifications
1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
and if you click on the CPU Support List you see that it does not support Dual core processor :(
May 06, 2011 | ASUS P4VP-MX Motherboard
Just finished with a new homebuilt system, I used an ASUS M4A785TD-V EVO motherboard and an AMD Phenom II X2 550 Dual Core AM# Socket Processor. My motherboard will not boot, screen is getting no signal...
I have published some guides and I have posted them below, go through them, they will help you a great deal.
I have had the same thing happen to me, try every-thing you can as described in the guides. Maybe there is some-thing new to try.
If all else fails then the best bet is to get warranty support for your computer mainboard. Your mainboard is the most probable cause of system failure.
The published guides I talked about;
How do I reset my BIOS/CMOS to defaults?
My Computer is not turning on!!! Is it dead!!! No POST!!!
Happy testing!
damnor01
Nov 21, 2010 | ASUS M4A785TD-V EVO Motherboard
Power keeps shuting off while installing Windows XP (remaining 20 mins) 1) ASUS M4A785TD-V EVO AM3 AMD 785G HDMI ATX AMD 2) AMD Athlon II X4 640 Propus 3.0GHz 4 x 512KB L2 Cache 3) G.SKILL 4GB (2 x 2GB)...
damnor01
Sep 19, 2010 | ASUS M4A785TD-V EVO Motherboard
Amd processor upgrade
The M3N78-em mobo doesn't support AM3 processors. It is an AM2 / AM2+ platform. A wonderful GPU for you would be this. http://www.newegg.com/Product/Product.aspx?Item=N82E16814102858
If you have any other questions please write back in this thread. I will be happy to help you through your computer upgrade.
Jul 06, 2010 | ASUS M4A78T-E Motherboard with AMD Phenom...
I have a problem with computer frozen, it get frozen almost every 3 hours, and make a sound like a motor, and I cannot move anything even the keyboar´s lights don{t move. I have ASUS M4A785TD-V EVO...
Sounds like its running hot, check that all fans are working and fan slotes / CPU cooler isnt clogged, You do not mention 3DFX card, ??getting hot also.
Feb 17, 2010 | ASUS M4A785TD-V EVO Motherboard
What is the minimuim requirements on resident evil 5
Yeah maybe but it gonna be SLOW so I dont recommend it. you should have a better computer.
Resident Evil 5
Publisher: Capcom
Developer: Capcom
Minimum System Requirements
OS: Windows XP
Processor: AMD Athlon64 X2/Intel Pentium D series
Memory: 1 GB
Hard Drive: 8 GB Free
Video Memory: 256 MB (ATI Radeon HD 2400/NVIDIA GeForce 6800)
Sound Card: DirectX Compatible
DirectX: 9.0c
Keyboard and Mouse
DVD Rom Drive
Recommended System Requirements
OS: Windows Vista
Processor: AMD Phenom X4/Intel Core 2 Quad series
Memory: 2 GB
Video Memory: 512 MB (ATI Radeon HD 4800/NVIDIA GeForce 9800)
DirectX: 10
Keyboard and Mouse
DVD Rom Drive
Aug 17, 2009 | Intel DG31PR Motherboard
Finding a compatible motherboard and processor
The DDR1 is now Obsolete. I suggest you to purchase entire motherboard with processor, RAM and graphics card. As it is one time investment, try purchasing Quad-Core CPU's with atleast 4GB of RAM.
Feb 15, 2009 | ASUS A7S333 Motherboard
Cost of game hardware in india
2GB RAM should be about $100, the same for installation. Your current graphics card meets the specs you provided. An upgraded video card will be about $200 for one that will work, $300 for one that will work well.
Jan 19, 2009 | Computers & Internet
ASUS M4A785TD-V EVO Motherboard Logo
43 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
