Question about Pentax Optio S Digital Camera
Optio w20 Cameraa works fint with a cable but the won't turn on with Battery - should I purchase a battery to find out if the battery is bad?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey slerm,
I would try cleaning the battery terminals inside the camera with some alcohol and cotton swabs before I went out and invested money into a new battery. The manufacturer suggests you make sure the battery is inserted correctly with the arrow pointed towards the back of the camera. If neither one of these options work for you by all means try a new battery.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 08, 2008
Need updated software for pentex Optoi W20 , soft ware S-SW58
The page containing all Pentex software downloads is at:
http://www.ricoh-imaging.co.jp/english/support/download_digital.html
Nov 03, 2013 | Pentax Optio W20 Digital Camera
Pentax optio w80 waterproof digital camera won't turn on
I had the same problem. I checked the voltage first to ensure it was greater than 3.7V (some batteries were not). I left the door open and pushed the battery down and pressed the button and it powered up. Seems to be a problem with the contacts. I put about 6 layers of duct tape on top of the battery to cause the door to push it down and now it works.
Feb 21, 2013 | Avianne & Co Pentax Optio W80 Waterproof...
My computer does not detect my Pentax Optio w20 digital camera
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ACDsee or any other photo cataloging program.
Jun 09, 2012 | Pentax Optio W20 Digital Camera
Camera comes on. screen shows OPTIO AND AT BOTTOM V1.01 THATS ALL- none of the funtions work. camera won't shut offf. have to open battery cover to shut off.
If you can get into the menu system, find "reset" in the set-up menu. If not, remove the card and battery...press every button....leave it alone for 20 minutes...insert the card and then the battery...turn it on.....this is called a "hard reset" and sometimes works.
Jul 17, 2011 | Pentax Optio 50 Digital Camera
Won't switch on. Was working fine; battery running low so removed it to recharge as I have done many times before. On reinstalling battery the camera is completely dead.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 28, 2011 | Pentax Optio A30 Digital Camera
My Pentax Optio WP beeps 3 times, goes dim and turns off. The battery is charged up fully. Any suggestions?
Hi Jesslionbery,
Please try removing the memory card that has been installed in it , if any.
When you remove the memory card make sure it starts.
If the above trick does not work , try using NIMH battery instead of the ones that you have in and check if it works.
Also if you update the firmware of the camera , it may solve your problem, please find this link for more information , as the crashing problem has been resolved for many because of a firmware update.
http://www.pentaximaging.com/customer_care/show_firmware?firmId=6442215.
Hope this helps ..:)
Jun 28, 2011 | Pentax Optio T20, T10, A20, A10, W20, W10,...
I think the battery was the problem...where can i buy and how much is the cost of it?
You can buy battery replacement for this unit from any electronic store near your area like best buy, or radio shack or you can get it from this online store , by the way the price range for the battery is $10 - $20.
http://www.batterycentury.com/pentax-optio-w20-battery-p-42693.html
Aug 13, 2010 | Pentax Optio W20 Digital Camera
I have had my pentax potio 60 for over ayear but hardly used it. Now i want to use it. i had tried many times to charge using the recommended 2 AA batteries but does not charge. or after taking a single...
Hello.
The Pentax Optio 60 does not charge batteries. You must purchase a battery charger and rechargable batteries and charge them yourself.
The AC Power Adapter cable just powers the camera, it does not charge the batteries.
Hope this helps.
Feb 15, 2010 | Pentax Optio 60 Digital Camera
My Pentax Optio W20 won't turn on. The power light turns green, but can't get it to do anything else. Screen is black. I just charged the battery. ???
took me a while to figure out your website, it should be more instructive on how to find answers to similar questions. I followed the advice of Jackboy who suggested taking an eraser to the battery leads, That worked. Thanks
Sep 07, 2008 | Cameras
Pentax Optio W20 digital camera
I found a step by step manual for this operation. I hope it helps you get to transferring movies. http://www.pentaximaging.com/files/manual/OptioW20_pc_web.pdf
Sep 04, 2007 | Cameras
Pentax Optio S Digital Camera Logo
29 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
