Question about Whirlpool Dryers
DRYER OVERHEATING - Whirlpool Dryers
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Replace the thermostat..
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
How do i find the problem with overheating on hotpoint ctd40 condence dryer
Clean out all filters and make sure there is a space of several inches from any wall . if it still over heats the thermostat is at fault.
Sep 28, 2014 | Dryers
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
Blowing out cold air
That could be your heating element OR one of the components installed for safety reason's All dryers have limits which trip if their is an overheating problem. Overheating is cause mostly bu air flow blockage. Rarely by the heat control itself. But you cannot rule that out if the dryer is clear of lint and junk. Your basic service manual and more is on my dryer page: DRYER PROBOS
Sep 21, 2012 | Dryers
My dryer Kenmore DWJR ELE 2406028 FM64 stopped working. First it would stop at intervals. Now if I let the dryer cool, I can get it to run for a few minutes. It is over 10 years old.
Sounds like it is overheating. Clean your dryer vents and remember it is attached to GAS lines so don't pull on the cabinet. You can usually pop some hidden clips on the Dryer panels to remove them and access the inner workings of the machine.
Servall is a company which carries the dryer parts and may be helpful to you. They have a Website and sometimes have Diagrams you can use. You can also try the Kenmore Website for the photos.
If the dryer vents are clean, it sounds like a thermal switch is overheating and shutting the unit down.
Jan 25, 2012 | Dryers
Dryer drum loose not lining up properly making a huge thumping sound
Identification of Dryer Problems
Signs that an electric dryer may need some repairs include the dryer not heating, clothing not drying fast enough, overheating of the dryer, the door not locking shut and the dryer not starting at all. Any of these are signs of an underlying problem that can usually be solved without the help of a repairman.
Effects of Dryer Issues
If an electric dryer doesn't heat properly, it prevents the clothing from becoming dry in most cases. Restricted venting can cause clothing not to dry fast enough, as the dryer will cycle the heating. Overheating dryers can ruin clothing or cause burns. If the door on a dryer wont close, it is impossible to get any laundry dried. A dryer not running at all can be very frustrating and lead to owners needing to use a laundromat.
Considerations for Solving Common Problems.If the dryer wont heat up, owners should check the circuit breaker to see if it's down. The voltmeter at the wall plug should read 240 volts. Checking the power cord can show owners if the wires are burned where they meet the dryer.Clothing not drying fast enough and overheating are signs of restricted venting. Removing the vent hose from the dryer can help owners decide if this is the cause of clothing not drying. If the hose is removed and the dryer runs normally, the vent should be cleaned.White plastic or thin foil ducts can also lead to overheating. Only metal ducts should be used with dryers. Kinks in the vent hose can also lead to heating issues. Overheating can also be caused by a shorted heater coil, a bad operating thermostat or worn drum seals.If the door on an electric dryer will not close, it is usually a problem with the door catch. This can be solved easily by purchasing a replacement door catch for the dryer.
When a dryer wont run, it could be a number of issues. The circuit breaker may be down or the wires at the plug may be burned. It may be an issue with the door switch. The door switch should click when closed. The thermal fuse should be checked for any issues.
Preventing Dryer Problems
The electric heating element, thermostats, fuses and thermal cut-off should be checked regularly for continuity. Dryer vents should not exceed 18 feet without a helper blower in the duct. Vents that are run vertically need to be cleaned out once a year. A meter can be purchased and used to diagnose problems with your electric dryer.
Warnings and Tips.Inexperienced people should never try to fix electrical problems at home. A professional should always be used if dryer owners suspect a more serious problem. Dryer owners can purchase kits to make cleaning dryer vents easier.
Mar 11, 2011 | Whirlpool Dryers
DRYER WILL NOT SHUT OFF. CONTINUOUSY RUNS AND IS OVERHEATING.
The control board regulates the timer functions, yours may have failed
Nov 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Frigidaire dryer is overheating
Sound like the limit switch on the dryer is faulty and needs to be replaced. Hoped this helped
Mar 14, 2009 | Frigidaire Dryers
LG Dryer overheating
check vent outlet out side house is it blowing out air.
Dec 24, 2008 | LG DLE5977 Electric Dryer
Dryer shuts off
motor overheating ..doesit "groan" when start button pressed ? If so bad motor ..possible excess lint due to poor exhaust system caused lint build up around motor causing overheating and motor damage .new motor only fix
May 02, 2008 | Kenmore 62602 Electric Dryer
Clothes dryer motor overheating
Have you repalced the thermostat?
Apr 28, 2008 | Washing Machines
Dryers Logo
57 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
