Hello my computer screen all of a sudden re-sized to pincushion size and i went to the settings menu to try to change it but it is still the same size. how can i get rid of the pincushion size?
    Problem Solver:
  • 15 Answers
The problem is from the control panel,you need to do the settings from there,if does not work then try the monitor's settings,from the monitor.
Posted on Aug 30, 2010
The resolution on my disply suddenly went HUGE and I have tried various resolutions, and the only one that seemd to work is 1699 x 1024 at 76Hz but the size of the font is too small.
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size %
click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it
if you do not see these tabs in the top toolbar
right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
hope this helps
Nov 23, 2011 | Star Cibox Inter@ctive C1905 19 inch LCD...
I have a JVC I'ART 27" TV. Model # AV 27F485. My screen is in wide screen. When I play video games or movies everything on each side of the screen is past view. I went to the menu but can't find out...
Hello
Hit the "Menu" button surf through and enter "Picture settings' screen. There you can see various picture adjustments options. Just press "0" [zero] button on your remote, will set all the picture settings factory levels, and will solve your probelm. OK.
Mar 30, 2011 | JVC Televison & Video
I have a apex tv (AT3208S) and i can not see all of the picture is there a way to change the size of it.
Yes, there is a way you can change the size for you to be able to see all the pictures on the screen.
You go to your televisions menu, select the display setting, which is a picture of a television, then you select the display setting, a list of screen size, as you select, the screen will be changing sizes so you can select that which best fits the screen.
Take care
Sep 09, 2010 | Televison & Video
I have a 17" CRT monitor.. When I was using the computer, suddenly the monitor screen size reduced like some kind of pincushion effect to the maximum... When I tried the option buttons provided below,...
if you are technical person open the monitor the biggest part named E.H.T. look at its heat sink a double diode attached to heat desoler it check it and replace it even found ok by multimeter
Aug 29, 2010 | Dell Computers & Internet
Suddenly, I can see only a part of the display width. I can't control the width size in the screen setup (all the other functions are OK)
see that it may be from the resolutions..if you give it a smaller one ..and it is a wide screen format ...it will hae black 2 inches wide band on each side... just right click on desktop properties and settings ..and restore a normal resolution on it ..
Apr 25, 2010 | Hyundai ImageQuest ImageQuest Q770 17" CRT...
Samsung txe2546, how to adjust horizontal size. I went on the service mode but there is no adjustement for horizontal size. How can I adjust it, because the image is larger than the screen... Thank you...
Hello Laurent
This is pretty easy it's like when you adjust the imgae on your pc monitor, go to the menu then go to settings, select video or image, look for the option and just change it there.
Jul 08, 2009 | Samsung TXE2546 25" TV
I cant adjust my picture size to normal on my Sony Wega 51" TV
the screen size feature is gray out because there is a previous option selected already and computer assumes you want always that size.So going into the menu and try to look for a previous selection related with: "screen size default". The menu allows you to selec this option and (i like to "standard" and i adjust screen size with my cable box feature who allows change size also if is needed, but now days cable box change it itself because is automatic) is install in the original program by manufacture because helps you to keep one size and you don't have to change it any moment. This default option is outside the regular screen size option, if i remember right is in set up screen. try to find this options in your user's manual to follow the right screen procedure..
Apr 21, 2009 | Sony KP-51WS520 51" Rear Projection...
Pincushion and h size problem on aoc 17" 771s
one of the buttons on your monitor is partially shorted. trust me, ive encountered this problem many times.
Jan 03, 2009 | AOC CT720G 17" CRT Monitor
ViewSonic E70f 17" CRT pincushion changed itsself continously
Press the [1] key & hold it for 10 seconds / till OSD Unlock appears on the screen. When OSD unlock appears on the screen , release [1 ] & press [1] or [2] key. This will unlock the OSD.
May 22, 2008 | ViewSonic E70f 17" CRT Monitor
New screens at Max. size
Hello there.
In Windows sometimes it 'forgets' its window placement but luckily we can set it back to maximised windows by default.
To do this please do the following.
* Double-click "My Computer"
* Maximise window by clicking the icon on the top right.
* Left click "Tools" menu.
* Left click "Folder Options"
* Left click "View" tab.
* Left click "Apply to All Folders" in the "folder view" section
* Finally left click "OK"
This will save your window placement to be maximised by default, for any new windows opened.
Hope this helps.
Apr 16, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
David Payne
David Payne
