Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
GE Profile PFS22S french door fridge - digital temperature module not working and now fridge not working, freezer seems ok.
  • 27 Answers
SOURCE: Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Posted on Feb 02, 2008
  • 1073 Answers
SOURCE: GE Profile French Door bottom
IT IS STILL UNDER WARRANTY call ge at 800-386-1215 for factory service
Posted on Apr 15, 2008
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
tborn6
  • 700 Answers
SOURCE: GE Profile 25.1 cu. ft. fridge is too large for door entrance
yes you can, or just removed the bottom drawer, open the upper doors and slide the refrigeraro thru the doorway by just swinging it thru. a mover friend of mine showed me that trick at it work great.
Posted on Jan 24, 2009
  • 5 Answers
SOURCE: there is a loud knocking noise from inside or the
This is normal. It is the actuators adjusting the temperature between the freezer and the fridge.
Posted on Dec 21, 2009
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
GE FRENCH DOOR REFRIGERATOR DOES NOT MAKE ICE
First thing to check is if the freezer temperature is going down low enough for the ice maker to work - around 10 degrees. The icemaker thermostat will not activate the mechanism (cam motor) unless this requirement is met.
Nov 27, 2013 | GE Profile PFSF6PK Bottom Freezer French...
Ge profile refrigerator not cooling
there is a fan that brings the cool air from the freezer to the fridge. make sure thatit is working and that the vents for it are not blocked or frozen
Nov 10, 2011 | GE Profile PGSS5PJXSS Stainless Steel...
I have a PFSS5PJXCSS French door with bottom freezer GE Profile refrigerator. Was making an awful noise and both fridge and freezer were warm. I opened back panel of freezer to find ice everywhere,...
Had similar problem, freezer was working fine, but fridge was warm, (68 degrees) It wasnt my damper, the mother board was fried, and so was the inverter board that told the compressor what to do, after having the inverter and two mother boards replaced.......I threw it out, biggest piece of ****, only three years old, and Sears would not stand behind it, even though I used their repairmen. I will never buy another GE product, or enter a Sears store again
Jun 03, 2011 | GE Profile PDS20SFS Bottom Freezer...
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
GE PROFILE FREEZER PFS 22 SISBSS
hopefully you have a service warranty. I have had me fridge for two years and have replaced the temp control panel twice thus far. serviceman coming AGAIN on Tuesday because now everything in the fridge is freezing. cna't get the temperature in freezer and refrigerator regulated properly. GE knows they have a problem...something in the computer panel board sticks. I'd give anything to be able to put this on the curb and buy a new refrigerator.
Jul 19, 2008 | GE Profile PFS22 33" Artica French Door...
Temperature display lights do not work all the time on a GE Profile french door refrigerator with bottom freezer, Model #PFS22SIASS.
I have the same problem as well, although the temperatures seem to be holding, you just can't read them.
Jun 21, 2008 | GE Refrigerators
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
60 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
