Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
Valve clearance? - Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
  • 395 Answers
The Briggs & Stratton website should be able to provide this information.
Posted on Aug 31, 2010
What is the valve clearance of nissan caravan
Valve lash is the end of the rocker arm and the valve stem clearance between. When the engine is running, due to the thermal expansion and contraction, if there is no gap between the rocker arm and the valve stem, rocker arm swells, the top valve open, the impact of engine power and economy. Engine valve clearance will be different, usually when the car is cold, the intake valve 0.08-0.10MM, clearance exhaust valves 0.10-0.12MM Car Diagnostic Tool
Aug 26, 2016 | Nissan Cars & Trucks
Valve clearance
Valve clearance Google search your year make and model valve clearance. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Checking and adjusting valves
Engine Valve Adjustment Procedure The Right Way
Valve Clearance Adjustment
Valve clearance Google Search
Aug 10, 2016 | Cars & Trucks
Valve clearance 4hj1 isuzu
Intake valves clearance cold 0.4mm(.016inches)
Exhaust valve clearance cold 0.4mm(.016inches)
Oct 28, 2015 | 2001 Isuzu Rodeo
What is the valve clearance on 2007 WR 450 F Yamaha
Intake valve -0.10mm
exhause valve-0.20-0.25mm
Feb 15, 2015 | 2007 Yamaha WR 450 F
Set valve clearance on 21hp briggs and statton
Valve clearances are set by either tappet screws in the lifters or on a lot of small engines, clearances must be set by either cutting out valve seats with a special cutter tool (to DECREASE clearances) or grinding the end of the valve (to INCREASE clearances) and generally are from .008-.010 on intake valves and .010-.012 on exhaust valves. Check engine specs to insure proper clearances.
Sep 24, 2014 | Garden
Valve clearance 4g13
make the engine runs for about 30minutes before adjusting the valves,
valve clearances:
intake valve = 0.20mm(0.008 in)
exhaust valve = 0.25mm(0.010 in)
for reference only when the engine is cold,
valve clearances:
intake valve = 0.25mm(0.010 in)
exhaust valve = 0.30mm(0.012 in)
engine specs: mitsubishi 4g13 1.3L (if you have same engine)
Feb 29, 2012 | Mitsubishi Cars & Trucks
Carburator and valve clearances
For the carb :
Idle r/min.- 1550+_50 r/min.
fuel level- 4.5+_5.0 mm
float height- 25.8+_1.0mm
pilot screw- 1-3/4 turns out
do you need jet #'s or not?
the "+_" signs are those plus-over-minus signs i cant do on my comp.
Valves:
valve diameter- in-30mm
ex-26mm
valve lift- in-5.5mm
ex-5.5mm
valve clearance or tappet clearance (cold):
in & ex: .08-.13mm
valve guide to valve stem clearance:
in-.010-.037mm
ex-.03-.057mm
valve guide I.D.: in & ex-5.5-5.512mm
valve stem O.D.:in-5.475-5.490mm
ex-5.455-5.470mm
Hope this helps.
Jan 30, 2011 | Suzuki Swift Cars & Trucks
Valve clearance 4hj1 isuzu engine
This is the specs for the 4H Diesel engine:
Jan 28, 2011 | 1995 Isuzu Pickup
Want to know what the valve clearances are for my 1999 hyndai excel
Adjust the jet valve clearance before the adjustment of the
intake valve clearance.
Jet valve clearance (hot engine)
[Standard value]. . . . . . . . . . . . . . . . . . . 0.25 mm (0.010 in.)
now adjust valve clearance
Valve clearance (hot engine) [Standard value]
Intake . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.15 mm (0.006 in.)
Exhaust. . . . . . . . . . . . . . . . . . . . . . . . . . 0.25 mm (0.010 in.)
Jul 30, 2009 | 1990 Hyundai Excel
Valve clearances
On the intake 0.0008 or 0.0020 (it's in between these 2)
this is for the stem to guide clearance. (for the intake)
The Exhaust 0.0018 to 0.0030 stem to guide clearance.
Jul 10, 2008 | 1993 Nissan Pickup
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
411 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
nirodacyar
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
