Question about Whirlpool Washing Machines
Washer model LSR8233JQ0. Cycle got to rinse section and stopped. When you try on any cycle, it just does a ticking sound for a few minutes and then shuts down totally. You can wait several minutes and it resets and then you can try again and you just get the ticking sound.
  • davidpratt Aug 30, 2010
    I do not believe it is timer, unless it is solid state, because now it will not do anything no matter where you set the timer
    I gave up and ordered a timer
  • 11,896 Answers
This could be caused by a few different things. Either the lid/door switch is faulty and not allowing power to flow through the system, or the timer may be bad. You can test the switch with an ohmmeter to see if it is faulty or not. You can test test the timer as well which is another common failure.
Posted on Aug 30, 2010
  • Whirlpool Master
  • 19,396 Answers
Re:"When you try on any cycle, it just does a ticking sound for a few minutes and then shuts down totally. You can wait several minutes and it resets and then you can try again and you just get the ticking sound."
Problem is likely the timer board, before replacing timer board better testing pressure switch, which detects the water level, as this can also cause similar problems.
If there is no filling, also check that the inlet valve is working and that there is water from the house.
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
May 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Will not complete a wash cycle or rinse cycle, stops short
I think it maybe your lid switch. If the lid switch is out it will not spin and sometimes spin or drain. can you give me a model number so that I can further assist you?
May 12, 2009 | Washing Machines
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Stalled Motor
quite possibly the drain pump which would cause it to stick in rinse cycle. the humming noise you heard is probably the drain pump powered up but jammed. likely cause is a foreign object stuck in the pump impellor - main culprit is bits of bra wire. take the pump to pieces and extract whatever is jamming it.
May 12, 2007 | Kenmore 24852 Top Load Washer
Washing Machines Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
