Question about Baby Lock Sewing Machines
Broken needle fell into opening on base babylock Esante BLN what is procedure to remove the base plate to access the broken needle parts?
  • 185 Answers
SOURCE: babylock
The arms are serial numbered to match the machine. Each series esante is different.
If you can get me a serial number (off the back of the machine) I will tell you which series you need to order. I can get it through my work.
Posted on May 27, 2008
bargainbox
  • 1388 Answers
SOURCE: Janome Needle plate and needles hitting something underneath
The broken pins are called chaining pins and are tricky for the home user to replace without risking damage to the needle plate as they are difficult to remove and the tiny burr used to hold them firm can easily open up and no longer grip the pin.
There are only a couple of things under the needleplate that are likely to collide with the needles. 1. Lower looper - with the needles 2. Both Loopers colliding with each other - not with the needles 3. Needle guards attached to lower looper - with the needles 4. Fixed Needle guard - with the needles
If you remove the needleplate and VERY gently turn the handwheel you should be able to see and feel where the collision is occuring and have a better idea of the issue.
I would strongly advise that you do not try to operate the machine until you are sure that the colliding components are adjusted. Broken loopers are approx $65 AUD and guards, tho' only about $20 AUD require some finesse in adjustment. Chain Pins approx $6 AUD
My recommendation is to speak with your local Janome dealer for advice and an approximate price to repair, replace or adjust as the case may be.
Your country's Janome website is certain to have a Dealer Locator page to list the nearest to you.
This is one occasion where it is sensible to call on the people who do these things routinely rather than try to DIY and make a more expensive hash of it.
www.bargainbox.com.au
Posted on Nov 22, 2008
  • 9 Answers
SOURCE: Babylock seger machine keep breaking the left side needle.
Try rethreading the machine, and make sure the thread is not wrapped around anything. Then check the tension for the needles. Run a few inches of chainstich off slowly, while watching the thread and loopers make the loops over the finger. Your threads may be in the wrong position, or underneath the wrong parts to start.
Posted on Jun 12, 2009
  • 14 Answers
SOURCE: on a babylock elegante the bobbin thread shows,
Have you reset the tensions for this machine, look in your manual and follow directions. If this is an Elegante there is also a set of instructions on the machine. On the LCD screen there is a picture of a sewing machine with a question mark, touch it, find Troubleshooting and touch that then find the problem you are having and read. If this does not help take it to a Brother dealer and have it reset so as to keep you machine in good running order.
Posted on Jul 07, 2009
SOURCE: looking for a babylock esante manual. ESe2. The
I have a manual for the ESe2. If you still need it let me know
Posted on Feb 17, 2010
Do The ESE ESante Baby Lock hoops fit the ESI ESante Baby Lock machines
The Babylock Esante ESE1 and ESE2 hoops are not compatible with the Esante ESI1 or ESI2 hoops. The Babylock ESI1/2 used the same hoops as the Brother PC7000 and PC7500. The ESE1/2 use the hoops that are compatible with the Brother PC6500 and PE700 series embroidery machines.
I wish that I had better news for you. This site has hoops for sale for both the ESI1 and the ESE1: http://www.allbrands.com/categories/871 . If you need hoops for either machine, use the compatibility data on each machine type to help you find more vendors that may have the embroidery hoops.
Jul 30, 2015 | Baby Lock Esante
Flashing Display, Won't Connect to Computer.
I have not yet seen babylock release a driver for windows 8 and the BLN. The dealer likely has a computer with an older operating system.
Jun 09, 2015 | Baby Lock Esante
How do I unlock it?
Normally when you have a jam with material the machine with lock up to prevent further damage. Once the jam is removed "completely" the machine will unlock on its own. But, on occasions it will not. Unplug the machine from the power & any hardware you have attached to it such as a computer. Allow the machine to "rest" for several hours. This allows the lock up to clear from the memory & the machine should preform when you return it to the power. Also remove the bed plates around the needle area & check carefully for leftover material, thread, dust, bent parts & replace the needle. Good luck.
May 28, 2015 | Baby Lock Esante
Wont connect to computer
Model number of esante? On the back of machine on the silver sticker. BLN, update available Baby Lock Esante Model BLN Update Version 1 03 you will need a computer running XP to do this update. Once done it will talk to newer windows operating systems. No Apple products even with compatibility software
Feb 22, 2014 | Baby Lock Esante
Babylock Esante stopped. Just makes loud noise but won't move even manually.
You probably have a jam. Start digging under the bobbin area.
If you get it all cleaned up under there... and it still won't move. Time for service by a pro. Could be something horrid like a bent shaft.
Good luck
Nov 03, 2012 | Baby Lock Sewing Machines
Babylock Esante BLN won't turn on. Wall plug
have you checked the power cord to make sure it's inserted correctly
into the machine?
if it is in the machine correctly, the problem could be the on -off switch
or the power cord
it would be a good idea to have the machine checked at a sewing machine
repair shop
Apr 28, 2012 | Baby Lock Sewing Machines
I inherited an Esante baby loc, golden anniversary limited edition. Unfortunately the manual was missing. I have searched everywhere with no luck. Any advice!
There is manual downloads from the Babylock website, I can't see this model but can see the Esante BLN, take a look, it may well be close enough to get you going. Otherwise you can contact BabyLock using their "Contact Us" page at the bottom of their home page, www.babylock.com.
http://babylock.com/ftp/whitepapers/Esante_BLN_InstructionRef.pdf
Jan 05, 2012 | Baby Lock Esante
Sewing Machines Logo
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
