Question about Uniden 5.8GHz Dual Cordless Phone
Put in batteries in both phones. Plugged phone into outlet and get an E 3 message. It doesn't seem to be charging.
    President:
  • 2,047 Answers
Iff both phones dont seem to be charging this eliminates the the phone as the cause of the problem as both phones cannot be faulty at the same time.
First step in troubleshooting ensure that the chargers are properly connected to the power source and that both phones are well connected.
Also check if the charger chord does not have any breakages midway through because there are then such problems can be encountered.
Finally try to check the battery authenticity as if the batteries are substandard such problems can be encountered.
Hope this solution has been helpful?
Posted on Sep 20, 2010
    Genius:
  • 1,478 Answers
I will advice you try reset the unit first and see if it will respond to charging., Follow this steps to reset the unit,
Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if it fix the problem.
Take care.
Posted on Aug 30, 2010
After charging battery,the phone dial reads, out of range,or no pwr at base
Double check that the power cable is _fully_ plugged into the phone base, then check to see that power cable is fully plugged into wall outlet; and/or fully plugged into phone wall outlet. (Some base units have no power adapter and get their power from the phone outlet on the wall). In short, double check _all_ wired connections. Do not assume they are fully plugged in.
Aug 15, 2015 | Vtech VT-CS6114 Cordless phone w/ CID/...
No dial tone on a cordless phone
Some units if the battery is not fully charged or any ac adaptor for another phone also connected is not plugged in you will now have no dial tone.
Dec 15, 2012 | GE Lands Phones
Nokia 5800 not holding charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 13, 2012 | Nokia 5800 XpressMusic Smartphone
Why does my Nokia phone say "charger not supported?
That error message usually occurs when using an unsupported third party charger. An example would be if you bought a cheap "knock off" charger that doesn't supply the correct voltage to the phone. These messages can sometimes occur in error when using an official or supported charger.
If you're sure you're using a supported charger, there is something you can try to fix this error. First, unplug the charger from the phone and the power outlet. Turn off the phone and then remove the battery. Wait about 15 seconds and insert the battery again. Turn on the phone, and plug in the charger to the power outlet and the phone. The phone should now charge.
If it's still not working, you'll need to try to get a new charger. Sometimes, if the phone is still in warranty, you can get the charger replaced for free if it is defective.
Jun 01, 2011 | Nokia 2626 Mobile Phone
Does not work, we tired a new battery, but no help.
Instructions
    Technical Difficulties
  1. If the phone doesn't turn on, make sure battery is charged and fully plugged into phone. Remove battery from phone and use rag to brush away dirt that may interfere with connection. Reconnect and try again. If using cigarette-lighter adapter, make sure it's properly plugged in. Make sure charger is properly plugged into outlet and into battery.
  2. When the battery doesn't charge, plug lamp or other electrical device into outlet to verify that outlet works. Borrow friend's charger to see if charger or battery is problem. Replace charger or battery if necessary.
  3. In case the phone gets wet, remove the battery from the phone and allow both to dry thoroughly. If rust or corrosion develops, wipe it off with a stiff brush. If phone still does not work, replace it.
  4. Should the display not be working, try getting it to room temperature, extremely cold or warm conditions may affect display functions.
  5. If the keys don't work, look for a display of a symbol that looks like a lock. The keypad may be locked. The display often tells you how to unlock it. If not, check owner's manual.
Jan 24, 2011 | Lands Phones
Panasonic phone handset display not working
Hi Nergeshb,
First try relocating the base unit for testing purposes, to ensure that the unit is plugged into a working telephone jack and that the adapter is plugged into a working electrical outlet. Verify that the in-use charge light is lit.
Additionally, there may be interference if the base unit is located near any appliances, or if it is plugged into an outlet with other devices. Try plugging the base unit into an outlet of its own.
If you are still experiencing a problem after these preliminary tests, you should reset the phone. To do this, remove the battery from the handset, and disconnect the adapter and phone line. Leave the unit disconnected for 1 minute. Put the battery back into the handset and then place the handset on the base unit. Reconnect the adapter and phone line. Then test the unit.
Thanks for using Fixya.
Please rate the this solution for your problem.
Nov 02, 2010 | Panasonic Lands Phones
Battery is dead, should it still power up if plugged in?
It will only power up after the battery has some charge in it.
If your battery is bad, it wont power on at all no matter how long you have it plugged in.
Mar 17, 2010 | Audiovox PPC 5050
Not able to charge the battery
As per Sony, if you are getting this message, it's a concern.
This message usually appears, if you are using a Battery other than Sony's.Make sure you are using Original Sony's charger. Try to use some other Charger and Battery.
If problem persists, you need to send the unit for repair. More likely, it's a firmware issue. I have hardly seen any Charge / Battery issue.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 13, 2009 | Sony Ericsson Walkman W705 Cell Phone
Suspect Battery is Dead But Not Completely Certain
In my 30+ years of servicing battery operated devices, I have to tell you that 95% of the time, it's a bad battery.
Question1 : I agree that it should operate on outlet power. Perhaps the battery has a shorted cell and is eating up all of the charger's available current. Chargers have a limited amount of capacity.
Question2: Charge the battery then remove it from the phone. It should be slightly warm to the touch if you touch it within a few minutes of completion. If you have access to a DC Voltmeter, let the battery sit for a couple hours and check the voltage. It should be at least (usually higher) what is written on it. Other than that, replacing it is the only other way.
Hope that helps...
Geno
Apr 04, 2008 | Sanyo RL-4930 Cellular Phone
Uniden 5.8GHz Dual Cordless Phone Logo
20 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
