Question about HP DeskJet 5650 InkJet Printer
I have an HP deskjet 5650 and just changed both black and color cartridges. Test sheet ran fine with color and black. Now I am trying to print a Print Shop color document and the printer will only print black and white. I cannot find any grayscale setting I may have selected. Please advise me on how to print in color. Thanks.
    Brigadier General:
  • 10,406 Answers
Click Start
Click Control Panel
Click Classic View
Click Printers
Select your printer
Right-mouse click on the icon
Click Properties
Set the printer to print in "colour", not just "black".
Posted on Aug 30, 2010
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
I put a new hp tri colour cartridge in my printer ....when it prints off test sheets it prints in colour but when i try to print off colour documents it only prints black and white
There's an option under your print setting for color or black and white. When you select to print a window will pop up. make sure that you have the color print selected. Hope this helps
Nov 10, 2013 | HP DeskJet F4280 All In One Printer InkJet
Will not print envelopes in black
It sounds like you need to run an electrical check on the printer, it is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see steps with instructional video on how to activate these hidden diagnostic HP utilities: http://inkjet411.com/?page_id=2358
Apr 16, 2013 | HP DeskJet 5650 InkJet Printer
My HP Deskjet 5650 will not print in color even though i have installed a new cartridge yet the test page is in color??
Just check your printing property and choose color print and apply the settings and then ok.
Good Luck
Feb 26, 2011 | HP DeskJet 5650 InkJet Printer
Hp deskjet 5650 printer is printing A test page after every print job I do. I've tried system shutdowns restarts and turning the printer on and off.
It might be prinitng the alignment sheet because you might have replaced the cartridges receently. So pleae scan that sheet once to complete the alignment and I believe it will fix the issue.
If your issue gets fixed, please come again to give us a
vote which will really motivate me to help people in
future.
May 10, 2010 | Office Equipment & Supplies
I have a HP DeskJet 842 C. I have a black
The nozzles of the color cartridge is blocked or u have set the photo print to gray print
Apr 30, 2010 | HP DeskJet 5650 InkJet Printer
Hp 5650, black ink not working
try cleaning the copper contacts of the cartridge and the inner area of the slot where the cartridge goes in..
Also go to the Printer & Faxes under Control Panel and open the printer's properties..select Printing Preferences >> Paper / Quality >> under the color section check if "print in greyscale" is checked..
it shud not be checked...
save changes and try to print
Oct 01, 2008 | HP DeskJet 5650 InkJet Printer
Prints everything in black and white...
When you try to print something, go to the Properties of the printer, before the final OK to print to see if you can make a selection of the cartridge.
Aug 22, 2008 | HP DeskJet 5550 InkJet Printer
Hp deskjet 5650 inkjet printer
Click Start - Control panel - Printers & FAXES
Right click on the printer icon Officejet 5600 series -- Select properties - Click on ports tab - Change the port to USB virtual port.
Disconnect the usb cable from the computer.
1. Click Start
2. Click Run
3. Type Services.msc
4. Locate print spooler on the list, right-click and choose stop.
5. Again right-click the print spooler and choose start.
Reconnect the usb cable try printing.
Thanks.
Dec 22, 2007 | HP DeskJet 5650 InkJet Printer
Not printing color
Loks like there is a "well" under the "docked" position of the heads (at the right end of the unit, facing it - under the control buttons.) In my unit, ink had built up in this well to the point that some of the mechanical bits were scraping the top of the built-up ink pile. After I carefully removed about two TootsieRoll's-worth of old dried ink with a long scewdriver (using a flashlight to illuminate the area), the color printing seemed to be doing better. Can't tell yet if this has completely resolved the problem, as I have not yet printed enough pages to prove the point...
Nov 05, 2007 | HP DeskJet 932c InkJet Printer
HP DeskJet 5650 InkJet Printer Logo
224 people viewed this question
Seeker5211
Seeker5211
