Question about HP (P2074-69003) Motherboard
I have a hp tx1003au laptop.it works some times.but most of the time it never works.i went to the hp service center but they told me to replace the motherboard which is very costely.what i do
3 Suggested Answers
gsage
  • 180 Answers
SOURCE: laptop not working
You've got it right - it's the dreaded nvidia chip failure. If you do replace the m/board ( not as expensive as some boards ) ensure the AMD processors heatsink fan remains clear to breathe - AMD processors run hot and this heat is what kills the nvidia chip.
Sorry but the only repair because the GPU ( graphics chip ) is built into the m/board is a new m/board.
Posted on May 22, 2009
  • 124 Answers
SOURCE: hp pavilion dv2000 display scrambles
It sounds like the graphics chip is on its way out the only solution is to invest in a new laptop or look on places like ebay to buy a motherboard, you could probably find one from £10 to £100
Posted on Aug 22, 2009
I bought a new pavillion dv7 -4192sf yesterdat managed to start uo the machine load bitdefender. went to use it today and the machine would not fire up. A message came up 'Detected fan problem will...
This seems like a hardware problem and since the laptop is just one day old you are entitled to get a complete exchange for the laptop.You need to carry the laptop to nearest HP service center who will certify that the system was dead On Arrival (DOA) and once it is been certified from the hp service center as DOA you can take the system to the store from where you purchased this laptop and get it exchanged.
Dec 25, 2010 | HP Pavilion dv7-1130us laptop
My notebook screen immediately splits into four equal segment when powered
I suppose you must have a Nvidia Graphic Card....
This is a very common problem with nVidia geforce 8400 and 8600 cards.
Serach google with this "Defective Nvidia geforce card" and you will see lots of user facing same problem in HP, Dell etc..
I too have an Hp laptop with nvidia geforce 8400. I have faced similar problems(screen got divided into 8 parts) in past for 3 times. Every time I have to replace my motherboard at HP service center.... It is caused by overheating of laptop that destroys the nvidia graphic card.
Go to the service Center and ask for a motherboard replacement.
hope this will help.....
Sep 26, 2010 | Computers & Internet
Hello, My HP dv9000's screen has split into four horizontal parts. They are all slightly yellowish and it is almost impossible to read anything in them. Please can you help?
I suppose you must have a Nvidia Graphic card in your laptop....
Sep 26, 2010 | HP Pavilion dv9000z Notebook
Hi! Just want to share to you my HP dv2520 problem. I bought my notebook last august 8, 2007 from dubai and experienced a problem during start-up last year on August 7, 2008. It won't start normally after...
Try removing all the hardware exept for one stick of RAM and HDD (ie. wireless card, battery, modem, etc) then see if it boots up OK, if it dosent, try the other stick of RAM instead of the other (if it has 2), if it does, keep adding hardware untill it does not, then either replace the faulty hardware or if it something you don't need dont put it back in (eg. modem).
Aug 11, 2009 | HP Computers & Internet
The hp pavilion dv2000 not booting
You might be still covered under extended warranty, check here
Jul 27, 2009 | HP Pavilion dv2000 Series Laptop Full...
Laptop not working
May 22, 2009 | HP (P2074-69003) Motherboard
Laptop problem
you can try this: unplug from power, remove battery, press power button for about 30 to 60 seconds, connect back to power leave battery out, turn power back on. see if that works.
Let me ask you this, when you turn the power on: do you see or hear the hard drive spinning?
let me know if it works,
good luck
Mar 28, 2009 | HP Compaq Presario C500t Notebook
HP Pavilion dv 9205 us tries to start up, screen stays black
THIS IS A LONG REPLY POST BE WARNED : HOWEVER IS LIKELY HELPFUL TO OTHERS WITH INTERMITTENT LCD / PORT ISSUES. MY STORY,... Hi all. Ok, i'm gonna chime in here on this. I have the HP DV9205us and i've returned my unit a total of three times. Ultimately I was told (under warranty for 24 ms) that it will likely need to be repaired due to same intermittent display and other intermittent issues with most ports. I had three different people 'working' on it. Uh-huh. They advised it would likely need to be replaced. I sent it in. Two weeks later I got my same laptop back. The billing sheet was $0.00 however, it stated they replaced the MB, HD, memory and LCD. The first repair was exactly what you're commenting on for intermittent ports and most notably display failure at times. I, again went through phone troubleshooting with them. Had to send it in a second time for same issue. They then told me they had to replace the MB and memory this second time. It worked for awhile. Within a few weeks (maybe five) the same issue happened. However, accompanying the intermittent issues was a serious heat problem. My unit was running VERY hot. In fact one of the ports actually melted the plastic side face. They asked me to send it back a third time and the billing sheet went down the list of everything replaced. MB, HD, memory, LCD and this time replaced the power supply. Hmmm,... I though to myself. My unit overheated to the point of smoking and melting. They've now replaced everything at least twice or more. Now they have basically given me a whole different laptop with piecing it together and now my case is melted. I contacted them and they advised that it was 'cosmetic' and not covered by my extended warranty. I wasn't pleased to say the least being that they pieced together my supposedly new laptop over the course of hit and miss at my expense of course (time without laptop). I told them I took the extended warranty for almost $300 extra dollars and was told it was covered for EVERYTHING except intentional damage. i even bought the high joules-rated power compressor, blank media, screen wipes, plate cooler, etc. It didn't matter, he didn't relent. I was keeping this laptop. He stood his ground. Whatever my case may be it's not going to be as agreed. So, I moved on to the second question. Why was my power supply replaced the third time and not the first time? He began to state it was customary to troubleshoot in a chain method until it's resolved. I then posed to him, why they sent me a differnt power supply this time. Different model than I was sold. He stated it was the same model. I told him I recorded everything for my insurance and it includes serial / model numbers. He read to me what the model of the PS should be and asked me if that's what I have. Of course i've got that one now. Why was I sold a defective PS in the first place. To me, it's very clear that my problems were resolved not by replacing everything in the pc. But by starting at the most common sense place. The power distribution from the wall pack or the MB. Nothing more. To me it was overkill to replace EVERYTHING multiple times. It told me HP didn't know what they were doing. It was a clear sign of that.
As of this date, I have had a functioning laptop without intermittent problems. No longer overheating and still am reminded by the scars on my melted case. Cosmetic? Umm,... I think that's why they spend millions marketing colors and flashy things. The look is what brings customers to see what the laptop offers. I actually researched HP and am a Sony guy typically. I bought my wife the Sony and I bought my HP. I waited two years to make the decision. I not only took the leap, I also took their full coverage option. I feel taking a laptop without the + warranty isn't smart investment. It depends on how mobile you'll be. Many people are business, as am I. Downtime is critical. Needless to say, I got no appology from HP. Meanwhile, my wife has yet to even reformat her HD again. With a year plus in my pocket, i've had to personally reimage four times trying to troubleshoot with them on the phone. Also, the two or three HD's they put in.
The long and short of it. HP took me for a ride. I sat patiently. I did everything they asked. I went without. I payed additional. In the end, I have a port module melted that reminds me every day that HP will not be welcomed anymore. I am sorry to kick them to the curb, but going off of how I was treated and the idiocracies they subjected me to in troubleshooting, i'd venture to guess many of you feel the same way. I'm sure mine is a little more labor intensive. I just want you to know your complaints didn't fall on deaf ears. HP abandoned the 9205 and I haven't found quite the same problems with the newer models. Aside from my treatment, I love the look and feel of HP. I have fourteen Sony products in my home entertainment system. Guess where my first look will be in the future of laptops? I shouldn't have strayed. My wife is plenty happy and i'm jealous.
Maybe the PS issue is related. Maybe ohm and test it for output. Most techie nerds you know can do this for you. Look for intermittent power delivery. HP never acknowledged the problem in writing. I couldn't even get them to acknowledge my question on the phone. It was the slippery-trickery on the phone. So, i'm passing it on. When I troubleshoot such problems in the future. I'll start at the most obvious. However, I have no problems with any Sony products nor my wife's (Sony) laptop. So, I don't figure on having it happen ever again. This is likely helpful to a variety of laptop owners with intermittent LCD / Port issues. Glad to help.
Thanks for allowing me to vent. I think I feel better. No wait,... may be the whiskey.
Jan 05, 2009 | HP Pavilion dv9205us Notebook
HP (P2074-69003) Motherboard Logo
43 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
