Question about Saeco Vienna De Luxe Espresso Machine
Broken coffee maker
I am cleaning the saeco vienna then the red light suddenly blinking after wiping and discarding the ground coffe i turned it off and then when i opening it again no more light green and red totaly powered off. Pls, help me to solved it immediately before my employers comes home .
  • 515 Answers
I don´t no realy what you mean, if you have the door open so will the machine be dead, there are a switch in the machine that power off when you open the door.
Posted on Jul 11, 2008
Red light on, not blinking
make sure your steam button is completely turned off
Jan 14, 2012 | Saeco Odea Giro Plus Coffee Maker
After making coffe red ligth is on, coffe is just fine?
Which red light is on? It may be that youa re emptying the dreg drawer with the power off. When you do this it doesn't reset the counter that tunrs that light on
Feb 14, 2011 | Saeco Vienna De Luxe Espresso Machine
I just received a used Saeco Vienna SuperAutomatica and I can not get coffee to brew. Drive grounds are shot into discard bin
HI
You must have 2 knobs in the bean hopper, or the grinds are more like French Press (very large grinds) If yoou just have 2 knobs turn the small one towards the minus (-) a little, and see idf that helps. If you hqve very large grinds you grinder has seperated and needs to be replaced.
Oct 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Red light from the coffe keep blinking
make sure all the doors are closed, brew group, tray, water, and disposal are all seated closed.
have you cleaned the brew group? something stuck in the grinder? got beans and water?
Sep 19, 2010 | Saeco Vienna Espresso Machine
COFFE MACHIEN WON'T MAKE COFFEE
Hi
A blinking red light means that something is not in place. The usual subject is the drip tray. If it doesn't lock into place usually there are grounds behind it. The brew unit is an other one that doesn't lock in every time. To check, open the door and without pushing the "press" button, grab the handle and pull. If it comes out, that was your problem.
Jun 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe grinds but plugs up at door
Try this: clean out the chamber, then set the grinds coarser to see if it makes a difference. If it does not then the micro switch or solenoid that controls the door is broken. Check resistance on solenoid it may need to be replaced.
May 10, 2009 | Saeco Vienna De Luxe Espresso Machine
Grinder starts, but doesn't wet coffe before red light comes on
This is a duplicate, here's the answer
I have the same problem but it's easy to fix. Turn the machine off. Open the front panel. Remove the dump box on the side. Pull the grinder unit out.
Look at the thing you just pulled out. You'll see a little ramp going from where everything slides down from the top. That ramp gets damp and the freshly ground coffee starts sticking on it. Take your finger and wipe it off.
Next, is kinda hard to describe. If you put your fingers inside, along the top, center edge of the machine you'll feel a ridge. It's a spring loaded door. Pull it down and clean the grounds out.
Slap it back together and you're good to go. Only takes about a minute when you get the hang of it.
Jan 05, 2009 | Saeco Vienna De Luxe Espresso Machine
You can download a manual at www.cerinicoffee.com
Jun 10, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
197 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
