Question about Kitchen Ranges
The "hot surface" light will not go out. - Kitchen Ranges
  • presterd Aug 30, 2010
    How does one check or change this burner sensor or light? Does the ceramic cook top lift up?
  • presterd Sep 01, 2010
    It is a Whirlpool Accubake System, Super Capacity 465, model # RF386 PXG OR # RF388LXG.(I cannot tell which from the manual, and I haven't tried to pull it out from the wall to look at the back panel).
    Master:
  • 497 Answers
Please give me more info on Make &
model, plus problem description. (i.e. is the light on but the surface is cool?)
Posted on Sep 01, 2010
  • 864 Answers
Can you please provide me with the make and model of the Kitchen range and then from there i will be able to better assist you with your problem. Thanks, Midwest-tek
Posted on Aug 31, 2010
    Genius:
  • 1,478 Answers
There could be a problem with your burner sensor (stuck open or closed) or your indicator light circuit. you will need to check or replace the entire light unit.
Take care.
Posted on Aug 30, 2010
Hot surface indicator light stay on?
One of your surface elements is bad (the hot-element switch that is part of the element is stuck on). If each element has its own hot-light, then you know which element is bad; but if you have just 1 hot-surface indicator, your problem is figuring out which element is bad. That takes an electronic technician with patience and an ohmmeter.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 24, 2014 | Whirlpool RF378LXKS Electric Kitchen Range
The surface light on my mothers stove stays on and all burners are off and cold any ideas why
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Oven Hot Surface Indicator Light stays on
heatman101
Jan 18, 2011 | Maytag Cooktops
Hot surface light will not go out
heatman101
Sep 02, 2010 | Maytag Kitchen Ranges
GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Jul 01, 2009 | GE Kitchen Ranges
Pilot Light Wont Light
Take off the top cover plate inside the oven. Now with the door open turn the oven on does the hot surface glow? If it doesn't glow then you have a bad igniter and needs to be replaced. What ever you do don't touch the surface of the new igniter human oil will shorten the life of the igniter. now if the hot surface glows then the gas valve is bad and need to be replaced. I'm betting it's the hot surface.
Nov 25, 2008 | Amana Ovens
The hot surface indicator light remains ON all the time.
Your hot surface indicator light might have a short that causes it to stay on all of the time. If you can, try unplugging it for a little while and plugging it back up. If the light is still on, you have a short. You can still use the stove, but the light staying on will not be any help to you.
Oct 22, 2008 | Frigidaire FEF366EC 30" Freestanding...
Hot surface light
across each plate there is a cutout - you can usually see it thro the ceramic and is a rod going across the plate. it also senses that the plate is hot and turns the hobhot light on. this is the part that is faulty. sometimes only available as a complete plate
Sep 02, 2008 | Frigidaire FEF366 Electric Kitchen Range
The hot surface light is staying on and will not go off. Is there a way to fix this?
Each element contains a sensor to detect when the element is hot, this sensor has failed. The element will have to be replaced. If there is only one light to indicate hot surface, you will have to determine which element has failed.
Jun 09, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Surface unit indicator light is always on
Coffy, if you are talking about the hot surface indicator lights, they are controlled by the limiter on the burner itself. When the burner heats up the limiter closes and sends power to the light (hot surface). When the burner cools the limiter is supposed to open cutting power to the hot surface indicator light. They may be stuck closed. If you are talking about the lights on the back panel, that is controlled by the infinate switch itself. Catriver
Oct 09, 2007 | Kenmore 96012 / 96014 / 96019 Electric...
The "hot Surface" light is remaining on continuously. (the surface light is off)
all surface knobs [switches] feed into a common relay for the surface light. check for a stuck relay.
Aug 20, 2007 | Maytag MER5750 Electric Kitchen Range
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
