Question about GPS
My garmin gps etrex vista will not turn on bats. are good not sure if its the screen i have no manual
  • 2 more comments
  • gyoung11446 Aug 30, 2010
    it did not wopk all blank will not power up
    this did not work still wont power up
    This solution does not work as the unit itself will not power on to begin with. I tried your solution and it did not work. I have tried new batteries and also tried a "Super Master" reset of the unit and it still did not work. Any other suggestions?
    I cannot turn the unit off to do your suggestion as the unit itself WILL NOT turn on at all. This is my problem and was the problem that I had originally stated. I tried what you had said and it still did not turn on the unit! What other suggestions do you have to get my unit turned on?
  • 857 Answers
Turn the on button at the top of the device o by pushing it to the left and hold in that position for at least 20 seconds. The device will reset and turn on.
or
•The main plate under the logo of Garmin has to be taken off.
•In there, you have to press the button for resetting.
If this doesnot work the battery might be faulty and may need a replacement.
Posted on Aug 31, 2010
    Genius:
  • 1,478 Answers
I suggest you reset your GPS, to reset your gps, follow this steps, turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Once the Garmin GPS unit is reset, remember to place the device outside where there is a clear unobstructed view of the sky for 15 – 30 minutes in order for it to requires fix to GPS satellites. with this, this should fix the problem.
Take care.
Posted on Aug 30, 2010
Somehow my map got erased from my garmin etrex vista, how can I get a map back on it?
meu etrex vista hcx não reconhece nenhum cartão de memoria, ja tentei pelo menos uns 3
diferentes que funcionam em outros lugaresaguardo uma resposta obrigado
Nov 23, 2010 | Garmin eTrex Vista HCx Handheld GPS...
My etrex vista cx will not turn on- new batteries installed
as its new, it would be unwise to fiddle around with it. Return it for exchange,
Before you do though make sure that the batteries are good and have been inserted in the correct polarity.
Etrex Vista is a very robust unit and most reliable generally, so this is unusual.
Please rate my help++++Thanks fo using FIXYA
Jul 31, 2010 | Garmin eTrex Vista Cx GPS Receiver
Garmin eTrex Vista Cx won't turn on
Call Garmin customer service, they are wonderful. My rubber thing around the outside became loose,and they sent me a new unit, even though it was almost 2 years old.
Apr 11, 2009 | Garmin eTrex Vista Cx GPS Receiver
My eTREX VISTA won't get a satelite fix any more
The unit needs to have the screen facing up. The unit will not read if it is vertical. Garmin cust serv finally helped me with that one. Once you turn on the unit, it could take up to 20 minutes (usually about 3) to grab satelites.
Mar 26, 2009 | Garmin eTrex Vista Cx GPS Receiver
Garmin etrex screen too dim to read
I have an older Garmin 12XL and suddenly the screen turned very dark. I tried replacing the batteries and let the GPS rest for a week so the internal lithium battery could re-charge. But that did not work. I just got an email from a friend who had the same problem... it turned out that his unit had changed the screen contrast setting all by its' self.
This may not be the cause of your problem but it's worth trying... go into your "Settings" menu and reset the contrast and see if that cures the problem. Good luck.
Sep 22, 2008 | Garmin eTrex GPS Receiver
Garmin Etrex display problem
Have you updated your Garmin unit software recently?
Mar 21, 2008 | Garmin eTrex GPS Receiver
Screen Blanks
11-08-07
I had the same problem with an etrex Vista. I spoke with Garmin, they said that a recently launched WAAS satellite is interferring with some models (he mentioned it is the models with a black and white screen). Garmin tech support said that they're working on a software patch but for the meantime switch WAAS off.
Call Garmin tech support with any questions or to find out about the software patch, 1-800-800-1020
Nov 04, 2007 | Garmin eTrex Vista Cx GPS Receiver
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. http://www8.garmin.com/support/download_details.jsp?id=711 Update the unit using this latest software and using Garmin's Webupdater. http://www8.garmin.com/products/webupdater/howtoinstall.jsp If that won't work, use the following download page to access the latest software updates per units. http://www8.garmin.com/support/blosp.jsp 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Mar 28, 2007 | Garmin eTrex Legend GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
