Question about GE GSS25SGMBS Side by Side Refrigerator
GE model #GSS201EMBWW is not defrosting, checked defrost heater and it was burned out. Replaced with new 2 heater design and now it burns all the time, which is most likely what burnt the other 1 out. Looking at forums it says this model does not have a defrost timer, instead has mother board that controls the defrost. I would think that if the mother board was bad it wouldn't heat at all. Any info you have would be helpful
  • GE Master
  • 1,606 Answers
This is how the defrost works . I have NEVER found a defrost problem associated with a bad main control board since these computerized GE's came out in 2000 . Lots of thermistor problems , lying to the board , causing different problems .
Your GSS model refrig does not have a defrost timer . It works off of the main control board . Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Posted on Aug 31, 2010
  • GE Master
  • 17,130 Answers
The drive output - solid state relay maybe a thyristor - is short and is continuously heating the element thus burning it off.
The element is supposed to heat only for a specific period of time. The motherboarrd must be taken out to confirm the shorting of the thyristor/SCR.
replace with the same type and it will only swittch on when the microprocessor timer signals a bias to turn it on.
Posted on Aug 30, 2010
  • 1 more comment
  • davef636 Sep 28, 2010
    I have the same refr. It wasn't defrosting and water was collecting in the bottom of the fridge compartment and running on the floor.
    Replaced the defrost heater awhile ago with the double element unit.
    Defrosting was still hit or miss so I turned off the ice maker.
    It seems to be defrosting ok with the new heater but still getting some water in the fridge, but less.
    Now I've disconnected the damn water supply. I thought maybe the filter's plugged but there's no filter to be found.
    Jeez!
  • tonyss350 Sep 28, 2010
    My refrig was running water in the floor when defrosting after I installed new heating element. Turns out is was my fought. I had stuffed a paper towel into the drain hole while defrosting before I install element and forgot to remove it. This will surely run water right out into the floor
    I unpluged refrig. and hooked up the heating element again and when I did this time, everything started working ok. I guess it just had to restart. Thanks for all the help
My rgr profile side by side is at 47 and wont go down
The PSS26MSRSS is famous for burn out of the defrost heater part number=> WR51X10042 or 914080 Defrost Heater you may click on photo or banner for Repair Clinic once on our web site. You should always replace the defrost thermostat while working behind the freezer rear wall with power disconnected. Part=> WR50X10054 Defrost Thermostat or 1170024 Defrost Thermostat
Watch our "Part Testing" video to determine if the defrost heater has burned out and needs to be replaced. Please rate this solution and as always thanks for usingFixya, Sea Breeze
Feb 10, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE side by side model gss221fphww.The freezer is icing up and the refrigerator part is not cooling well.
johnnybur64, That is a typical sign that the defrost heater and defrost thermostat need to be replaced, Those models have very little problems with the motherboard section that tells the defrost to come on. Most times just those parts defrost heater=> WR51X10101 and defrost thermostat=> WR50X10068 will be all you will need. Unplug remove rear panel and defrost with a hairdryer to speed things up. When that defrost heater burns out you can see it easily through the glass tubes, I always replace the defrost thermostat because it is cheap insurance that you will not need to go back inside. You also can find these parts here=> GE Artica Profile Technical Information
If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breezed28e6ff.jpged3daa8.jpg
Feb 01, 2010 | GE Refrigerators
Why is my side by side freezer not freezing
Most likely your refrigerators defrost heater is burned out. The PSS26MRSS has no defrost timer and defrost is done when the motherboard tells it to. I have not seen may problems with the mother board when it comes to defrost. Check the rear wall of freezer for frost and if yes unplug and remove contents and rear panel in freezer. Get a hair dryer to speed things up and once the ice is melted look for the defrost heater at base of the evaporator coil. When they burn out they are easy to spot because the outer tube is glass covering the defrost element inside. If burned out replace the defrost heater and defrost thermostat. I will instruct you, Thanks, Sea Breeze
Jan 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator model GSS23QTACC has frost buidup on the back wall and the top shelf is defrosting. What can I do?
OK the most likely reason for this on you model is the defrost heater and defrost thermostat will need replaced. The least likely would be the motherboard. The part number for the defrost heater is=> WR51X10055 onece you unplug and manually defrost the refrigerator and remove the rear panel you will be able to see the burned out defrost heater because it is covered by a glass tube. Always replace the defrost thermostat part number=> WR50X10054 when replacing heater. The only thing left would be the defrost control on the motherboard. If you need help there you had better let me know before you go and spend a arm and leg for service. You can find me here at Fixya or=> Here or here=> Sea Breeze Appliance Parts and Technical Services if you need answers let me know! Thank You, Sea Breeze
Dec 13, 2009 | GE Refrigerators
GSS201EMBWW Unit is freezijng up.
Most likely part number WR51X10101 Defrost Heater has burned out. Unplug and remove the rear panel inside the freezer. Defrost with a hair dryer and examine the defrost heater and look to see if burned out, It has a glass tube around the heater element and will be easy to see if burned out. If you need to replace the defrost heater you should also replace the defrost thermostat part number WR50X10054 If you don't see a problem with the defrost heater and I will instruct you on how to manually defrost to test the heater and defrost thermostat. Check for bad connections on wiring to heater and defrost thermostat. Your model has a mother control board part number WR55X10942 We may also need to check that because it does the thinking and determines the time for defrost. Let me Know what you find, Thanks, Sea Breeze
Oct 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side is freezing in the back of freezer, I have to defrost once a month. How do I check what parts I need and how to fix it
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Need location of defrost timer
The refrigerator you listed does not have a defrost timer. All defrost and refrigerator functions are controlled on rear of the refrigerator. It's called a mother board. If it s damaged you will sometimes see burns on one of the both sides, but not always. Another problem could be that your defrost element or defrost thermostat is defective. You can see your refrigerator below by putting the model GSS201EMBWW into the model search feature. I am here to help you if you want, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Here is another link here on FixYa that shows the mother board
http://www.fixya.com/support/t230703-ge_refrigerator_stopped_working
May 28, 2009 | GE GSS25SGMBS Side by Side Refrigerator
GE frige no defrost
I guess the first thing i would check is to make sure the control board is getting a proper ground. next i would manually put it in defrost (while it is still frosted) and make sure the heater is glowing red hot. other than that i would have to suspect another bad board? let me know how it turns out
Jul 02, 2008 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
GE Profile SxS Refrigerator wont defrost after new heater installed
If one coil was burnt out and you replaced the heaters and defrost terminator switch I would recheck the continuity through the defrost heaters. You can do this with an Ohm meter with the refrigerator unplugged. If you had an open coil in one of the heaters you did not have to replace the thermo disk. If you have a complete circuit through the heaters try using the old thermo disk. If you have a meter you can check the voltage from the heater connection on one side to the inlet side of the thermo disk with the refrigerator running in the defrost mode. You should read 115-125 Volts on the meter. This reading tells you that the defrost timer is supplying power to the heater circuit.
Apr 30, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Intermittent Warming on GE side by side
The most common cause of this with a GE fridge is the defrost heating element is burned out.
Empty the freezer, take out the shelves and remove the back wall. You will see the heater at the bottom of the evaporator coil. It is a glass tube with a heating element inside it. Some models have two heaters, some have one. If either one looks black inside the glass it is probably burned out. You can check them with an ohm meter. If you don't have a meter, take the heater to an appliance parts dealer and they will check it for you. If yours has two heaters, they must be replaced as a set.
If the heater is not your problem, post the complete model number from the fridge and I will try to walk you through the defrost system checks.
Mike
Apr 06, 2008 | Refrigerators
GE GSS25SGMBS Side by Side Refrigerator Logo
1,470 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
