Question about Freestyle Mongoose Bmx & Owners Manual - Bike / Bicycle
Need to read owners manual for samsung wf218an washer
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Freestyle Master
  • 102,366 Answers
WF218ANB: http://www.samsung.com/us/support/downloads/WF218ANB
WF218ANB/XAC: http://www.samsung.com/us/support/downloads/WF218ANB/XAC
WF218ANW: http://www.samsung.com/us/support/downloads/WF218ANW
Posted on Dec 08, 2010
No power to washer, can't open the washer door
http://www.appliancepartspros.com/parts-for-samsung-wf218anw-xaa-0000.html Look at the video section to see how to get under that machine and open the door and drain it.
Oct 04, 2015 | Samsung WF218AN Front Load Washer
What code does LE stand for on Samsung front load washer
LE LE1 E9 11E Natural drain/Water leak - Low water level detected during cycle. · Check that the level of the drain hose is not lower than the base of the washing machine. Additionally check for a water leak. If no trace of water, switch off the power, reconnect and try again. · If problem persists please call the customer support team.
Mar 15, 2015 | Samsung WF218AN Front Load Washer
Samsung washer reset
sound like module problem try to remove all the conection connecting the module and connect maybe after 30 mins.
Nov 06, 2013 | Samsung WF218AN Front Load Washer
Samsung WF218AN washing machine is leaking from the soap dispenser
Simple sugestion, try cutting back the water in flow rate from the taps, If this works, unscrew the hose from the tap and fit a stainless washer with a small hole in the inside, on top of the wire mesh water filter on the inlet pipe to restrict the flow. Hope it helps.
Dec 01, 2011 | Washing Machines
Machine not filling up with water
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 19, 2011 | Samsung WF218AN Front Load Washer
I am trying to start my washer and the symbol of a head with a collar appears on the dial and i am unable to change any of the controlls or start the washer.
Hi.
Samsung machines error codes are numbers and letters, then I the machine is not in fault mode, but child lock has likely kicked in.
Here is child lock icon:
Try the following:
ACTIVATING/DEACTIVATING
If you want to activate/deactivate the Child Lock function, press the Soil Level and Signal
buttons at the same time for 3 seconds.
How It Works:
1. "Child Lock" can be activated while your Washer is running.
2. Once you activate "Child Lock", all controls (except for the Power button) will be locked
until you deactivate "Child Lock".
3. The Child Lock button will be lit while it is in effect.
Here the user manual.
Jan 11, 2011 | Samsung WF218AN Front Load Washer
Samsung Front Load Washer WF218AN puts stains on clothes, looks like oil, this machine is less than 2 years old. Could it be He Softener not being rinsed properly due to inadequate water? Sears and Samsung...
replace or clean rubber insert on washer as the scum is oily and will always get on clothes when getting out clothes.the rubber is easy to clean just be careful of the barrel when wiping on the inner side of rubber.
Jan 09, 2011 | Washing Machines
Samsung front loading washer, New, model WF218AN doesn't spin right, clothes is too wet for the dryer, even if i re-spin it
IF IT IS NEW YOU SHOULD CALL FOR SERVICE. SAMSUNG HAS A 1 YEAR WARRENTY. IF YOU ARE USING HE SOAP AND NOT TOO MUCH YOU SHOULD CALL FOR SERVICE
Jan 13, 2010 | Samsung WF218AN Front Load Washer
Freestyle Mongoose Bmx &  Owners Manual - Bike / Bicycle Logo
299 people viewed this question
Top Freestyle Cycling Experts
Michial Gueffroy
Rommel Balcita
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you a Freestyle Cycling Expert? Answer questions, earn points and help others
