Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Theres a double 60 double 30outside does a 220 wire run to points from breaker box
    Problem Solver:
  • 19 Answers
Typically 230v appliances do have a dedicated circuit, yes.
Posted on Aug 30, 2010
HOW TO WIRE E3EB-20 TO PANEL BOX
I'm just assuming that is 220 volt 20 amp The wire that is run is likely a common romex 12-2 NMD-90 Strip the 2 wires put red tape on the white wire as it is no longer a neutral. Hook both wires into a double 20 amp breaker. Put the ground wire onto a ground screw.
Nov 28, 2013 | Heating & Cooling
HOW TDO I HARD WIRE MY FISHER PAYKEL DOUBLE OVEN TO THE 220 THATS COMING FROM MY BREAKER BOX. IM TRYING TO TEST THE OVEN....IT HAS A GREEN BLACK RED AND WHITE WIRE COMING FROM THE FLEX OUT OF THE BACK OF...
Green and white from the oven go together and connect to the copper from the box, red goes to white and black to black. Be sure that it's 220 breaker your connecting to, for an oven it should be a 40 amp breaker, sometimes thirty
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Oct 09, 2013 | Fisher and Paykel Washing Machines
How to get 220 from breaker box
You are measuring in the wrong place! If you have a double breaker in the circuit breaker box, measure the voltage at the dryer outlet. You should have 110, 110, 220 at the different terminals.
If that isn't the case, then replace the circuit breaker (assuming that you have the right input voltage into the house)
Jan 01, 2012 | Dryers
I have a wood planer with a 3HP 220 single phase motor wired to 20amp circuit breaker in my house. I usually run the planer off a 12gauge extention wire about 30ft from the house plug. I would like to...
Look on the planer to see what the R.L.A. are, for example 16.0 amps. Set a box with 2- 20 amp fuses, or a double pole 20 amp breaker. Do not exceed the amperage of what the planer says on its data plate. If the R.L.A. is 10.0 to 19.3, use a 20 amp.
Sincerely,
Shastalaker7
Jan 20, 2011 | Inline 20 amp. In-Line Circuit Breaker
Electrical issue...220 dryer outlet problem
ok start at the pannel is there a double breaker there
usually a 30 amp two pole breaker this is how a pannel works first breaker pulls 120 off of one side of pannel second breaker pulls off 120 off the other side of pannel if you look the buss bars you will see that they interchange from one side of the pannel to the other so at the breaker you are checking make sure you have 120 v on output of one half of breaker and 120 on second half of breaker when you use a volt meter put one side to gng the other side to wire comming out of breaker you should have 120 on both sides if not you have a bad or tripped breaker
Apr 24, 2010 | Hammering
We recently moved and now the oven and stove temp does not go as high as it is supposed to....we had to put in a 220 line as there was only a gas line ......
You say you put in a 220 volt line, I'm afraid it must be miswired. If you did this yourself, carefully check your work., particularly where you wired into the breaker box. When wiring, Black and Red both go to the double-pole breaker, white to the neutral buss, and green to the ground buss. The wire used should have these colors and be 10ga. or larger. Or consult an electrician
Nov 15, 2009 | Kitchen Ranges
Admiral wont heat
Your breaker in the breaker box has a double pole breaker for the stove one breaker is shot so you still have 120volts which runs the lights 240volts for the elements.Turn main power off and replace the breaker. To verify for sure pull the stove out and unplug it check power at the plug you need 240volts at the plug. If i dont have a plug and wired straight in disconnect the wires and check the wires.
Sep 01, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Installing a 220 circuit breaker
First you must have space for a double pole 30 amp breaker in your panel.
Otherwise is is almost the same as the one you installed before, exception is 2 hots both going to the breaker.
The green goes to ground. The white goes to neutral. The black and red go to the breaker.
Mar 13, 2009 | Whirlpool LER5636P Electric Dryer
Trying to install a 30 amp breaker into a ge powermark gold 200
Hello, First, you need to determine if you are installing a 220 or 110 vac circuit breaker. The 220 is a "double pole" and will have (on the underside) 2 tabs for each 110 phase on your breaker box. It will also usually have a double switch tied together. A single or 110 breaker will just mount to one of the "hot bars" on the breaker box. Again, look at the underside of the breaker. Just remember you need 2 wires (usually a black and a red) for 220 and only one wire (usually black) for a 110 single. The neutral shouls tie to the neutral bar on the box (where all the white wires are connectoed to)
Of course, use extreme caution and insulating gloves when working on a circuit breaker.
Hope this helps and good luck with it. Gary
Mar 12, 2009 | Electrical Supplies
How do I wire up a F2544 baseboard heater with 220 wire?
in a 220 setup you don't use the white wire. just your other ones. just wire nut it off
Sep 12, 2008 | Fahrenheat Electric Convector Baseboard...
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
