Question about LG Flatron L1919S LCD Monitor
Display rotated 90° to the left. I don't remember doing anything in particular that might have caused this, there are a number of buttons (5) on the right hand-side of the screen that I might have pushed but I tried using them to straighten the picture again, without success. How do I correct this?
    Brigadier General:
  • 7,191 Answers
To restore the display to the original upright position, kindly press these three key together on your PC keyboard :
CTRL, ALT , UP arrow key (See attached image)
Hope this helps. Thanks for using FixYa.
Posted on Aug 30, 2010
Testimonial: "I must have wasted more than an hour trying to solve this. Why didn't I think of you earlier? Now I'm a fan. Thanks a bunch."
I put new rotator button cap and plugs and wires and I'm getting codes saying it's misfireing
Is this a 99 Honda accord?
Just about anything can cause a miss-fire, check fuel--spark--compression.
What were the code numbers, does it point to a particular cylinder?
Apr 08, 2017 | Cars & Trucks
My computor monitor is side wasy
Try the following key combination in order to rotate your display back to normal:
Press and hold down the CTRL button on your keyboard.
Then also press and hold down the ALT button at the same time.
Then finally press the UP ARROW key while still holding the other two keys down.
Pressing that particular combination of keys but with a different direction ARROW button is probably how you rotated the display in the first place.
Otherwise you will have to look in your CONTROL PANEL.
Then DISPLAY.
Then SETTINGS.
Then ADVANCED.
Then look in there for a ROTATE DISPLAY option.
I hope that was helpful Patsy.
Good luck and take care.
Joe.
Dec 09, 2011 | Computers & Internet
Battery went dead radio security kicked in and i don't have the code
I'm hoping that you are in the states, because I have a free stateside number that you can call. Here are a full set of instructions to get you sorted out:
If it says "OFF" turn the key to ACC for 5 minutes with the radio on, and displaying "OFF". After 5 minutes the radio will turn itself off. Turn the key off then back on again. The radio should now display "CODE". If this doesn't work disconnect the battery for 5 minutes, and repeat the 5 minutes radio on displaying "OFF" with key in ACC until the radio turns itself off. Now that it says "CODE" go to step 2. The radio must display "CODE" to enter unlock code.
  • 2 Find the radio serial number The radio's serial number is on the left side of the case that is inside the dashboard. You will have to remove the fascia that is around the radio carefully to reveal it. In most models you can use a small dental style mirror to see the code without completely removing the radio. If you can't see it this way you will have to take it all the way out. Don't disconnect anything just pull it out far enough to see the numbers. The model number starts with MNxxxxx, this is not the number you need. The serial will be an 8 digit number, no letters. It will be close to the model number however.
  • 3 Now that you have your serial number call Mitsubishi Motors of North America at 1-888-648-7820, M-F 7am - 4pm Pacific time. They will give you your unlock code for free.
  • 4 Now that you have your unlock code you have to enter it into your radio. They should take you through this on the phone, however, here's how:
  • The 1,2,3,4 preset buttons on your radio toggle up only through the digits 0-9. The 1 preset button is the first digit holder, and so on for the 4 digit code. If you go too far just keep pressing the button, and it will go back to 0, and you can get back to the right number. If your unlock code has a 0 in it you have to press the button once to get to 0. It starts with a dash (-). This doesn't count as the 0. For instance if your unlock code is 0873, you will press preset 1 once, preset 2 9x, preset 3 8x, and preset 4 4x. Once you have the correct number in the diplay press the "CD" button, and it will unlock your radio. If you didn't do it right, it will display "ERR1" before going back to the "CODE" display. Don't mess up more than twice. After the third failed try things get a lot more complicated!
    Aug 09, 2011 | 1998 Mitsubishi Eclipse
    E27 and e95 code
    I had this problem. I tried to interupt a cycle just after it started and then couldn't start the cycle again, with the E27 code coming up.
    e27 refers to a problem with the door locking mechanism which could be due to a number of causes. The problem I had was with the solenoid in the door, not a genuine problem with the door latch mechanism.
    Here is how I fixed it:
    (1) Set knob to off
    (2) Hold down spin selector and Allergy rinse buttons and turn the knob to the LEFT (right does not work)
    (3) The display then shows a number of program codes P01 to P14. (Pressing spin selector rotates through the codes).
    (4) Press spin selector until you reach P02 on the display, then press the start button, the door will click and the machine will begin a cycle.
    (5) Turn the knob to OFF, and then you should be able to use the machine as normal.
    Jul 18, 2011 | Bosch Nexxt 300 Series WFMC2201UC
    Screen display is sideways
    Hi all5r_mine,
    Based on your situation. I suggest trying the following options:
    Upside Down or Sideways Monitor Display
    Problem Description:
    The user accidentally pressed a keyboard combination that turned the entire monitor display upside down or sideways. The user cannot recall the keyboard combination that caused the problem and has no idea how to rectify the display.
    Possible Solutions:
    Some graphics cards have rotation "hot keys" enabled by default and this is probably the most common cause of this problem. The exact procedure for rectifying the display may depend on the particular brand and configuration of the graphics card in the problem computer. One of the following options may help resolve the issue.
    Option One:
    Try using the keyboard combination, "Control + Alt + Up Arrow Key". Control + Alt along with one of the arrow keys is a fairly common rotation hot-key configuration and may just do the trick.
    Option Two:
    If Option One doesn't work, see if there is a graphics card icon displayed in the Notification Area (near the Windows Clock). Clicking (or right-clicking) the icon may reveal a "Rotation Settings" option that will allow you to revert to "normal" display.
    Option Three:
    If neither of the previous options help, try the following procedure.
    1. Right-click an open area of the desktop and click "Properties" to open the "Display Properties" window.
    2. Click the "Settings" tab and then click the "Advanced" button to open the monitor settings window.
    3. Click the tab corresponding to your graphics card. You may need to click one or more buttons within the tab to reveal a rotation settings option. Exactly where rotation settings are located will depend on the brand of graphics card installed.
    4. Once you locate the rotation settings, choose the "0 degrees" or "normal" option to change the display to upright. The rotations settings may also give you the option of disabling rotation hot keys so that the problem does not happen again.
    5. Click "OK" to save changes and exit out of any open properties windows.
    Navigating through menus and choosing options when the display is abnormal is difficult but certainly not impossible.
    Hope it helps.
    Please rate this solution if found useful.
    Best regards,
    Reyjoshua07
    Jan 17, 2011 | Acer Computers>Laptops Aspire 5610-2013 PC...
    Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
    have Aiwa TV MODEL No. TV-A209
    Its stuck randomly on a particular channel that I was watching at that point of time.
    Along with that channel it now shows a message in flashing red color that reads :-
    AGING
    O6895H
    Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
    S123 K234 Y
    000 001 1
    The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
    I really don't know anything about this. So, please help me out of this problem.
    Nov 08, 2010 | Televison & Video
    Cannot remember my code to unlock my samsonite breifcase
    Turn your suitcase upside down. At this position all your numbers look upside down. Now with the help of a torch light you should see a small gap above the rotating thing (the one with which you change your number) Take the first rotating thing and rotate from 0 to 9, at some particular number you can see a small hole inside the small gap which I have mentioned before. Do the same for the next 2 rotating thing.
    When you are done you can see the small hole(a tiny spring like material is seen in the hole) in all the three small gaps.
    Now you can open the number lock.
    Jul 09, 2009 | Samsonite Tripod
    CD player won't play after pressing the play button on all tracks
    This problem is usually caused by dust or smog accumulating on the laser lens assembly. Unplug the unit and remove the top cover. Take a cotton swab and wet one end with glass cleaner. Wipe it gently across the lens (do not apply pressure). Use the other end of the swab to dry the lens. Reassemble the unit and test for skipping or non-playing discs.
    Feb 02, 2009 | Audio Players & Recorders
    Inadvertently rotated display
    The solution was easy. Press [CTRL, ALT, up arrow] simultaneously and the display goes back to normal.
    If anyone knows why CTRL plus left click (and CTR plus right click, for that matter) rotates the display I would be curious to get the information.
    Jul 01, 2008 | Logitech 9311570403 Mouse
    Need an owners manual
    to set the 5 main presets:
    with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
    to set the 5 additional presets:
    with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
    to set the digital clock display:
    with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
    Apr 05, 2008 | GPX HDT4004SP AM/FM Radio
    LG Flatron L1919S LCD Monitor Logo
    125 people viewed this question
    Top LG Computers & Internet Experts
    Alun Cox
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
