Question about iRobot Roomba 4210 Bagless Robotic Vacuum
L purchased a roomba from canadian tire in canadargvidcab3 black last december what is the warranty it keeps dying after 15 mins
    Problem Solver:
  • 28 Answers
Poor or faulty battery. Also, make sure that the gear box is free from debris. If the gear box is clogged, your Roomba will drain its battery.
Posted on Sep 25, 2010
I have bought HOOVER 20 VOLT cordless vacuum cleaner from Canadian tire 15 days ago .while using the machine ,it stops suddenly .why ?
Don't take it apart as it should be under warranty Take it and your receipt back to the store where you bought it. Get your money back or it replaced.
Feb 07, 2017 | Hoover Vacuums
Room a 620 keeps stopping
It could be clogged with hair (when was the last time you cleaned it out?), it could be the battery isn't holding a charge any longer. It could be getting caught on something . How long is it running before stopping? I found I used to get about a two hour run from my Roomba, before the red light flashed. Then I started to unplug the charger and Roomba when it had a full charge and it wasn't needed. I noticed that after this the Roomba didn't run as long, maybe one hour, before needing a charge again. I leave it plugged in all the time now.
Jul 07, 2014 | iRobot Roomba 560 Robotic Vacuum
Why won't my Roomba start when I press a green "clean" button?
Bad PC board. Throw it away. Robot vacs are nothing more than novelties ( expensive toys ) They may do what you want them to do at first but they never last very long and other than brush replacements they are not repairable. If it is within the warranty period you can get a replacement with that.
Jul 01, 2017 | Roomba iRobot 630 Vacuum Cleaning Robot
Robot runs for about 5 min. then says clean brushes. brushes do not turn
The dust build up in these Roomba's do create a problem in all operating phases
Keep in mind if taken apart every 6 months and cleaned inside they will operate like they should
Jul 03, 2010 | iRobot Roomba 560 Robotic Vacuum
My irobot (Roomba)is only working for 10 mins then
It should take about 6 hrs to charge. I had the same problem and reset the charging circuit. 1) Charge it until the green light comes on. 2) Unplug and pull battery out. 3) hold down the power on button 15-30 seconds. 4.) Put the battery back in, plug in the charger (direct - not through the dock) and charge for 72 hrs. Then, run at Max clean until the "I'm dead" tune plays.
May 12, 2010 | iRobot 4150 Roomba Vacuum
I have the irobot roomba and the battery does not hardly hold a charge and now it won't go forward just backwards and around
The Roomba has a rechargable Battery. The Roomba battery like any battery will eventually ware out after so many charges and discharges. Mine lasted about three years and then is would hardly hold a charge. I purchased a new battery and then it worked fine after that.
As for not going forward. That is usually due to a dirty bumper sensor. You have to take the Roomba apart for cleaning that. You can take it to Sears and they will do it for you.
Oct 01, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
I bought Roomba 560 robot vacuum cleaner about 3 weeks ago and it has been cleaned without problem all kind of positions of floors (also carpets) Last friday I anyway mountained nearby of outcoming door...
Roomba won't clean black carpet because it interprets it as a cliff. The sensors under the bumper tell the Roomba that it's about to fall down the stairs and it backs away. Unfortunately, because they're a safety feature, they can't be shut off.
Aug 18, 2009 | iRobot Roomba 560 Robotic Vacuum
IRobot Roomba going in circle and quits
you need to turn roomba over, leave the battery in, push the wheels at the same time 15 times. after that, push the front bumper about 15 times. then turn on roomba and press clean.
Feb 08, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Battery charge
Dave you are correct. You should never over-charge anything like a Roomba, Cel Phone, etc. That will kill a bettery very quickly.
Jan 11, 2009 | Roomba Robotic Floor Bagless Vacuum
Roomba 4200 Scheduler
The best for the battery if (NiMH). Discharge completly, than charge full (charge more even the charger indicates full charge)
Clean every part, maybe a hair slow down the wheels and thats why need more power.
Here some tip from the web:
With proper care, one iRobot Roomba battery can last for hundreds of cleaning cycles before you need to replace it. Here are some things you can do to extend Roomba's battery life and keep Roomba cleaning at peak performance:
Use your Roomba frequently. Your Roomba is powered by a rechargeable nickel metal hydride (NiMH) battery, which lasts the longest when you use it regularly.
Keep the brushes clean. If the brushes and brush axles get clogged with hair and other debris, your Roomba will strain to spin them, using more battery power than normal. In extreme cases, the battery can even be damaged. See How to remove and clean Roomba's brushes
Keep your Roomba plugged in when not in use. If you have a Home Base®, keep your Roomba docked in the Home Base and plugged into the charging brick. If you don’t have a Home Base, keep your Roomba plugged into the APS Fast Charger.
Make sure you are charging your Roomba correctly. When your Roomba is plugged in correctly, the solid green light should be illuminated on the charger or on the Home Base.
Plug your Roomba in as soon as possible after using Max Mode. Leaving your Roomba unplugged for more than 24 hours can damage the battery.
Place your Roomba and the Home Base on a smooth, hard surface when yourRoomba is plugged in. Make sure your Roomba and the Home Base have plenty of space for ventilation. Do not charge your Roomba on a carpet or rug.
Charge and store your Roomba in a cool, dry place. Keep your Roomba out of direct sunlight and away from sources of heat such as windows, radiators, heating vents, and large appliances.
Remove the battery when not using your Roomba for a long period of time. If you will not be using your Roomba for more than a few weeks, fully charge the battery, remove it, and store it in a cool, dry place. When you want to use your Roomba again, insert the battery and fully charge it. Leaving your Roomba plugged in for weeks when it is not being used can damage the battery.
You can purchase a second battery or replacement online at the iRobot Store.
Nov 11, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
iRobot Roomba 4210 Bagless Robotic Vacuum Logo
55 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
