The display scree is flickering. I have removed the battery and refixed it but the problem persits
    Scholar:
  • 166 Answers
Please connect an external monitor. If the screen still flickers then it is your video graphic adapter is the problem, on the other hand, if it does not occur then its your LCD hardware which can be the LCD itself and hopefully its just the flex cable that connects to your notebook. Please let me know of the outcome and maybe there would be a need to assist you further. Thank you and regards.
Posted on Aug 30, 2010
Polder kitchen scales light flickers after batteries changed
This was suggest by TWC42 on Amazon. I tried it and it worked. Had the same issue with mine. Here's a fix that might work. Set batteries aside. Remove the 6 screws from the back with a small phillips. Lift off the back. Remove the 5 smaller screws holding the display in place. Insert the three batteries. If the display now shows a number without flickering, do not remove batteries. Carefully replace display, reinsert five screws. Place back on, reinsert 6 screws. Turn over, see if off/on works. Mine did!
Feb 28, 2012 | Health & Beauty
Totally off
Check power in socket. If power switch on by remote. If not working, remove battery and replace new battery. And also check power in PCB board. if power, Switch power and remove DC wire to display in the indoor unit.and then refix again. Now, check again with remote. If still problem, PCB defective. replace it. Thanks.
Mar 09, 2011 | LG Art Cool LA181CNW Split System Air...
Mazda 626 2000 - warning lights for ABS, TCS
what u do to stop the vehicle and remove the battery head and refix,if the problem still persits go for thorough scanning.
Mar 25, 2010 | 2002 Mazda 626
Panasonic NV-DS65 500x it gives power red flicker
This is not the problem with that battery. That battery is using for the clock & date memmory. From your question not clear the problem. First you check the flickering condinously or after two or three or some another numbers flickering then giving some intervel then it doing again.
Any way I can give u a solution. Open the black cover remove the flex cable which is connected in between mechanisum and main P.C.B. & remove another flex cable which is connected capston motor & main P.C.B (which is big flex cable just closed to tripod fixing hole. Then clean with sprit & cotton bud. After five minute refixed it again. Mostely it should work. Try this if the problem is not solved tell the details of the flikering of the red light
K. R. Rajan
Dec 21, 2009 | Panasonic NV-DS65 Mini DV Digital...
Year old advent netbook 4211b will not turn on,
When you press power button press F1 or F2 or "del" key if you can see bios screen then you not need to refix RAM memory or reset bios.
IF you can see bios screen then lake sure harddisk is detected and SATA is disable then save settings and exit.
Also when you power up press F8 key if you able to see safe mode and other menu then you have change screen resolution enter in enable vga mode.
Then open control panel and display then change scree resolution to 1024*768.
Then apply and ok.
But if you can't see bios screen or nothing in dispaly then you have to refix RAM memory .
Check in back side there is 1 plate open it then refix RAM memory.
If still not get display then open back cover of laptop then find motherbord on it then pull cmos cell for 10 minutes so all settings go to defaults then again refix cmos cell then check.
Let me know if you need more assistance.
Thanks.
Oct 08, 2009 | Advent Netbook
No Display
you neeed to refix battery and RAM.
Jun 23, 2009 | Acer Aspire One PC Notebook
Power supply Problem
hi,
Might be the issue with display panel cable as well so please first try to refix it.
May 29, 2009 | HP Pavilion dv1000 Notebook
Flickering screen on startup
Sounds like hardware. Several possibilities come immediately to mind:
1) Backlight is going bad. (It's a fluorescent light).
2) Bad inverter
3) Loose or bad cable in laptop hinge
If the picture is OK using an external monitor, it's probably one of those three.
I've used these guys before for screen repair: Unknown document title.
http://www.notebookmechanix.com/
Feb 06, 2009 | Acer Aspire 3003LCi Notebook
Computers & Internet Logo
David Payne
David Payne
