Question about GPS
Switching on I have a tomtom one series3 but it wont switch on ,have tried reset but still wont switch on
  • tailboard May 09, 2008
    no card to remove all built in
  • 515 Answers
Well, first try this:
http://www.tomtom.com/support/index.php?Language=1&query=start&FID=6965
If no avail, remove sd card, clean contact surfaces, reinsert sd card, and try again...
Posted on May 08, 2008
Tomtomone stuck with frozen screen and wont switch off can switch off using the reset button but when switched back it sticks on the tomtomone screen
Your TomTom home software is corrupted:
1) Try a 'hard reset': while the power is on, stick a small (tooth/match) stick through the hole under your unit base and opposite to were the USB connector go, for a few seconds, remove the pressure on the stick will cause a complete system reboot if possible.
2) Check the health of your Tomtom One flash drive: connect to the computer, use Windows Explorer -> Properties -> Tools > Error-checking to scan and repair any problem.
3) Restore software: using TomTom Home, restore from a previous backup followed by a device update while connected online.
Hope it helps: let me know how you go and good luck!
Jan 06, 2010 | Tomtom ONE GPS Receiver
Tomtom wont start
try resetting it by putting a pin in the reset switch (usually next to the memory card) for 15 seconds, hopefully it will restart, good luck
Aug 26, 2009 | Tomtom ONE 3rd Edition GPS
Hi my tomtom 910 go wont switch on ], but when useing the charger the little green light lights up and will stil not switch on ive tries the hard resetting and does not work
I've had a similar problem on 2 TomTom 910s.
First, try holding in the reset button while holding the power switch down for 5 seconds.
If that doesn't work, let it charge for 12 hours and while it's still charging, hold the power switch down for 5 seconds.
It worked for me on both
Good luck
Jun 07, 2009 | Tomtom GO 910 GPS Receiver
My tomtom go 910 will not switch on it has the green light on at the top left when plugged into a charger but nothing turns on when pressing button for 2 seconds any ideas??
In general I find these sort of problems can be fixed by the below
If the Tomtom loses battery power it might cease to function with a blank screen but will show a green light when you charge it. The trick is charge it on the mains charger for at least two hours. Then reset the device with a paper clip. If you get no reponse hold down the on button for at least 20 secs and the device will show the Tomtom logo and play a drum roll and startup normally.
Sep 03, 2008 | Tomtom GO 910
Tomtom go 910
I have seen the green screen problem a few times before and this was caused by corrupted data / software or an error in booting up.
If you can't turn any TomTom off then perform a reset by inserting a paper clip into the rest hole and give 1 short press of the reset button ( it's a tactile switch so you should feel it click ) then try switching the TomTom on again the normal way. ( reset buttons are normally found through a small hole underneath the TomTom ).
If the TomTom does switch on but continues as before with the loading up problem , then it's best to format and reload all files from your backup copy.
A RED CROSS indicated a loading fault / corrupted files / incomplete files / corrupted or damaged media . ( media , meaning SD card or hard-drive )
Aug 05, 2008 | Tomtom GO 910
Tomtom wont switch on
its underneath there is a semicirular hole, you need a paper clip to reset
Jun 22, 2008 | Tomtom GO 700 GPS Receiver
Tom Tom 1 Wont Switch On
Well, dont know if you already have tried, but do a reset:
http://www.tomtom.com/support/index.php?Language=1&query=reset&FID=6965
Please follow instructions.
(Please remember to rate, thanks...)
Apr 14, 2008 | Tomtom GO 300 GPS Receiver
710 unit wont switch on again?off. 4 hour latter tried to turn it on again but does not switch on. Battery is charged but still not switching on?
Found the reset switch on GO 4V00.710 - look underneath, where the unit docks - small button - need a paper clip to press
Also, reset switch is documented in the Quick Start Guide - see label 'F' in the 'Your TomTom GO' what's in the box.
Dec 09, 2007 | Tomtom GO 700 GPS Receiver
Tom tom 300
"My tom tom wonts switch on. I have reset it and still it comes on with a boom boom noise and shows the 2 hands on the screen. It also shows the loading bar at the bottom, but then it just freezes and nothing happens. can anyone help please ASAP"
Sound as though your Map data card is corrupt. Remove the SD card and check it with your computer using a card reader. Backup the SD card onto your computer. You can run either chkdsk or go to the drive letter under 'My Computer' right click and select properties, then tools, then check now. You can also try starting the Tomtom with the SD card out of the unit. It should show a picture of the Tomtom with a 'X'. You can also try copying the data on the SD card to another SD card.
Sep 12, 2007 | Tomtom GO 300 GPS Receiver
GPS Logo
59 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
