Question about Omron Automatic Blood Pressure Monitor Options Large Adult Cuff Fits Arms 13 To 17
Omron 780 My machine registers readings that are all over the place and incorrect. ie. the reading will be 150/80 and two minutes later might be 90/84 and then 65/100 My blood pressure in the doctor's office is usually about 130/80 so my machine is obviously not working. Is this the callibration? How do I fix it? I haven't tried anything as I don't know what to do. thank you MS
    Top Expert:
  • Omron Master
  • 21,384 Answers
Check the batteries.
Posted on Aug 04, 2017
5 Suggested Answers
r321567499
  • 74 Answers
SOURCE: inaccurate reading
I'm not sure why you need it calibrated if your Docotor says it's accurate but here is a web site link....
I hope this helps.
http://www.omronhealthcare.com/product/s1-1126-186-manual-monitor
Posted on Dec 25, 2008
Max J
  • 22 Answers
SOURCE: Manual for Omron HEM-780 Automatic Blood Pressure Monitor
Get a manual at :
http://www.omronhealthcare.com/product/manuals.asp
Posted on Sep 07, 2009
  • 6 Answers
SOURCE: Have Omron 780 Blood pressure monitor. 9 times out
It appears you may have a leak in the cuff. This will need to be verified by an authorised service facility. Contact OMRON they should be able to assist you.
CONSUMER SUPPORT TOLL FREE NUMBER: 1-877-216-1333
Customer Service Representatives are available
Monday through Friday - 8:30am to 4:30pm CT
Posted on May 07, 2010
  • 4736 Answers
SOURCE: My Omron HEM-780 needs to
Recalibration normally has to be done by the manufacturer. As they have to certify the calibration. Keep in mind, that it is not unusual for your BP to read a bit higher at the doctor's office, than it does at home. It's sarcastically called "White coat hypertension." Which translated means, your blood pressure rises a bit at the doctor's office due to anxiety. Or it's being taken at a different time of day, than you take it at home, in a relaxed atmosphere.
Hope this helped you.
Posted on May 16, 2011
Blood pressure monitor readings too low, inaccurate
I have used Omron monitors for around 2 years now and I have not found any problem with it. The error may be because you went to the doctor, your blood pressure must have changed since there was a time gap. There is no need to get worried.
Sep 05, 2012 | Omron Latest Model HEM-780 Automatic Blood...
I just put new batteries in my Omron HEM-780. Doesn't work. When it finishes deflating it always says E7. What's going on?
Hi library336
The Omron HEM-780 generally has 5 Error Messages:
1]
ERROR MESSAGE: A single (E) Error message indicates movement during the measurement process, resulting in an inconclusive reading or the absence of a Blood Pressure or Pulse reading caused by a weak Arterial Pulse.
SOLUTION: Remove the cuff. Wait 10-15 minutes. Repeat measurement using approximately 40mmHg more pressure than in the previous measurement.
2]
ERROR MESSAGE: A Double (EE) Error message indicates an under-inflated cuff. Remove the cuff. Wait 2-3 minutes.
SOLUTION: Repeat measurement using approximately 40mmHg more pressure than in the previous, under-inflated measurement.
3]
ERROR MESSAGE: An E directly below another E Error message indicates an over-inflated cuff (in excess of 300 mmHg). Remove the cuff.
SOLUTION: Wait 2-3 minutes. Repeat measurement using approximately less pressure than in the previous, over-inflated measurement.
4]
ERROR: A Blank Screen indicates low or depleted batteries.
SOLUTION: Remove and replace all 4 AA Batteries. Do not mix used and new batteries.
5]
ERROR MESSAGE: An (Er) Error Message indicates an abnormal memory function caused by a faulty internal component.
SOLUTION: Call Omron Customer Service, Toll Free, on (in the USA) 1-800-634-4850 (or on the equivalent Toll Free or Freefone Number in your country).
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 15, 2011 | Omron Health & Beauty
I WANT REMOVE OLD READINGS
...here's the simple solution from Omron themselves: just turn it on, hold the memory 'down' button until it starts scrolling thru all the past readings, then press n hold the start button until you see three dashes across all displays...this should take 2-5 seconds...enjoy!
Jul 19, 2011 | Omron Latest Model HEM-780 Automatic Blood...
More frequently my Omron HEM-780 seems flaky. It would apply pressure and count up to 112-120 then start deflating, then inflating, etc. Then it would count down by units and end up displaying E. It would...
Part of the problem may the the placement of the cuff. Generally, if it's not placed correctly. the cuff will re-inflate trying to find the correct stopping point for inflation. Any movement of your arm could cause this. Also, if you haven't replaced the batteries lately, you should do that. Also check to make sure there are no air leaks in the rubber tubing or the cuff. Check your Owners Manual for the exact placement of the cuff.
Feb 07, 2011 | Omron HEM 780 Automatic Blood Pressure...
I want to clear the memory on my omron hem 780
...nope, taking out the batteries won't help...here's the simple solution from Omron themselves: turn it on, hold the memory 'down' button until it starts scrolling thru all the past readings, then press n hold the start button until you see three dashes across all displays...this should take 2-5 seconds...enjoy!
Aug 20, 2010 | Omron Latest Model HEM-780 Automatic Blood...
Omron hem 780 how do I erase the memory
May 01, 2010 | Omron HEM 780 Automatic Blood Pressure...
Have Omron 780 Blood pressure monitor. 9 times out of 10 I get an E and no BP reading. What could be wrong?
Apr 20, 2010 | Omron HEM 780 Automatic Blood Pressure...
Cannot switch user
first take the blood pressure and once it has read your pressure then push the button to which user you want the pressure to remain on either A or B.
Jan 13, 2009 | Omron Latest Model HEM-780 Automatic Blood...
Reset the tru-read mod
I had a hard time setting this too.
You have to press the "set" button while the unit is OFF not on.
Dec 14, 2008 | Omron Latest Model HEM-780 Automatic Blood...
Omron Automatic Blood Pressure Monitor Options Large Adult Cuff Fits Arms 13 To 17 Logo
Top Omron Health & Beauty Experts
Maxumized
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
