Question about Sewing Machines
Monogramming problems We begin the monogramming process and at the 45th stitch the machine beeps and says the thread has broken, but it has not. What could cause this? We re-threaded and checked to make sure there was no loose thread in there with the bobbin.
  • monogrammom May 17, 2008
    I have the same problem. No one that I have talked to seems to know what causes this. We have gone thru recalibration....didn't work. I was told they reset a sensor...didn't work. The stitching is fine, but it takes longer and is very frustrating because the machine keeps stopping for the false alarm.
    Scholar:
  • 41 Answers
Hi Stacbac & Monogrammom,
Could be a number of causes - below are a few to consider:
  1. a loose thread in the path of the sensor (in most cases, the upper thread break is triggered by a sensor in the upper thread path of the machine)
  2. a rough spot in the upper thread path that's catching the thread, causing it to not feed smoothly and trigger the sensor incorrectly
  3. a sensor gone bad (that still does not work when reset)
  4. a computer board gone bad (rare but possible)
Your specific machine models will dictate where the sensors are located. If you can see the sensor, look around it to see if a loose thread is the culprit. Feel the upper thread path parts of the machine for any rough spots (those you can get to at least). Rough spots can be smoothed - best done by your dealer if your machine is still under warranty or you're uncertain how to accomplish - but if you're very familiar/comfortable with machine repairs and have used an emery cloth you may be able to smooth small rough areas yourself.
Beyond blowing out any fuzz (canned air or a small air compressor) if a sensor or computer board is bad, a reputable dealer will need to take care of the problem for you (generally one who sells your brand machine as they will be able to get the parts and install them properly).
Not a perfect answer (not knowing specific machine models) but hopefully this will help you narrow down what's happening.
Happy sewing,
Kim & Linnette
Posted on Jun 27, 2008
I've rethreaded my 634d overlocker, and now it wont sew properly, its bunching up the threading behind the needle?please can someone help
Most often, the problem exists in the threading process. Try removing all the threads from the machine and rethread from beginning to end in the order specified. Any deviation with one of the threads may cause the machine to not stitch properly.
Nov 16, 2017 | Sewing Machines
I have bought new needles for my Riccar overlocker now the stitching is loopy and messy
Verify you are using the correct needles for your machine. Some needles vary by a fraction of an inch but will make a big difference in serging success.
Remove all the threads from the machine.
(Always cut the threads below the spools, raise the presser foot, and pull the threads DOWN through the needles--Never pull up!)
ALWAYS RAISE the presser foot when threading.
Be sure to always thread each thread in the proper order--threading out of order will usually fail.
Rethread from the beginning and give each thread an extra little tug when threading the tension disk.
If a thread breaks, it is usually less frustrating in the end to remove all the threads and rethread from the beginning. Trying to rethread a broken thread will most likely cause problems.
Apr 25, 2017 | Riccar Sewing Machines
Top thread keeps coming out of needle. How do I thread top thread?
Be sure to pull at least 4 to 6 inches of thread through the needle's eye before beginning to sew. Pull the bobbin thread up to the top of the fabric BEFORE beginning to sew.
How and Why to Bring up the Bobbin Thread (This works for regular everyday straight stitching too not just design stitches.)
Then, BEFORE taking the first stitch, hold both thread tails with the left hand and then slowly begin stitching. After a couple of stitches, let go of the thread tails and continue to sew.
If you need instructions on how to thread your machine, search the internet for a manual:
Make + Model + the word "Manual"
or look for videos on YouTube to help with the threading process.
Jan 30, 2016 | Sewing Machines
Husky lock 936 cover stitch troubleshooting
try a new needle
try rethreading that one needle
rethread the looper
if that doesn't help, then the machine may have a timing problem and would have to be checked
Jun 10, 2015 | Husqvarna Huskylock Computerized 936
Sew for three seconds and it stops and beeps four times. I have changed my needle and made sure it's in correctly, i cleaned out the area under plate (only one month old), checked thread and thickness of...
Some sewing machines are extremely finicky about the direction the thread feeds from the bobbin. I had one machine that didn't care which way the bobbin fed and another that would stop after 2-3 stitches and protest. You could try flipping the bobbin and see if that helps.
Feb 03, 2018 | Singer Curvy 8770 Electronic Sewing...
I bought the SINGER FUTURA XL400 in august. It sews,monograms an embroiders. Sews like a dream with no issues. The monogramming part has me at my wits end. It skips stiches, leaves big loops an looks bad...
Be sure to install a brand new sharp needle before sewing. Check that the needle, thread, and fabric are compatible. An embroidery needle or top stitch needle may help.
When threading the top thread, ALWAYS RAISE the presser foot before threading to insure the thread seats in the tension disk.
Apr 08, 2017 | Singer Futura Xl-400 All-In-One Sewing And...
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
Embroidery machine not pulling top thread on 385.19000
White on top means that the top tension isn't right some how. Now that can be because it wasn't threaded properly with the foot in the up position... or it could mean that you've got the little thread catcher **** on your spool catching the thread and causing problems. Sometimes if it catches it will wind a few layers of thread around the thread spindle the spools sits on. That isn't readily notice until you get mad and pull the spool off.... and finally see it. LOL
Carefully examine the path of the upper thread too.
Good luck.
Aug 19, 2012 | Kenmore 19001
Machine is threaded correctly on both the bobbin and top.I have followed the manual step-by step and tried suggestions from other users. The machine will stitch about 2 inches and then beeps. The thread...
It sounds as if you have tried all the usual fixes so it might be a problem with the actual circuitry causing this. I'd take it into nearest Singer the sewing machine dealership or shop where you bought it and ask them to service it (or if still under warranty, for them to diagnose the fault).
Jun 11, 2011 | Singer CE-100 Futura Computerized Sewing...
Beep sound on Kenmore 19233 sewing machine
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develop in the threading process and you are able to sew a few more stitches before the beeping starts again.If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. If it continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house.
Nov 05, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
