Question about HP Photosmart C7280 Printer
Carriage jam. ?get paaper out - HP Photosmart C7280 Printer
  • 1,218 Answers
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
http://www.fixya.com/support/t5821600-carriage_jam_open_door_clear
Posted on Sep 23, 2010
I'm getting an error msg and can't print. It says please fix cartridge jam and hit enter. I can't find any jam. What do I do?
If there isn't a cartridge jam then it's probably a carriage jam:
However, I'm not too familiar with clearing a carriage jam. I just know that if your cartridges are not blocked then the carriage is likely at fault. You will need to Google this on how to fix a carriage jam.
Jan 24, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
The printer indicates out of page. Load paaper the press OK. I have paper loaded in the printer and only on the first page i will get the indicated out of page. Once I press OK the system the printer...
The pick up rollers are dirty. You need to clean them with a damp cloth. These rollers should be just above the leading edge of the paper when loaded.
Dec 23, 2010 | Office Equipment & Supplies
I have a paper jammed in the printer and I cannot get it out.
Normally the paaper gets jammed into the rollers and the drives and could be easily released if you can use the copy keys to forward the drive.There could be also paper lodged in the feed rollers or the inner roller could have jammed into. If so you will have to release the holding screws of the roller and remove off the paper. If the dispaly is showing paper jammed there is also the possibility that the paper detect in optocoupler sensor is faulty. If so check and replace this which is found at the paper feed on. Once the display shows a release the printer should work . Hope you try out. Good day
Jul 05, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Paper jammed.visible when front opened.paper past roller about 5 cms. Will not pull through
you have paaper in the fusing roller.
Pull out the cartridge and loose 2 screws to take off the plastic fusing protection.
Turn the whell, and the paper get off... i hope.
Else, take off the fuser and release the springs to take off the paper.
Nov 17, 2009 | Canon FAX-L200 Plain Paper Laser
Carriage jam
Usually when the printer displays a carriage jam error the carriage assembly is jamming along the carrige path.
There may be something in the carriage path or the carriage shaft may need lubricating.
Check the area where the carriage is has stoped. There might be an obstruction visible.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Kodak 5300 printer
You'll need to contact kodak aio tech support so they can help you.
Aug 13, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Not printing!
pls open your bakside.and
check there is no any paaper jam in fuser assembly.
Mar 26, 2008 | HP LaserJet 1320 Printer
HP Photosmart C7280 Printer Logo
139 people viewed this question
Seeker5211
Seeker5211
