Question about Skull Candy Skullcandy Pipe iPod Speaker Dock Chrome (S7PIBNCZ) Docking Station
The volume lights are flashing and I am unable to control the volume with the buttons... I can listen to music, but only at one level! :(
The sound output is very low even using earphones can the audio output be upgraded to give a normal listening level.
Probably not without using separate amplified speakers. Check the mixer levels are set correctly.
Apr 02, 2016 | Computers & Internet
Tip
To connect a music player or other audio device to your laptop
<br />If your laptop has a line-in jack, follow the instructions above for connecting a music player to a desktop computer. But to connect a music player or other audio device to most laptops, you'll have to plug it into a microphone jack. To do so, follow these steps:<br /><br />Click to open Sound. <br /><br />Click the Recording tab, click Microphone, and then click Properties.<br /><br />Click the Listen tab, click the Listen to this device check box, and then click Apply.<br /><br />Click the Levels tab and make sure the Mute button looks like this . If the button looks like this , click it to turn on sound for this connection, and then click Apply.<br /><br />Play some music or other sounds on your device to test the volume coming through your computer speakers. Select the slider under Microphone, drag it right or left to increase or decrease the volume of your audio device, and then click OK. You might also want to adjust the volume on your device.<br /><br />Note<br />If you hear noise coming out of your speakers, try reducing the volume on both the music player and in the Levels tab. The microphone jack is designed to receive sound from a microphone, which is different than sound coming from a music player
on Dec 14, 2010 | Computers & Internet
Tip
To connect a music player or other audio device to your desktop computer 1After...
    1After you've plugged a music player or other audio device into the line-in jack and turned the device on, follow these steps:
  1. Click to open Sound.
  2. Click the Recording tab, click Line In, and then click Properties.
  3. Click the Levels tab and make sure the Mute button looks like this
  4. If the button looks like this , click it to turn on sound for this connection, and then click Apply.
  5. Click the Listen tab, click the Listen to this device check box, and then click OK.
    Notes
    • If you don't hear anything, make sure the volume is turned up on the device.
    • You can also change the line-in volume on the Levels tab. Select the slider under Line In, drag it right or left to increase or decrease the volume of your audio device, and then click OK.
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Volume increase samsung e2550
during a call/while listening to radio or music, use the navigation button up and down to raise and lower the call or music volume level (this only activates during a call or when radio or music function is on)
I hope this was useful
Oct 20, 2012 | Samsung GT-E2550 Cell Phone
How do you turn the volume down
1. Turn on the cube2. Hold silver + yellow at the same time while the startup music plays3. At the end of the music the voice will say "volume control, volume level ..."4. Release the buttons5. Tap either silver or yellow, listen to the voice and it will tell you the new level, "4", "3", "2", "1", etc. Yellow goes softer to a minimum of "1", Silver goes louder to a maximum of "4".6. When you're done, just wait a few seconds and it will automatically ask you which game you want to play.
Dec 26, 2010 | Pfizer Electronic Rubiks Cube Rubik's...
How do you turn the volume down .
1. Turn on the cube 2. Hold silver + yellow at the same time while the startup music plays 3. At the end of the music the voice will say "volume control, volume level ..." 4. Release the buttons 5. Tap either silver or yellow, listen to the voice and it will tell you the new level, "4", "3", "2", "1", etc. Yellow goes softer to a minimum of "1", Silver goes louder to a maximum of "4". 6. When you're done, just wait a few seconds and it will automatically ask you which game you want to play.
Dec 08, 2010 | Pfizer Electronic Rubiks Cube Rubik's...
I hit stop/start button, green light illuminates, hit again, green flashes, but no music. have tried volume controls and both sets of earplugs. i have confirmed that music is loaded.
If a green light is flashing on the player the shuffle button in the middle of the player is being pressed changing the players mode from continuous play to shuffle mode. To activate the player to listen to music you must hold the power button down on the right side of the player for about 3 seconds. If you need further assistance, please contact us directly at (808) 837-0074 or e-mail kevin@intova.net.
Thanks,
Intova
Jul 11, 2009 | Snap Sights H20 Man MP3 Player
Power Button Flashing Red
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Dec 14, 2008 | Denon AVR-1908
In my PC the drivers are updated but there is no sound at all.
If you Right Click on the Speaker icon in the lower right screen (system tray) and choose Open Volume Control, are all the slide levels about in the middle, and no check-box is set to Mute.
Nov 19, 2008 | Computers & Internet
Skull Candy Skullcandy Pipe iPod Speaker Dock  Chrome (S7PIBNCZ) Docking Station Logo
81 people viewed this question
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Owen Barnes
vimal
vimal
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
