Getting error code 29 on Corghi tire balancer when I try to balance a tire
  • 19,396 Answers
Hi.
Error 29 is device spinning malfunction. Either motor or motor speed sensor malfunction or other mechanical problem causing spinning malfunction. Advice is to call the service number listed in Corghi documentation, this usually is no minor fault.
Here manuals for several models:
EM8040
EM8070
EM 6040
5 EM43(Sp.)
Posted on Aug 30, 2010
What's your question?wheel balancer CORGHI EM 73 breaking fuse1 after replacement.solution.
if this a power in fuse to electric motor in the balancer then It may be a start/ run capacitor for the electric motor that has failed
have it checked and tested by an accredited electrician
Aug 28, 2015 | Cars & Trucks
Front right tire wobbles as if out of balance at speeds of 60-65 mph even after getting it balanced.
Assuming the wheel and mounted tire is balanced and the wheel is not bent would point to play in the front end suspension ball joints (control arm ,steering arm, tie rod), worn suspension bushings, or worn strut cartridges. However, some balancing is done at low revolutions rather than high speed balancing. The tire itself could have a belt that is separating in the tire that gets worse the faster it goes. Was the tire dismounted and remounted? Do you see a noticeable odd wear pattern on the tread? With the car up on a jackstand, grab the wheel at 12 and 6 o'clock and try to shake looking for play; then do the same thing at 9 and 3 o'clock. Check that all of the rods rods are tight especially near the ball joint and the bushings have not deteriorated. Loose wheel lug bolts/nuts are another cause.
Oct 13, 2014 | 2005 Toyota Corolla
Fault finding
Do you have a new set of tires? If so, its very likely they are not properly balanced. If not, it;s likely that one of the wheel weights on one of your tires came off and your tires are no longer balanced. Try getting your tires balanced and see if the problem goes away.
Sep 03, 2013 | Audi A4 Cars & Trucks
2000 Navigator Lincoln vibrates when driving
Could be a number of things (i.e. tire out of balance, axle shaft balance, etc....) I'd start with getting the tires balanced. You may have lost a wheel weight..and go from there.
Apr 19, 2011 | 2001 Lincoln Navigator
1996 Jaguar Vanden Plas. Problem: having trouble with vibration and noise on speeds between 30 and 35 mph. no vibration on lower or higher speeds. Any suggestions would be helpful.
Balancing the tires is the typical solution but your case sounds like it might be a bent wheel. Take your car to a tire shop to have them check for balance. While on the balancing machine, they can inspect the rim for a warped rim. Make sure you let them know prior to the wheel getting mounted on the balancing machine. Jags are known for that to happen. I hope it is just a tire balancing but if it is a bent wheel, the cost is more. Good luck.
Dec 29, 2010 | 1996 Jaguar Vanden Plas
My daughter has Maxima 1991 with 205 60/16R tires. Manual says 29 lbs. for 205/65/15's. Would it still be 29 for different sized tires?
It depends on the tire manufacturer. Generally speaking for standard tires and standard driving style I would keep the pressure somewhere in between 30-32. Try to balance similar pressure between tires to equilibrate driving.
Do not go crazy with that, current wheater and long driving will modify the current pressure in the tires. Just try to avoid significant deviations to specs.
Hope it will help
Dan
Dec 27, 2009 | 1991 Nissan Maxima
1999 AUDI A4 HAS VIBRATION AT CRUISE SPEED OF 50 TO 60 MPH.. NOTHING BELOW THESE SPEEDS OR ABOVE..
Could be a unbalanced tire..
Get the tires balanced..
Some tire purchases gauranty the balance..
Jul 08, 2009 | 1999 Audi A4
Computers & Internet Logo
1,533 people viewed this question
David Payne
David Payne
