Our Coleman Central heat and air unit EB20B keeps blowing the inline 3 amp fuse. How should I troubleshoot the fan relay and blower motor to look for defects that would draw too many amps. The relay and blower motor are 11 years old. Thanks Ken Rohm
  • Kenneth Rohm Aug 31, 2010
    Thank you for your quick response. Do you have any suggestions as to where the short could be? We traced and repaired the yellow wire to the Contactor. Could it be in the wall somewhere? Dumb question I know but we've been replacing brittle wiring for two weeks now and the fuse still blows. Any suggestions where to look?
    Thanks
    Thanks. It has to be in the yellow or y wire at the thermostat. You answered very quickly and to the point.
  • 8,220 Answers
The transformer is blowing the fuse because somewhere down the line two thermostat wires are shorted together. You gotta trace that out till you find the shorted wiring first. It is unlikely a component would blow that fuse. Most of the time it is wires chewed up or dry rotted and touching.
Posted on Aug 30, 2010
  • Dan Webster
    Dan Webster Aug 31, 2010
    Get a new run of wire and tie it to the old one and ease a new strand out there
I have a 93 Cadillac Deville when I turn on the heat it blows a 10 amp fuse and the transmission stops changing gears. What is wrong?
4504204 A/c blows fuses - Document Download
thebestsolutions.top/F/cars/t4504204-c_blows_fuses
4504204 a/c blows fuses ive had feron checked replaced a/c relay fuse last about 10 ... I have a 2006 impala that is blowing the 10 amp fuse to the ac/compressor/a new will last ... 93 corolla 1.8 No start Blown ignition fuse ... i have a cadillac deville the a c blows hot air on ... air con fuses air con heating mk3 mondeo talkford.
Blower Motor Problems ' Auto Repair Help - YouTube
? 4:22
https://www.youtube.com/watch?v=2vmfxYg8LoY
Sep 27, 2009 - Uploaded by mgittelman
I have a 1996 Cadillac DeVille that the blower motor stays on unless you unplug it. ... +mgittelman hi mate ...
Cadillac Repair - Questions and Answers from October 12 ...
en.allexperts.com > Shopping > Vintage Cars
Nov 3, 2006 - 91 Fleetwood "check engine" light, 10/31/2006, Tom Joy ... Q: My 95 Deville blows air when the heat is on, but the air never warms. ... 96 Deville Interrior Lights Inoperative & 3.2 Amp Draw on Body Fuse 3. ... Q: I have the 93 cadillac deville and those codes came up right after a transmission replace.
Cadillac Seville Questions - Heating/AC fan runs when car ...
Jan 10, 2016 | 1993 Cadillac DeVille
The fan stopped working for the rear AC/heat in our 2003 odyssey. Checked 40amp suqare fuse under hood and it tested ok. Is there a fuse or breaker for the rear fan motor?
The large fuse you checked is for the rear fan blower motor. The fuse you need to check is for the fan motor relays and rear mode control motor. It is fuse No. 3 (7.5A) located in the driver's under dash kick panel fuse box.
If fuse No. 3 is blown and you replace the fuse and it blows immediately, you'll have to check the five relays and the mode control motor all located near the rear A/C unit in the right aft sidewall. Most likely, the mode control doors have become jammed and that is why the fuse blows. The doors shift air from overhead vents (cool) to floor vents (heat).
If the fuse is fine, the trouble is probably with the blower motor itself or the wiring to the blower motor is broken, or there is a bad ground.
Feb 28, 2011 | 2003 Honda Odyssey
1997 Isuzu Rodeo V6 4X4. I have only owned this vehicle for 3wks and the fan/ac wont blow at all out the vents. The blue light comes on when i push the ac button but that is all it does. I don't know which...
C-19 Blower motor fuse 25A located in cabin fuse box. Left hand footwell on LHD vehicles, right hand dashboard on RHD vehicles.
Start by checking blower relay B-36 in the engine compartment fuse and relay box. Remove the relay. Jumper directly from battery to pins 85 and 86. (also see here: http://www.fixya.com/cars/r5544622-wire_relay if you dont know about relays) The relay should click Now measure across pins 30 and 87. Measurement should be 0 ohm.
Remove the blower motor(3 screws on the bottom of the unit under the passenger side dash) and connect jumper leads from the battery directly to the blower motor to see that it operates.
The blower motor resister is mounted on the ducting between the motor housing and the heating unit. Remove to test
Measure :
  • pin 1-2 : 2.4 ohm
  • pin 2-4 : 0.9 ohm
  • pin 2-6 : 0.28 ohm
  • pin 2-3 : 0 ohm
Aug 21, 2010 | 1997 Isuzu Rodeo
My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
May 28, 2010 | Coleman Heating & Cooling
I have a central heating and air unit. The unit
sunds like the fan bearings have seized up or u have a bad fan capacitor take a screwdriver and spin ith blade to where the air would be coming out the top and if it startswhen u spin it u need a fan capacitor
Feb 23, 2010 | Coleman Propane Forced Air Heater...
One unit runs a while, powers down, other unit blows transformer
you say it keeps blowing the transformer? you mean circuit breaker? if it is the circuit breaker, have the wiring checked for a short, if no short do a ohm test on the compressor. it may have shorted out internaly.
May 31, 2009 | Haier HC48C1VAR Central Air Conditioner
Air and heat not blowing air through vents
Either Your fan switch is burned out or you blower motor is no good, your blower motor is on the passenger side under the dash. Before you replace any parts you need to check your fuses and relays under your hood and in the car. Usually if your fan switch goes bad you will still get some air blowing thru the vents, so my guess would be blower motor, If its not a blown fuse or relay.
May 28, 2009 | 1999 Cadillac DeVille
Fan keep,s blowing
Your thermostat is calling for blower, your fan relay is stuck, or that model had a time delay blower solid state board on it which had the blower relay on it, and it could be bad. I would turn the power off to all of your system for a few minutes and see if this could make something happen.
Nov 20, 2007 | Heating & Cooling
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
