Question about Dell Photo 964 All-In-One InkJet Printer
Printer Busy I am using the Dell Photo All in One 926 Printer with Windows Vista (awful) and has been fine for over a year. I kept using cartridges well beyond time Dell said to replace (they were fine) but last week aborted a print and then had trouble installing new ones (the cartridges did not present 1/2 way along). Ever since this I have not been able to print; I have unistalled and reinstalled drivers (twice); cleared out(renamed) some 'w32x86' folders under 'spool' - as recommended by Dell tech support. Still no luck - cannot use locally for copying (no error messages just sits there) or print (message 'Printer Busy'). Help!
  • Dove_uk May 08, 2008
    Thanks for prompt feedback;
    As I think it is a printer issue (rather than PC driver problem - because I have done re install twice now) I have tried to restore factory settings as recommended and then print a test page locally - no luck.
    Can't see why but from your response sounds like bad news - do I really need to buy a new one?.
    Ann
I was having the same problem trying to scan. Then I noticed that the Mode (on the printer - use the checkmark to scroll to it) was set to Copy. I changed it to Scan and all is well.
Posted on Oct 02, 2008
  • Dell Master
  • 1,183 Answers
As you have already worked with Tech support at Dell, they may have exploited all the options but do try the following steps and tell me if that worked
1. DIsconnect you printer from the computer
  1. Press the down arrow button until Maintenance is highlighted and press the Select button.
  2. Press the down arrow button until Reset Defaults is hightlighted and press the Select button.
  3. The printer displays a confirmation message. Highlight Yes and press the Select button
This would reset your printer to factory defaults.
2. Unistall the drivers using the following file
R166225 .zip from the link below
http://support.dell.com/support/downloads/format.aspx?c=us&l=en&s=gen&deviceid=9913&libid=40&releaseid=R166225&vercnt=1&formatcnt=0&SystemID=PRN_PHT_964&servicetag=&os=WLH&osl=en&catid=-1&impid=-1
-> Save the file to desktop
->Double click to extract the file and see where the file is being extracted.
-> Go to extracted file folder ,right click on the file named setup and left click on run as adminstrator.
-> Follow on screen instructions and it would uinstall the printer
3. Restart your computer.
4. Install the drivers back on to the computer using the printer cd. Note :connect the printer only when prompted on the screen.
Once the printer has been installed , we need to update the printer aswell .
5. Download the printer firmware from the link below
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R114639&SystemID=PRN_PHT_964&servicetag=&os=WLH&osl=en&deviceid=9913&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=1&libid=40&fileid=151153
6. Follow on screen instructions to install the same
7. Check if the printer works after this , otherwise its time for a new one.
Thanks
Mandeep
Do let me know , if the information above was of any help. by rating me for the same.
Posted on May 08, 2008
  • Mandeep  Singh
    Mandeep Singh May 08, 2008
    As requested in the earlier post,
    > try resetting the printer first and update the firmware.
    > Do let me know if you are able to print locally if the print is not successful , i hate to say this but you would have to get yourself a new one.
    Thanks
    Mandeep
How do i put in ink on 926 dell photo scanner and copier
From the online manual...
1. Turn on your printer.
2.Lift the printer unit, and then position the scanner support between the tabs to hold it open.
3.The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4.Press down on the ink cartridge lever to raise each ink cartridge lid.
5.Remove the old ink cartridges.
6.Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
9. Snap each lid closed.
10. Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
Manual can be downloaded here.
Oct 30, 2012 | Dell 926 All-In-One InkJet Printer
I can't get dell photo cartridge for 926 all-in-one inkjet printer to lock in its holder.
try pushing it? try to remember how you took out the old cartridge then reverse it dell printer
Nov 27, 2011 | Dell 926 All-In-One InkJet Printer
Is a Dell PHOTO 926 copier compatible with a Dell INSPIRON 9200 laptop
Hi!
There's no known compatibility issues with any Dell Printer working with a Dell Laptop.. Your printer should work fine wih your laptop.. I
f your laptop runs on Windows XP, make sure you install the printer disc.. or downlload dirver & sw from here:
http://tinyurl.com/ydzple9
if you using windows vista or 7, you can use the link above, just select the windows version from the drop down..
Hope this helps.. :D
Sep 13, 2010 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 printer will not print with the black ink and tells me that the cartridge is incompatible even though there is ink in the cartridge and i got it from dell
Do you have a '926' or a '962' printer? You've cited each number in your problem description.
Remove the ink cartridge.
Turn the printer off.
Turn the printer on.
Reinsert the ink cartridge.
If the problem persists, contact Dell, and get them to replace it.
Nov 20, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell Photo 926 ink cartridges holsters won't show up
Contact the dell chat suport line on the dell.com website they are good at fixing probles even if they have to seend someone out or have you seend it in.
May 03, 2009 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 printer scanning problems
Go to Control Panel, then Programs and Features. Uninstall the Dell printer software.
Then, go to Control Panel, then Device Manager. Locate the printer, right click on it, and select uninstall.
Disconnect the printer from your PC.
Go to the Support section of Dell's web site, download the latest driver for your printer.
Restart your PC.
Install the software. Connect your printer when instructed to, or after the software install has completed.
Let me know if you still have issues :)
Apr 28, 2009 | Dell 962 Photo All-In-One InkJet Printer
Hi there
Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
Mar 01, 2009 | Dell 926 All-In-One InkJet Printer
Dell Photo 964 All-In-One InkJet Printer Logo
188 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
