Question about Pacific Laser Systems PLS5 Automatic Laser Plumb Level And Square
I have a robotoolz laser level RT-7210-1. ( The remote controlled one that rotates and sends out a level beam.) In attempting to calibrate it I backed the set screw out all the way and it fell down into the machine.I did this by accident because however far I turned it it didn't have enough effect (lowering the beam). Maybe it was too far out to be within the calibrating adjustment range or ???. Any ideas on this or on retrieving the setscrew? I'm about to embark on (foolishly?) taking the thing apart. Thanks, Dan
I need my Unit rebuilt, unit was knocked over and the bearings fell out.Can this be done?
Unfortunately no. Nothing you do will make this accurate again. These are throw away lasers.
Oct 23, 2014 | Robotoolz RT-7210-1G Self-Leveling,...
Were can I down load a robo laser rbo 1001 manual
nobody ever sent me any help. still cant operate
Jun 29, 2014 | Robotoolz RT-7210-1G Robolaser,...
Dropped rt7210-1 bearings out laser and drive ok
Dropped my robolaser RT7210-1 and the bearings came out.
Aug 23, 2013 | Robotoolz RT-7210-1G Robolaser,...
My Robotoolz : RT-7210-1 was stored improperly and now the lazer beam is dim and hard to see in bright sunlight... Could really use info on repair or info on a place that can repair it for me.
Improper storage (I've done it too), usually means that the batteries have become too hot - and
therefore weak. The first thing I'd try is changing the batteries.
The 635nm laser operates on (4) AA batteries, and the rotary uses (1) 9V battery.
The online reviews for this a horrifically bad - see:
http://www.gosale.com/4364289/porter-cable-robotoolz-rt
May 17, 2011 | Robotoolz RT-7210-1G Robolaser,...
Uno.comi have a robolaser level rbo1001 that dosnt work. put in all new batterys. worked great for 10-11 yrs now nothing. light or rotation.b
I have a Porta-Cable,I found that the clicker's battery always had a bad connection so I put packing around it and it has worked so far. I've also found that the first time moisture hit the thing the spread lazor lost it's power. If yours worked for 10 years, then it already paid for itself.
Oct 22, 2010 | Robotoolz RT-7210-1G Robolaser,...
I have a RoboToolz RB01001 rotary laser. The green light comes on for approximately 2 sec. then goes out and the unit does not function at all. It has very little usage and has been cared for, never tossed...
That's usually a battery problem either in the laser unit or the remote control. The battery in the remote tends to disconnect if bumped. A small piece of foam pad at the bottom of the battery can fix that.
Jul 11, 2010 | Robotoolz RT-7210-1G Self-Leveling,...
Does not power on. batteries new
check batters ports see that they are clean
Jan 13, 2010 | Robotoolz RT-7210-1G Self-Leveling,...
Need robolaser instructions; can not get it to turn on. it has new batteries.I really don't know anything about this laser. It was my Dad's he has passed away.
Did u open the front and turn on the remote to activate the laser ? the model i have ( 8years old )this is what it takes to get the laser work.
Jan 10, 2010 | Robotoolz RT-7210-1G Robolaser,...
Cant calibrate laser
You must place the unit 30' from a wall, level the unit with the level indicating vials, mark spot on wall or object, rotate laser 180 degrees and level with vials again, if it comes to the same spot your unit is calibarated. if not then you must do this process at least 2 times(1 for each directional level) and use the adjusting screw to move vial. it takes a while to get it right.
May 04, 2009 | Robotoolz RT-5250-2XPK ePlane XP High...
Pacific Laser Systems PLS5 Automatic Laser Plumb Level And Square Logo
48 people viewed this question
Top Pacific Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Pacific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
