My pink case logic wireless mouse will not hold a charge for more then an hour or two. I charge it for hours at a time and even changed the batteries but nothing helps.
  • missm6491 Aug 30, 2010
    no comment.
    President:
  • 4,070 Answers
Hi! The problem may not be on the batteries but surely is on the internal parts. The circuit board may be faulty causing an excessive discharge to the batteries. I suggest that you replace the wireless mouse for the one you are using may have reached it's break point. Hope this helps and thank you for using FixYa!
Posted on Aug 30, 2010
My headset will not charge fully and after a couple of hours needs re charging light does not flash for long
If it's old then the battery has probably worn out and no longer holds much charge. See if it can be replaced.
Dec 29, 2014 | Plantronics Cs540 Wireless Headset
Logik wireless mouse
1. Make sure the mouse is fully charged. The underside should have a red flickering light if it is working properly. If not you need to change the batteries.
2. Plug the USB dongle into the computer. The blue light should light up and flash rapidly as you move the mouse around. If it still doesn't work you need to re-sync the mouse with the dongle.
Turn the mouse off and back on again. Hold it near the USB dongle.
Push the blue button on the dongle. It should flash steadily. Push the reset button on the bottom of the mouse. The blue light on the dongle should start flashing rapidly and your mouse should now work.
Jul 30, 2014 | Case Logic EW-609 3-Button Wireless...
Charging battery
Sometimes if charged too long or your not around when the light does go off, after awhile the battery looses its charge. when that happens the charger will start to charge again and it will seem that it isn't working right or charging. in your instruction booklet it should tell you how long it should take to charge. some say 45 min some say hours. set a timer once you find the time recommended for your device, once it goes off unplug if light is off. good luck
Dec 07, 2013 | Case Logic IKBT-50 Bluetooth Keyboard...
My old 611 dosent hold the battery charge for long even though I have put in a new battery
An in car charger will not charge as well as the mains, when charging for the first time you should use the mains, and charge for at least 8 hours. If it didn't charge correctly, it will be the same low charge all the time, as the battery has a memory that makes it charge the same each time. Try charging from the mains, you might be lucky.
May 22, 2012 | Cell Phones
How do you change the battery in the Mouse
model no. all the wireless mouses have battery partition at downside. check it
Mar 08, 2011 | Logitech Cordless Mouse
The charge light keeps blinking red and doesn.t turn green, even after hours of charging and a new battery
There are many possible scenarios as to why this might be the case. The most logical would be that the battery has trained itself to not register a charge, this is a common problems with cell phone batteries due to incorrect charging procedures. Go ahead and power cycle the phone (take the battery out and let it sit overnight), if this does not resolve the issue, go and purchase another battery (make sure it works with your phone model) and try charging that one. hope this helps.
Oct 13, 2010 | Cell Phones
It uses up two AAA batteries in less than four hours of use!!
Hello Pabobr, hi, I wish this may help, I want to ask you a question, during that 4 hour use, does your mouse operate normally?
If yes, then thats a design problem, If no, you need to try other battery makes, and see if the changing battery names with solve your problem, if by any chance the problem still persist, try you mouse on another PC, see if the problem is your PC or not, if still you cannot break the 4 hour use, its already a design flow of that wireless mouse, call your dealer if what you have experience is the true just for confirmation. Try also other brands, you choose, still continue to use that mouse, and waste money on batteries or try other makes. Or go back to the traditional wire mouse.
Mar 10, 2010 | GE Wireless Optical Mouse
Wireless mouse plugges in light on and chnaged
You may have tried this.....on the cordless receiver press the button on it...while it is flashing press the button underneath the mouse. They should now communicate with each other..hopefully this works
Nov 01, 2009 | Logitech Cordless Mouse
DSealed Lead Acid Batteries: 12v 7ah; belongs in a Liftmaster LA400 gate control box. Can these batteries be charged using a trickle charger? I'm trying to find out if it's the battery not holding a charge...
Yes you can charge the 12 volt bttery on a trickle charger. You should use a 1 amp or less charger. Check the battery every 1/2 hour or so for heat. If it get's hot you should stop charging. Power packs that have a 12 volt rating will charge your battery safer and better but will take longer (like a cell phone charger) look at the voltage ratings on the charger. You will have to adapt the plug to hook it up and test for correct pos. and negative connections. The 7amp hour batery should be fully charged by a .5 amp (500ma) charger in about 14 hours (multiply the amps times hours of charge and do not go over the 7amp hours of the battery when deciding how long to charge). After charging check voltage, it should be around 12. Let the battery set for a few hours (overnight) and check the voltage again. It should be around 12 still. A fresh charge will usually show a higher reading (called a surface charge) than a battery sitting around. 4.5 v will not operate your device, 9.5 v or higher should.
Aug 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Mouse light keeps blinking.
You need to make sure that the mouse is near the receiver, or that the reciever didn't fall down or got moved too far away from the PC/desk or the mouse itself. Furthermore, check to make sure that the batteries you inserted were new or fully charged batteries.
Mar 22, 2009 | Logitech 9311570403 Mouse
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
