Question about Xerox Phaser 8560MFP Laser Printer
Xerox 8560MFP error code 39,003.40:47842 - Xerox Phaser 8560MFP Laser Printer
5 Suggested Answers
Nextgen
  • 13 Answers
SOURCE: 8560mfp system error 07,010.43:2640
The error you are receiveing is due to the printhead in the machine most likely being stuck in the tilt position by the tilt lock arms. The first step is to reboot the machine, which you have already done. The rest of the possible solutions require disassembly of the machine. They include:
  1. Verifying that the lock arms are rotating properly.
  2. Examining the printhead for spilled ink.
  3. Checking the process motor gears for damage.
  4. Checking the process gear box, shaft and drive module are in home position.
As well as a few others.
If the machine is new, I would suggest having it looked at under warranty by a Xerox tech. It sounds like something they would cover.
Hope it helps!
Posted on May 21, 2008
  • 2072 Answers
SOURCE: i have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Posted on Mar 11, 2009
  • 7 Answers
SOURCE: Error 09,036.44:41689
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Posted on Jun 10, 2009
pdouglasss
  • 125 Answers
SOURCE: Xerox Phaser 8560MFP/N System error
Hi mary_ballling:
Here is you problem.
9,035.4x through 9, 038: Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to Step 2.
Run clearISCfault test to clear the error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to Step 3.
Remove any blockage and/or replace the ink stick.Run
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace the printhead.
Replace the ink loader assembly. Run
Hope this helps
Posted on Jul 31, 2009
What is Xerox Phaser 8560mfp fault code 00,006.74?
Hi Anonymous,
You need to contact your the www.xerox.com website.
Regards.
Jul 28, 2014 | Xerox Phaser 8560MFP Laser Printer
What is the meaning of error code 13,136,40:77333? xerox phaser 8560mfp.
Defective part, triac possibly part number 084K35871 have a tec look at it
Jul 10, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
THE UPPER UNIT FLASHES ON THE SCREEN WITH ERROR CODE 39,003,40;75554
On the Xerox 8560MFP multifunction, this error code 39,003 signifies a Scanner problem, specifically that the Optical Test has failed. the 75554 is your current page count on the printer.
The Scanner Assembly 062K22590 must be replaced. It is fairly expensive, but moderately easy to replace.
You should also order the Scanner Calibration Sheet 109K01910 to make sure that margins and contrast are correct.
The scan/ document section is broken into 2 main parts, the Scanner, and the Automatic Document feeder. The feeder section is probably working fine.
Good luck with that.
Dec 27, 2010 | Xerox Phaser 8560MFP Printer
We have a problem with a Xerox 8560 MFP with this error 37,008.44:34849. We don't known where is the problem. Can you help us ?
There is a problem with the power up of the printer. For 37,00x.xx error codes you can try power off the printer, wait 30 seconds and power it back on. According to the Xerox website for 37,008:44 error code you should Verify the Printer's Power Source and Isolate the Printer.
Nov 18, 2010 | Xerox Phaser™ 8560MFP Laser Printer
Xerox Phaser 8560MFP/N System error 09,038.46:950
Hi mary_ballling:
1 1.
Go to Step 3.
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
Hope this helps
Jul 31, 2009 | Xerox Phaser 8560MFP Laser Printer
I have xerox phaser 8560MFP error cod 07,010.43:14059
Mar 11, 2009 | Xerox Phaser 8560MFP Laser Printer
I have 2 xerox 8560 printers with error codes
One of your ink sticks is not moving down into the ink loader properly.Either one is cracked, twisted or otherwise not moving down the loader. I think the .46 means its a black stick.
Mar 09, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
134 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
