Question about Jandy Aqualink Rs4 One Touch Control System Control System
6My heater heats my pool and spa. My jandy RS4 will make the heater turn on for the pool and operate properly attaining the set temp of 89 but, when in the Spa mode, will turn on and off intermittently, and run for about 30 seconds, never attaining the set temp of 104.
  • 320thvnvet65 Aug 30, 2010
    If the Sensor is the problem, why does the heater work properly when in pool mode and only fail when in spa mode?
    My heater heats my pool and spa. My jandy RS4 will make the heater turn on for the pool and operate properly attaining the set temp of 89 but, when in the Spa mode, will turn on and off intermittently, and run for about 30 seconds, never attaining the set temp of 104. The same Water Temp Sensor is used for the Pool and the Spa. Is the Senso bad?
  • 3,083 Answers
Just FYI, here is a general blog about some of the things it could be:
http://spababes.com/symptomandcure.html
Make sure the wiring to the sensor isn't grounding out on the metal cover, or intermittent.
And speaking of intermittent, make sure all wires are clean and making good contact with their terminals- this can be a big problem, and the cause of many crazy problems.
Also, refer to your manual and, just for kicks, do a system diagnosis on the unit- it might show up there.
Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 30, 2010
  • 944 Answers
The sensor is the defective one.Just pull the sensor from the pipe by loosening the stainless steel clamp that holds it in the pipe.Then follow the wire back into the Aqua link box and unplug. Get a new one at your local store and replace. It's a common problem and you should be able to do it with ease.The water temp is attached to a pipe, and held on by a hose clamp, and the air sensor should be located near the box, and looks exactly the same as the water sensor (minus the hose clamp).
When it is set to higher temperature it is not able detect the heat.For safety purpose the Jandy heater will turn on and off.
It turns off due to false temp deducted and also turns on due to same reason.
The sensor will look like this replace it
post a comment for further assistance.
thank you for using fixya have a nice day:-)
I can't get the pool heater to go on eventhough the heater will work in spa mode jandy aqualink rs4
I assume you have an RS4-PS. I would check the filter to make sure it is clean. If you have a dual equipment set up then call a Jandy automation expert.
Jan 28, 2017 | Jandy Pool & Spa
Pool spa heater when freezing temp
It normally will heat up with pump moving water, once the threshold is achieved - system will come out of its Freeze protection mode and will begin to work as programmed. If there is a heat call, heater will come on.
You can also locate the sensors, both the Water & Air (they need to be very close in temperature for this to work) then place them in water warmer than the actual ambient temp, & above the temp that triggers "Freeze".
Dec 27, 2012 | Jandy Aqualink Rs4 One Touch Control...
Why does pool heater come on when filter pump is turned on?
some models the heater will overide the remote. put heater temp to highest setting 104 degrees, then remote should override the heater
Nov 20, 2012 | Jandy Aqualink Rs4 One Touch Control...
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
Jul 05, 2009 | Jandy Aqualink Rs4 One Touch Control...
SPA Filter on while Spa is Heating
If it has motorized valves the stop positions have to be adjusted so that the water coming back is equal to what it drains to stop the spill over process unless you want to add more valves but the pool pump does the job of heating and filtering the spa
Jul 04, 2009 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
37 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
