Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Hit fence and right front tire is towing out. how do you get the alignment right?
    Problem Solver:
Kevin plumag, you may have bent the tie rod. It's an easy fix: each end of the tie rod connects to the axle, keeping the wheels at the right distance. Each end of the tie rod has a small cotter pin. Remove the cotter pin (a washer will fall off), lift out the bent tie rod, and put a new one back in, reinstalling the washer and cotter pin on each end.If your tie rod is straight, something else is wrong (which is why I'm searching the boards!). You can order a tie rod from Sears; check your manual for the part number.
Posted on Apr 16, 2011
Rip fence is out of alignment..what do I need to do?
This is the fundamental problem with rip fences on table saws. I don't know what kind of rip fence you have, but most rip fences are adjustable for squareness. However, unless you have a very nice (and expensive) rip fence, they often don't self-align when you move them anyway. If you have the type that clamps at the front and the back of the table, the problem can be overcome by making sure the rip fence is straight before you clamp it in place. The easiest way I have found to do that is to use an adjustable square. Put the front of the rip fence where you want it, then set the adjustable square so that it matches the distance from the miter slot in the table to the fence. Then move the square to the back of the table and move the back of the fence to meet the end of the square. Now clamp it in place and check the front and the back one more time. It's tedious to do this every time you adjust the fence, but you can get a perfectly aligned fence this way. This method assumes that your blade is parallel to your miter slots, which is adjustable too, but you have to get underneath the saw to do that. good luck, Al K
Jan 14, 2011 | Saws
I have 94 CHEVY SUBUBAN K1500 4wd. I have had it aligned 2 times, new front tires and the outer edge of the passenger front tire keeps wearing uneven. The driver side front tire is fine.Chould this a...
check if your shocks are leaking. Jack up the car and with the right wheel off the ground check it for play in the bearing if it is tight and not grinding it is good. I would try another alignment shop if you dont find anything. Oh by the way dont let the wife hit any more curbs. If it is hitting curbs it could get knocked out of alignment.
Dec 09, 2010 | 1994 GMC Suburban
I own 2009 Impala and just replaced tires at 30,000 miles. I did rotate tires but still had wear on front tires. I had a front end alignment the last time and they told me the camber was off because I must...
Well, the camber which is the vertical angle of the tires or wheels as the car is viewed directly from the front, is adjustable on these cars' struts.
So, if the alignment technician performs a front wheel or even a 4 wheel alignment (which is better), then the front angles should be adjusted so that tire wear doesn't occur on the left or right side of the tire as viewed from the front.
I would continue to rotate tires every 5,000 mi. or so, and have the alignment checked at a place like Sears or your local tire shop to ensure that your alignment is good, and not out of specifications.
Nov 03, 2010 | 2009 Chevrolet Impala
What can were you tire out with in tow weeks
out of tire alignment if wearing out on either the outside or inside tire thread.......Hope this helps.
Oct 10, 2010 | 1996 Ford Windstar
Pulling to the right.
As long as the vehicle has not hit a curb or been in an accident:
First, check your tire pressure. Make sure the right front brake is not dragging, and next try switching the front tires. If the pull changes to the left the tire is suspect. If that doesn't catch it - have the front end checked by an alignment shop.
Feb 01, 2010 | 1993 Mazda Protege
Car vibarts when it hits 45 pulls to the right
alignment issues , bad tire, or a balance issue
Oct 13, 2009 | 1994 Oldsmobile 88
Blade Alignment?
ok yep your blade is out of alignment with the fence. It is closer to the fence at the rear than the front. You need to make the modification or adjustment to your fence, if it allows that, and then worry about the miter slots later (which should be adjusted miter slot to blade, not miter slot to fence). You might be able to adjust the miter slot to blade by moving the actual table and then securing witht he table mount bolts. Check your manual for how to align the fence.
You do want to fix that though as it can be potentially dangerous and result in kickback of the workpiece which is a rather SCARY thing, and very dangerous.
Jun 01, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Front wheels not aligned
it sounds like your drag link is bent.look under the front.the rod connecting the two tires should be straight.if not,straighten it and slide a slightly larger piece of galvanized pipe over the rod to stop it from bending again
Apr 29, 2009 | Troy-Bilt Pony Garden Tiller
Biesemeyer fence not parallel to blade.
Yes you can adjust the angle of the fence. There are two adjusters at the front of the fence where it meets the fence rail. Adjusting these will pivot the fence either slightly left or slightly right.
There is a basc video on youtube my daughter made to show you how to align yourfence to the saw blade.
Feb 28, 2009 | Delta Machinery 3 HP Left Tilt Unisaw with...
Hit a curb 1999 Ford Taurus SE 16" wheels steering problem
It could be the steering rack but the first thing you should do is have an alignment job done. Even if there is another problem, the hit would almost certainly knocked your suspension out of alignment. So you'll probably need to get this done anyway. If there's still a problem after that, then I'd have your steering looked at. But the alignment may fix it entirely.
Jan 08, 2009 | 1999 Ford Taurus
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
885 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
