Question about Health & Beauty
I have nexxtech infrared massager with adjustable handle item # 6318371, woking fine but there is magnet type meteal piece with screw which is attached to the tip of the rotating motor broke and fell apart. is that possible to get that part.
  • 74 Answers
SOURCE: door handle loose
they are a vivration attenuator and yes are spacer too, but are a little dificult to mount if the machine are working well ok leaved like that but check every coples of month for a loose screew.....good luck and rate me
Posted on Jan 10, 2008
SOURCE: coupling broke
I have a Dremel 395 Type 3. Motor works fine, shaft doesn't turn. Took it apart to find that the white plastic or nylon flex coupling on the shaft had crumbled and the spline driver, which fits directly over the motor end of the shaft was somewhat worn. I emailed Dremel and got an overnight reply listing the 2 parts I need and the cost: Coupling is $1.00 and the driver is $1.25. Placed order by phone: 1-800-437-3635. I ordered 2 of each in case future replacement is needed. Total bill came to $7.27 including Florida tax and shipping. Can't beat that. They said it would be in the mail by tonight. (Flex coupling number is 2615294309; spline driver is 2615294308.)
Rating Locked! (?) lexrehabtech has rated this solution as Helpful
Posted on Oct 31, 2008
SOURCE: disassemble to repair
I just decided to try to fix mine. There are all together 5 screws. The two on the handle are covered with plastic caps which can be pulled out by sticking a duct tape and pulling it up. The other three screws are in the thumper head and are covered with the purple violet rubber piece. I removed it with my fingers. There are also two plastic bolts in the head of the thumper opposite to the handle. I removed them by using a sharp knife to loosen them and pulled with pliers.
I purchased two thumpers over time and in both the switch failed. I see that the switch in the handle is linked with the underlying mechanical switch by a very thin plastic piece. What a miserable design. That piece broke off in both thumpers rendering them unusable.
Good luck. Artur
Posted on Jan 03, 2009
SOURCE: repalcement handles for Rival slow cooker crock pot model scu600
My black handle broke off, too. I went to the hobby store and got a wood ball not too big and drilled a hole in it the same diameter as the screw that held in the original handle. Voila, I now have a wood ball knob handle on my crock pot lid. You just install it and cscrew it on just like you do a new knob on a kitchen cabinet.
Posted on Apr 07, 2009
  • 297 Answers
SOURCE: Where can I get a new motor for an Intex pump model 637 or 12R
first off water should not be getting to the armature area. be carefull with how you are taking care of your pump.
secondly a 1500 gallon pump is very weak I would advise at least 2500 or even the intex 4000
the most important part of pool maintenance is circulation.
if you have time check into electric motor rebuilding in your area
but sometimes that is more expensive than buying new
also if you have a valid receipt and the pump is less than 90 days old call intex and they will send out a new one within 24 hours
good luck
Posted on Jul 27, 2009
My SPT model #AB-753 infrared foot massager guit working, no power, how do I fix it?
I assume this foot massager is a dealer installed item on your unknown car, or you have posted the question in the wrong section.
Dec 27, 2016 | Cars & Trucks
Nexxtech keyboard 800 728 2. Opening battery compartment
try using a small percision flat blade screw driver....find side with dimple use screwdriver and push outter piece in toward the middle and lift ..
Aug 13, 2016 | NexxTech Computers & Internet
How do I reinstall the curved magnetic handle?
In many can openers of that type, the "handle" actually is an assembly that mounts on a pivot pin. You may have to experiment by rotating the assembly to find the spot where it slides into place.
Sep 18, 2015 | Cuisinart Deluxe Stainless Steel Can...
Where can I download a "user's manual" for
try typing what you want into your search engine ie, user's manual" for King king USA Big Foot Infrared Foot and calf massager. you might be pleasantly surprised
Oct 02, 2011 | Health & Beauty
1971 CB 350 clutch is VERY low (close) - How do I adjust it?
On the left side sprocket cover is a nut and screw , if you loosen the nut you can turn the screw you can adjust the clutch. You will want to loosen all your cable adjustments first so you have the adjustments later when you need them again. If this does not work, take the cover off and inspect the pieces for damage ,missing bearings, cracked parts,bent shaft,etc. If you pull the shaft out of the motor be careful there is a small bearing that will usually fall out of the motor after you have left the room if the bike is on its side stand.
Aug 01, 2010 | 1971 Honda CB 100
Chain is off and I am not sure how to get the adjusting screw in
You don't need the adjusting screw, if it is missing, you can still run the saw. Get the chain straightened out on the blade, with the cover on if you can, keep the cover bolt loose, put the blade in a vise, pull on the saw and tighten the cover bolt at the same time, make sure the chain moves, as long as it is not dangling down real loose, you should be all set. My adj screw bit the dust years ago, so did the safety bar. Still works great.
Feb 20, 2010 | Remington Electric Chain Saw
The door handle on my sub zero 650 has come off.
On Few Models, To remove the existing handle have a look for clipped on covers hiding the screws.On others, With a small flat blade screw driver stick between the handle and the door trim on top and push it up and on the bottom push it down and you can access the screws in the handles and tighten.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 05, 2009 | Sub-Zero Bottom Freezer Refrigerator
I nee to tighten up the freezer door handle on a sub zero 650?
There are different handles depending on serial number. The older of the two is at the top of the door. The screws are covered with a magnetic trim piece. You can remove this by putting tape on the chrome and pull up. You can then tighten the nuber two phillips head screws. The newer model is on the door itself. These are held on with small set screws accessed from the bottom of the handle. You may get by just tightening the set screws. If not you need to remove the handle by removing the set screws. You can then tighten the standoff and reatach the handle. For the 632 same procedure except it will be on the side.
Apr 12, 2009 | Sub-Zero 650 / O Bottom Freezer...
Can't disassemble massager.
I don't have the Homedics programmable, but I have taken apart my Brookstone programmable (and lots of old Homedics massagers).
I'm going to guess the screws concealment method is similar. On the under side of the massager, look for small oval-shaped outlines that are the same color as the rest of the body. Mine had four. These are little plastic plugs that you can pry out with a tiny flat screwdriver or a razor blade. The screws are hidden under these plastic plugs.
I hope this helps
Feb 23, 2009 | Homedics PA-4H Programmable Percussion...
Cannot unscrew screw!
try super gluing (or with some commercial purchased weld products (like a glue or epoxy) a bolt to it and extract the screw with a wrench on the head of the bolt. Might try vice grips on the head too.
Dec 28, 2008 | Homedics Quad Roller Massaging Cushion...
Health & Beauty Logo
74 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
