Question about Ovens
TURN OVEN ON. SATAYS ON FOR A FEW MINUTES THEN SHUT OFF AND WON'T RE START. THEN THE ONLY THIN THAT WORKS IS THE CLOCK
  • 21 Answers
Set clock to manual cooking not auto or time
Posted on Sep 01, 2010
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
We cannot turn the oven on! No instruction manual. The 'A' is flashing on the 'clock'/timer - what does this mean?
This means it is in auto mode. It must be in manual mode for the oven to work. Turn the oven to ON. Some clocks have 2 or 3 buttons. Press the buttons at the same time/try all different combinations. This might take a few minutes, be patient. When the oven indicator lights the clock is in manual mode.
Apr 01, 2011 | Ovens
Clock keeps flashing i keep setting clock but after 5 minutes or so starts flashing again putting tape over ready time button to hold it down then reset clock seems to work till the tape comes loose Stove...
It looks like the clock is on its way out. I would try two things. First, turn the power off at the main switch, leave it off for a few mins and then turn it back on and see if it makes a difference. You may need to do this a couple of times. Secondly, with the power switched off, repeatedly press all the clock buttons one at a time a number of times - there may be a contact that needs cleaning by operation and then see what happens. if you do need a new clock/timer then ask espares for a quote.
Nov 14, 2010 | Stoves 720EF Electric Double Oven
I purchased a microwave/convect oven combo last week. Installed today, everything works fine except that the lower oven won't heat. I tried turning the breakers off waiting a few minutes and back on. ...
Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
Sep 04, 2010 | Bosch HBN 9722 GB Electric Double Oven
My oven shuts off after only been on a few minutes. I turn on my Tappan oven (example at 350 degrees) then it shuts off.
If your display temp shuts off and reverts to only clock like some one hit cancle, your computer or main clock is no good. Some are no longer avalable.
you need to change the clock (main board)
Nov 17, 2009 | Ovens
Put in new wall oven , turned on power and set
my kenmore double oven model 41165 has no power....its hardwired 40 amp....it stopped working when it was cooling down after the slf cleaning cycle..we had a storm and had a minute power outage. Finakky got the door open but it wont turn on at all. Tried the breakers but i stll get no power....no even the bulb.......thanks....
Jun 07, 2009 | Ovens
KitchenAid Superba Double Oven clock won't light up
hold down the clock button for 3-5 secs. youve somehow toggled the clock dosplay off.
Nov 05, 2008 | Ovens
Dacor ECS230 Wall Oven Control Panel Time functions not working
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
Nov 09, 2007 | Dacor Millennia MOV130 Electric Single...
Oven won't turn on
If you haven't already, try turning off the circuit breaker for a few minutes. Turn it back on and see if the clock display is lit. If it does not, you may need to replace the clock assembly. It is sometimes costly for this repair.
Oct 04, 2007 | GE JKS05 Electric Single Oven
Ovens Logo
49 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
