Question about Samsung SCX 4521F All-In-One Laser Printer
I have black lines on copies I make and when I send faxes
  • 360 Answers
Hello press menu 10 times display MAINTAINS and their is a submenu CLEAN DRUM select and press enter button.then try to get copy .
didnt solve it u have to repalce toner
Posted on Aug 31, 2010
When I fax it copies a black line is on the page. And when I copy from the top part it copies a black line. How can I fix that?
are you getting black lined copies while you are trying to send a fax or black lined images are obtained at the receiving end. Is there any problems while copying from platen glass. if it's ok, then check if there is any thing on the stream reading glass (the small sized glass plate meant for ADF) & clean it.
Apr 14, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
I keep getting a black line about 2 inches along the right side of the paper if copying as well any faxes sent are also getting that blac line. Brother fax machine intel 4750e
Well you said the Lines are present when you are copying and when you are sending from the fax unit. Copying and sending functions both uses the scanning unit. What you lift open the document feeder for original documents. In there you should see rollers and a glass. clean this glass with cotton swab and alcohol for left to right the entire glass. Close the unit and try copying or sending, documents should now be clean.
Apr 04, 2011 | Office Equipment & Supplies
I have a Brother Fax 2850. When I send a fax the receiver has advised me that there is a vertical black line approx 2'' thick which blocks out some wording. How do I fix this?? Many Thanks Heather
Something is jammed in or covering the optics.
Check the area where the original document is placed for faxing.
Open this area and clean any liquid paper, sticky tape or staples covering the optics.
Test by making a copy. When the black line on a copy goes away the unit is fixed.
If the receiver is still getting this black line then it is probably their machine and not yours.
Send a fax to this number. 1300 368 999 It will send you back a copy of what it receives.
Nov 17, 2009 | Computers & Internet
On sending a fax the receiver copy has a black
You must clean the glass strip that the origional passes over to be scanned. You may have White-Out or an Ink smuge on it. Another way to determine if it is your FAX is to put in an original and make a copy. If the line is on your copy than it is your scanner **** (glass).
Oct 30, 2009 | HP Officejet 6500 Wireless All-in-One...
When sending a fax, black lines runs thru entire fax, what to do?
Clean off the glass where the paper runs through.You have some dirt or other substance that is blocking the light for copying or faxing.
Apr 20, 2009 | Canon PIXMA MX310 All-In-One Printer
When sending a fax on our Brother Fax-4100 the person on receiving end of the fax says it comes across totally black What is the problem??
If you make a copie. on your fax.
That is the same quality that you are sending over the phone line.
If the copie is total black
lift the document feeder see if there is anything on your optical glass.
But my experience tells me that the lamp has gone out also know en as the scanner asm.
let us know what hapens
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Black lines printing out on sent fax
If you make a copie and the lines are on the copie then the optics's are dirty, white out, ink or fourn oblrct on glass.
If you have clean the optics and the lines are still there then the C,C,D, needs to be replaces the part that reeds the documents.
more then what the fax is worth sorry.
Feb 16, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Faxes I send are reduced in size and have series of black line down right hand side.
If its reduced in size during transmit or copy then simply place a letter size document in the feeder and close the two sliders up to the sides of the paper. If you don't close the slider up to the paper it will go into auto reduction
Apr 27, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
Samsung SCX 4521F All-In-One Laser Printer Logo
201 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
