Question about Gateway FPD2275W LCD Monitor
I would like to replace the backlight bulb on my gateway fpd2275w tft lcd monitor. how do i remove the back (?) case
  • 11,361 Answers
Very very carefully! or you will break the ribbon cable and it is very hard to put the cable back in the socket. See my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
It will more likely to have bad caps, but if you want to change the CCFL assemblies, you will ahev to take the LCD panel apart which very hard to do also unless you have done one before.
Check www.lcdparts.net for lamps.
Posted on Aug 30, 2010
  • 1 more comment
  • Bud Martin
    Bud Martin Aug 30, 2010
    Capacitors kit: http://lcdalternatives.auctivacommerce.c... he can make you a set of caps
  • mikes0665 Aug 30, 2010
    thanks i didnt see any bad caps. so it might be the backlight unless they are one in the same. if it is a backlight i didnt see that but will have to look again
  • Bud Martin
    If you can post the pictures, that will help.
Can't find a information on where to get a replacement backlight for my FPD2275W Gateway Monitor. Is there a replacement part available.
It can be the backlight or inverter - eBay is the place to go. This is not always a simple job.
Professional service at http://www.lcdrepair.us/
Mar 19, 2011 | Gateway FPD2275W LCD Monitor
Gateway monitor FPD2275W TFT LCD powers on, gateway logo goes on fine with brightness then monitor brightness drops so you can barely see it. Not sure if this is a problem with the brightness setting or...
The back lamps that provide the illumination of the
colors, is shutting down there are feedback circuits when there is a problem
with the lamps it will shut down the lamps. Replacing the lamps should alleviate
this problem. For more information on this email me at Sprint6@zoominternet.net
Dec 22, 2010 | Gateway FPD2275W LCD Monitor
The Gateway FPD2275W TFT LCD Monitor the screen is black when my computer is up & running. I can briefly bring up the screen, and it shows my desk top, then changes to black. I have been trying to...
Hi!
The problem is not the setting on your monitor...The problem is the backlight inverter located inside the upper and lower edge of your screen..
It is busted. The backlight inverter is the light source responsible for the displaying image on your screen. If these were busted.. then the only thing you will see is black screen.
It is very risky for you to replace it by yourself if you don't have the knowledge and the right tools to open the back of your lcd..My suggestion is to bring your monitor to a credible technician to have your backlight inverter replace. if there is warranty for your lcd, please avail this.
Hope it help..
Much appreciated if you rate this solution..thanks..
May 26, 2010 | Gateway FPD2275W LCD Monitor
Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Oct 09, 2009 | Gateway FPD2275W LCD Monitor
My monitor fpd2275w gateway turns on but the screen is black
mine does it too...it seems to be that the back light is not staying on...seems to come on full brightness for about 3 seconds then goes out, there are images...but no backlight
Aug 27, 2009 | Gateway FPD2275W LCD Monitor
I was told that the backlight on my monitor was burned out. Can this be replaced without having to send it off somewhere? Where can the replacement light be purchased
First off it could be the backlight bulb or the LCD inverter. I would try the LCD inverter first it will cost about $25 and is easy to get to Take the face plate off around the monitor and the LCD inverter is at the bottom. It looks like a strip of circut board with plastic coating over it. Most of the time it is the LCD inverter.
But if its the Backlight bulb you might be able to take it to a local tv repair shop. you can order the backlight bulbs online but they are gragile and tricky to replace. you have to seperate the layers of glass on the screen abd the backlight will be at the top inbetween the layers of glass. If you do decide to do make sure to wear rubber gloves because the oiles from your fingers will get inbetween the glass layers and cause foggy spots when you put it back together.
Hope this helps
What kind of computer is it?
May 02, 2009 | Gateway FPD2275W LCD Monitor
GATEWAY LCD MONITOR FPD1530. UNIT SHUTS OFF IN ONE SECOND WHEN TURNED ON, EVEN WITH XP SOFTWARE TURNED ON.
Hi...there,
It's seems your backlight inverter are busted... need to replaced a new one or repaired it.
Aug 21, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD2275W LCD Monitor Logo
250 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
