Question about Ovens
The duel glass door has lint and other things inside. how do I clean the inside of the glass
  • siemion Sep 01, 2010
    yes. concise and complete
    thank the expert
  • 944 Answers
You can remove the oven door and dis-assemble it to clean it.
There will two to three screws you have to remove the screws and the hinge spring.Once have the door is removed you can begin the task of taking the door apart. Lay the door inside part down on a table or counter, remove the screws from the
bottom of the door trim (piece that holds lower part of glass) and remove the trim. Now you should be able to slide the outer glass downwards (some models required side trims to be removed also). Now you can remove the handle assembly and then begin to remove the inner door liner and inner glass package.The below picture gives you idea how to disassemble the oven glass.Specify your model no for more help.
post a comment for further assistance.
thank you for using fixya have a nice day:-)
Posted on Aug 30, 2010
    Guru:
  • 642 Answers
The screws to open the panels on the door are on the inside of the door. You can go about this 2 ways. 1./With the door in place or 2./ with the door removed.
To remove the door open to the grill position and pull on the door towards you. It willr elease from its hinges. Place on a firm surface and proceed to unscrew the crews on the inside of the door. Once unsrewed you can lift the inner panel from the door. This will allow access to the inside of the of the glass.
Things to bear in mind:
  • Although the glass is hardened and scratch resistant do not use scourers of any description on it. If the first round of oven cleaner and cloth does not do the trick, repeat until properly clean. Nothing spoils the apperance of an oven as much as a scratched glass panel(well perhaps a dirty one may.)
  • Take note of the seals on disassembly in order not to break them and also their position. On reassembly make sure the rubber seals sit properly or it will be that much easier for dirt ingress and shorten the period to the next clean.
Posted on Sep 02, 2010
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
How to clean the inside glass of themador PODMW301
you have to remove the door and disassemble the whole thing.
I do them all the time.
Feb 16, 2014 | Thermador Professional Series PO301...
How do I clean beko oven door inside panel?
Oven door glass is a "sealed" unit that accumulates stains over a period of use. It is not intended to be removed, unsealed, cleaned, resealed, and reinstalled.
Dec 28, 2013 | Ovens
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
How do I get the inside glass panel back onto the door?
You will find sets of screws ether on the outside edge of the door OR on the inside panel. You can NOT! use any glue to "seal" the Glass this will make everything smell like the sealant you picked to use. your door was probably used as a resting spot for something heavy and caused the doors skin to be bent OR when you Cleaned the oven with the clean feature it caused the door to warp. Your option is to get a replacement part to fix the problem you can stop by any appliance parts shop and ask them what the best thing to do is and/or buy the part there you can "pull the door" off the hinges by lifting the door straight up at you and take the part to the stop for help and or replacement
Feb 10, 2010 | Zanussi ZBF360 Electric Single Oven
The inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Jun 27, 2009 | Ovens
Cleaning between double glass oven door
Without disassembling the door, you can't. the glass is sandwiched between two rather rugged metalized gaskets to create an air pocket (or vent space) to keep the outside glass cooler than the inside.
Feb 04, 2009 | Ovens
Dirt and grease between glass in oven door
i have taken the glass from the inside of the oven,and just cant get grease off, tried everything ,bleach,even lemon juice,
any ideas jimmy
Aug 01, 2008 | Ovens
Glass window cleaning!
You have to remove the inside skin of door, pull door up and off of hinges and lay on floor to make this easier. Then you remove clips or brackets that hold the glass to door and clean. Very simple, but time consuming, mainly lining skin back up on reassembley.
Jan 27, 2008 | Ovens
Ovens Logo
73 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
