Question about RTO Lifestyler Expanse 8.0 Treadmill Walking Belt
I have a lifestyler expanse 500 treadmill, the rubber on the front roller has moved to the left, I have trim the extra rubber because it was rubber the left side of the treadmill but it keeps sliding what is the problem and can i just continue to cut the rubber off of the roller until it is all gone or will the roller and the walking belt slip?
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: the walking belt on this Lifestyler Expanse 8.0
I'm sorry to say that the belt is toast and needs to be replaced. I would also check the end caps I believed it is a one piece unit that the belt tension bolt is attached and the left side had cracked and cause this problem. Call Icon Fitness @ 1-800-999-3756 with locating the proper parts and pricing
Posted on May 28, 2010
Replace belt on llifestyle 850
see the video attached and proceed accoring.God bless you
Nov 23, 2012 | Treadmill Doctor Lifestyler Expanse 850...
My lifestyler expanse 850 control panel has stopped working but the belt still works?
1( adjust the REED switch, see the diagram, clean it, and tight the wires connectors very well.
2) replace the batteries.
3) clean the contacts batteries with special cleaner
4) retight the spring contacts batteries for better contacts.
5) tight the ribbon cables from keypadys vs display board.
6) tight the display board connectors vs lower board.
Jul 10, 2012 | Treadmill Doctor Lifestyler Expanse 850...
How do I change the level of the Lifestyler Expanse 500
Dear Sir:
Please read the instruction manual carefylly.If you do not have please go for free download: www. fitness.manualsonline.com or www. iconservice.com
sincerely. God bless you
Apr 30, 2012 | Treadmill Doctor Lifestyler Expanse 500...
Lifestyler owners manual
PLEASE GO TO THIS WEBSITES:
www.fitnessrepairparts.com
http://manualsfactory.com
http://fitness.manualsonline.com
http://pdfservicemanual.com
www.iconservice.com
Most of them are download free other you must pay some fee, give you model, etc. and ready,
Good luck, sincerely. G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Dec 03, 2011 | Exercise & Fitness
Running mat keeps moving to the left
It looks like you will physically have to inspect the treadmill form under the motor shroud, front roller, frame and to the end where the belt tension bolts are. To see if their anything bent or misalign, this will take some time with good lighting and a extra pair of eyes. You will even have to start the treadmill and watch the entire sequence closely until you see whats happening with traveling running belt. This what I would do Good Luck!!
Jul 18, 2010 | Treadmill Doctor Image 800Q Treadmill Rear...
The walking belt on this Lifestyler Expanse 8.0 Treadmill has slipped towards the left side; folding the left side of the belt over itself.
May 28, 2010 | RTO Lifestyler Expanse 8.0 Treadmill...
Treadmill front roller has a rubber sleever that keep moving
That front roller's rubber sleeve by all rights should not be moving any which way. This mean the roller will have to be replaced call iconfitness @1-888-999-3756 and order a new up-graded front roller .
May 07, 2010 | RTO Image 15.0R Treadmill Walking Belt
Proform Crosswalk Dual Motion Cross Trainer Treadmill. motor works great. Rubber on right side under the moving belt has come off so belt slips when in use
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Oct 24, 2009 | Proform Crosswalk 500 Treadmill
Treadmill adjustment on bowflex 5000tc
There are two hexagonal screws on either side of the front rollers, and four inset hexagonal screws on the back rollers. Turn it on the lowest speed while turning the ones in front, one at a time. You'll see the tread move from one side to the other. Tightening the screws bring the rollers out, pulling the rubber tread taught, and to the left or right, depending on which screw you're turning at the time. The treads should roughly be the same tension, adjusting both inside and outside front screws for each tread. If you have the dual rear rollers, you'd then have to stop the machine after finishing the fronts and tighten the four inset hexagonal screws on each of the rear rollers. No adjustment per se, just tighten them. If you don't, you'll have a sort of clunking, or clicking noise from the imbalance. The single rear roller is a little different, and the adjustment I believe, can be found on this site:
http://nautilus-technics.com/
Good luck.
Dec 28, 2008 | Bowflex Treadclimber
RTO Lifestyler Expanse 8.0 Treadmill Walking Belt Logo
147 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
