Question about Maytag Neptune MDE5500AY Electric Dryer
All electronic working but dryer will not turn on to dry
All electronic panel above will come on, but the dryer will not come on to dry any clothing. Help. I think the motor runs real lightly. But the point is it will not even come on to dry when the door is shut.
  • Anonymous Sep 03, 2008
    the dryer will not turn on at all the light is on
  • 45 Answers
If you think you here the motor come on real lightly you have probly broken a belt the motor is turning but not turn the drum because the belt is broken
Posted on May 22, 2008
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 | Dryers
Dryer drum not turning
First...just as a reminder that electricity can kill! Unplug the dryer and slide it out so you can get to the back of the dryer. Remove the back panel. Plug the dryer back in and observe the dryer in operation. If the belt is broken you have your obvious answer. If nothing happens then UNPLUG the dryer again and reach in and remove the belt from the motor. Plug the dryer back in and attempt to run it again. Does the motor spin? If not, dead motor. It is not the thermal fuse because you say it heats up. Take a look at this video for additional help.
Nov 29, 2017 | Samsung SM-DV210AGW - SERVICE MANUAL
Turned on Dryer today; problem; Estimated time remaining window shows CL (no time) Non of the time buttons selected show time in window. Dryer runs forever; gets hot and drys clothes. Pause button does...
The Child Lock feature is activated and it can be deactivated by pressing and holding the DRY LEVEL button for 3 seconds or until the CL display is cleared.
Indicate the exact model number of the dryer if the control panel doesn't look like the one shown above or if no button with the small "PRESS & HOLD 3 SEC TO SET CHILD LOCK" (DRY LEVEL) marking is found.
Mar 06, 2011 | LG DLE2514 Electric Dryer
Dryer is not drying i have to go through four or five cycles. you can see the red light going on and off in the back
By 'red light', do you mean the glow of the heater element or gas burner? Is this a dryer with an electronic control panel, or knobs?
This is probably the 'cycling' or 'high limit' thermostat going bad (or a sensor if it's an electronically controlled dryer). When this thermostat goes bad, it turns the heating element off too soon (because of internal physical wear) and the dryer runs at far too low of a temperature to efficiently dry clothes.
The thermostat is fairly cheap and easy to fix.
Go to repairclinic.com to look up your part. They also have how-to videos for some dryers.
Mar 01, 2011 | Dryers
Does not dry clothes, keeps turning off prior to
then it maybe the heat element.Is it getting hot and it may be the controll panel,there still could be sme lint stock some were,try using vacum hose and put in back of dryer it may free it up.
Jul 08, 2010 | LG DLE5977 Stainless Steel Electric Dryer
Frigidaire Dryer not drying clothes properly
TRY DISCONECTING THE VENTING FROM THE BACK OF THE DRYER THEN RUNNING IT .POSSABLE THE OUTSIDE FLAPPER STUCK?IM THINKING NOT THE DRYER. GOOD LUCK!
Jan 16, 2010 | Frigidaire AEQ6000ES Electric Dryer
DRYER WON'T TURN ON JUST A ELECTRONIC SOUNDING BEEP WHEN I PRESS START.
Check all fuses and circuit breakers , if they are fine, then the problem is with the control timer. You need to have the control timer replaced.
See also the following website: What is wrong with your Dryer?
You can get replacements here.
Sep 10, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Clothes not drying - fan ok, heat ok
I just had a Miele tech fix this. There are several causes for this. One cause is a motor fault with the fan motor or a bad belt. Second issue is a blocked up condenser. Finally the issue is electronic and the electronic panel needs to be replaced. The electronic panel consists of small relays that can burn out.
My issue was the electronic panel.
To test a blocked up condenser, is to take the top panel off, and spin the fan motor (by hand). If you feel resistance, you have a clogged condenser which must be replaced (Always run 'Remove Fluff' cycle so this never happens after every dryer use).
To test the fan, take the connector off and 'carefully' connect to 220v to the fan motor (checking polarity). Only do this, after you reset the switch (found in the rectangle box in the middle of the Miele metalwork on top) and made sure the fan does not work automatically when a drying cycle is selected.
The most expensive repair is the eectronic module which costs £175 plus £99 Miele callout.
Apr 22, 2008 | Miele WT945 Front Load Washer / Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
71 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
