Question about GTCO Quik-Ruler Digitizer, 36/48" (QR3648)
We can't activate the stylus. When our last estimatr was here everything worked fine. As soon as we went to use after he left we couldn't get to work. Any ideas?
  • 49 Answers
Plug in the Digitizer and make sure you hear four (4) beeps and 4 beeps only.
Any other tone would indicate a problem.
If you get four beeps,try to set the Superset code to S01 by using the stylus,select S,then 0 then 1 and you should hear four beeps again.
If this doesn't work the pen may have gone bad,have an open wire inside the cable.
It would have to be replaced. If you have another transducer,pen or cursor,try those.
Posted on Dec 23, 2010
All power gone from car
All automobiles have a kind of power transfer port. The battery and everything requiring a 12volt supply passes through the wiring harness. Most everything gets its ground from the frame. So If all power is lost suspect the harness. Otherwise there would be power failure at whatever refuses to work. So check at the wiring harness. Carefully probe the harness under the hood at the fire wall. all the power gets to its destination on the other side of the harness that is inside the car under the dash. If there is no voltage outside there is a great likelihood that none will be inside. Your problem is interesting, you will discover it soon, just by eliminating things in a logical fashion. Post again if none of this has helped you. Finally, try to recall the last thing you were doing before everything quit.
Apr 10, 2014 | 1996 Mitsubishi Mirage
Irulu recognizes finger but not stylus
Have you tried a stylus for capacitive screens?
Apr 09, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Dell windows 7 mouse returns to stylus's last point
Do you have installation software for the stylus? If so, I'd reinstall it and reboot. There should be a setting for you to disable the stylus. You might go to your control panel and try that. Then you can have more time to figure out what went wrong.
Mar 29, 2014 | Dell Computers & Internet
OK button on olympus stylus 710 not working
It's possible some debris has gotten under the pad that would activate that button. My first try would be a direct blast of air from a pressurized can of duster. Sometimes it may take several shots from different angles. if this doesn't solve the issue it may be hardware related and would require a technician.
Aug 06, 2012 | Olympus Stylus 710 Digital Camera
Post Test card reads 43 what does it mean?
when was it manufactured . it has possibly went past it's life expectancy
Mar 01, 2017 | StarTech.com PCI Post Diagnostics Test...
2010 Z1000 in Australia. bike was 100% fine less than a week ago, got it out last night and it wouldn't start. The dash lights up, but doesn't show neutral light when it's in neutral. Also the...
get the dealer to sort this out as taking it apart yourself could invalidate the warranty. its classed as third party interferance, and as you are not a kawasaki mechanic they could wash their hands of the warranty.
Sep 08, 2011 | 2010 kawasaki Z1000
In management ,I can show a 500GB disk but couldn't read or write , couldn't active . I couldn't take out my data .
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 08, 2011 | Western Digital 500GB ELEMENTS 500 GB USB...
I have a pair of Chamberlain Liftmaster Professional openers (Chamerlain Model 2500 belt drive) in my two-car garage. Both systems are identical, so it is easy to troubleshoot. I am able to completely...
It sure sounds like you have a light bulb that is generating a radio signal that interferes with the receiver in that one opener. Remove the bulbs and try. As strange as it sounds it can happen.
Nov 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wipers, heat, and turn signals only work when I jiggle the key
i would recommend replacing the ignition switch
Dec 01, 2008 | 1985 Jeep CJ7
Won`t play or record
take it back and get a new one. Make sure you scan for a virus i use the free AVG
Oct 14, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
Computers & Internet Logo
144 people viewed this question
Top GTCO Computers & Internet Experts
William F. Bryant Jr
Level 1 Expert
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
