Question about Refrigerators
Amana water fill and ice maker
I have a Amana side by side. I purchased it used. The ice maker has made only a fe3w cubes in the last 12 hrs and the water dispeser pours slowly. Does the icemaker take a wile to get going ? The water line to the frige is fine and I can hear the pump ingage when I use the water dispenser. Should I be getting more water or is it norm for the water to flow slowly?
  • coreyandjoy Oct 31, 2008
    My water dispenser dispenses very slowly-- hardly more than a trickle. Takes a while to fill a glass. So if it's the plumbing, what do I do about it?
    Genius:
  • 1,073 Answers
Check the flow from the water line of the house to the water valve of the frig not connected to the valve it should fill a large container fairly quickly
if it does the problem is with the water valve of the frig
if it does not fill the container fairlly quickly then the problem is the plumbing of the house to the frig valve
Posted on May 08, 2008
My amana reffigerator ice maching is making shells of ice cubes.
This indicates not enough water getting to the tray. check the ice maker shoot where the water comes out to see if it's obstructed with ice. You can defrost it if so, but you may need to replace the water fill solenoid in the back of the refrigerator where the supply line connects.
May 28, 2011 | Amana Refrigerators
Amana side by side ice maker tray is full and frozen but cubes aren't being ejected
Make sure the ice crusher/dispenser is working or gt a technician 2 look at it. Also ensure that u do not spil water when refiling the ice maker n do not go beyond the full markings 4 this may cause malfunctions when the water is frozen.
May 05, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Amana Refrigerator Model # ARB 2214 CC with leaking ice maker
Good day,
If the fill pipe that fills the ice maker is in it's proper position, then it is a defective water fill valve located in the bottom rear of the machine.
After harvesting the cubes the ice maker mechanism continues to rotate and turns the water valve on for 7 seconds. If it does not shut off smartly then it can cause the well to overfill, and flow water into the bucket.
Do not let this go. A small leak could turn into a major overflow, even overnight causing serious problems to the machine and as I have seen the entire house.
Dec 21, 2009 | Refrigerators
Ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Jul 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Ice Maker
well ur refrigretor is;nt producing enough gas to produce ice make sure u hire some expert who can examin and solve it.
Mar 18, 2009 | Amana ARSE66MB Side by Side Refrigerator
Water does not reach ice tray, ice maker appears to be cycling
Pull the filltube from out of the back check for ice inside, use warm water to melt.
Mar 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker not making ice
HAVE YOU CHECKED THE INLET WATER FILL TUBE ? IT COULD BE FROZEN UP AND THEN NO FILL ACTION. TAKE A HAIR DRIER AND TRY TO THAW IT OUT. GOOD LUCK,
Jan 02, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by side ice maker will not fill with water
Old message, I'm sure you have solved your problem by now, but . . .
IF
 Amana/Whirlpool conforms to wiring standards (no guarantees), the main AC wires should be white=neutral, black=hot, red=switched line.  Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
It would be kind to post back what you found as it might benefit others in the future.
Thanks-
Nov 30, 2008 | KitchenAid (KSRD22FKST) Side by Side...
My amana sise by side fridge wont drop the ice
hi thanks for the question probably have a problem with ice maker the timer in ice maker is not advancing to the drop off cycle need a new ice maker thanks the appliance doc
Jul 03, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by side
if the unit has been runfor some time prior to connecting the water the fill tube may be frozen up, he solution is to turn off defrost overnight with door open and then turn back on, flush water through when turned back on to clear old water and air.
Sep 02, 2007 | Amana ARS9266BS Side by Side Refrigerator
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
