Question about Keurig B70 Coffee Maker
Machine will not brew all of a sudden was working fine for months, what happened?
  • 3 Answers
You probably need to descale it. Run white vinegar thru it for three cycles, then leave the last cycle in overnight with machine on. In the morning run three cyclkes of plain water thru it and it should work again
Posted on Aug 30, 2010
Green light goes ON but nothing happens
I have the same problem after using it only twice...the store won't take it back as they no longer carry them, and there is no place local to repair them...and I can find nothing online to fix it. it was too expensive of a machine to have this kind of problem that is not easily repairable.
May 07, 2014 | Bodum Bistro b.over Coffee Brewer - Black
We have a 2 month old bunn coffee maker. worked fine now coffee is taking 10 minutes to brew
Sounds like calcium build up, You need to descale the machine.
If you look at the grounds on the basket, After the brew cycle is over there is like a hole in the center of the grounds. This happens when there is calcium build up in the tank, tube and or spray head. And takes forever for the brew cycle to end.
Follow the instruction on your manual to descale the brewer.
Jan 15, 2011 | Bunn Coffee Makers & Espresso Machines
My Tasssimo coffee maker is 11 months old and isnt functioning.
Possibly all you need is to clean off the bar code reader window. It's right under where the bar code on the t-disc ends up. A little dried milk, etc., can cause your symptom.
Dec 18, 2009 | Braun Tassimo Espresso Machine/Coffee...
My Saeco Classico won't brew
Have you run a backwash on the group with espresso machine soap?
If no then remove the shower screen in the group and clean (that might be covered with coffee oils).
Jul 17, 2009 | Saeco Classico Espresso Machine
No coffee, water going to the drip tray
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 20, 2008 | Saeco Royal Professional Espresso Machine
DGB-600 Will no longer grind coffee
I am having the same problem, can someone please help?
Oct 09, 2007 | Cuisinart DGB-600 Coffee Maker
SAECO VIENNA ESPRESSO/COFFEE MACHINE
Sounds like it could have pre brewing enabled which wets out the coffee and helps extract the full flavour. It may also need lubricating it is hard to know with a limited description. You can use a pen to bypass the sensor in the door to see what it is doing at the time. This may or should help establish the noise.
Jul 09, 2007 | Saeco Vienna Espresso Machine
Keurig B70 Coffee Maker Logo
137 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
