Question about Panasonic AG-DVC200 DV Digital Camcorder
DVC recorder Have a panasonic AJ SD255 DVCPRO and get an EE-00 error when I  play a sony Mini DV tape. Don't have problems with other tapes. Thanks Maria Pd. can't find this product in the menu below
  • 4,234 Answers
The physical tapes are the same size, but the encoding on the tapes are different. Unless the panasonic recorder can play DVcam, you're out of luck.
Dan
Posted on May 08, 2008
Sony dv premium ME DVM60 Mini DV tape. How many times(hr) to use
Recommend contacting your local service provider directly or online here:
Contact Us
Jul 29, 2017 | Canon Sony DVM-60 Min. miniDV tape - 6Pack...
I have a panasonic dvcpro aj-d230h deck and i keep getting an E-00 error...does anyone know how to fix this ?
Err-00 lights when servo disturbances continue for
3 or more seconds during playback, recording or
editing.
I have seen this problem before, and it was due to a bad servo board.
Nov 19, 2009 | Panasonic AJ-D230H DV/Mini DV VCR
My Panasonic AJD230 is spitting out some but not all, tapes
The capacitors are old and need replacing. And what I mean by caps is ALL the caps. These decks are known for failing capacitors - even if the deck hasn't logged much play/record time - time is not kind to them. Panasonic have ready made capacitor sets for the decks and even though you might be able to fix your transport problems by replacing only a portion of them, it's advised they all get done at once. That's between 10-20 hours for an experienced tech and it will cost you. What can you do?
Oct 26, 2009 | Panasonic AJ-D250 DVCPRO DV/Mini DV VCR
Tape deck no longer plays large DVCpro tapes
the tape compartment elevator has switch senors that tell the machine what size tape is in..
does the tape load all the way.. you need to tell us
is there an error code ?
either the sensor or the reel motors the feed and uptake the tape,,
they ride on rails and slide into position to accomodate the tape side they could be having trouble moving, dirty, broken actuator
Apr 07, 2009 | Panasonic AJ-D250 DVCPRO DV/Mini DV VCR
Tape format playback for AJ-D250
menu item 107 can be used to select dv playback
Dec 08, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
AJ-D250 PANASONIC E-62 PROBLEM
E-62 error on AJ-D250 points to a cassette housing problem. either replace the cassette housing or have it rebuilt (replace gears on the sides that raise and lower the cassette). "replace belts" won't work - the AJ-D250 doesn't have any belts.
Oct 14, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Panasonic aj-d230h
without knowing the exact error message, I can only speculate, but most rewind errors I have seen with the AJ-D230 are related to problems with capacitors on either the reel motor driver board or the system control board. the firewire upgrade (AJ-YAD230) is no longer available.
Sep 19, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Audio Problem with Firewire
The input select switch on the front of the AJ-D230H needs to be in the "OPTION" position, not "LINE". That may help if all the other settings are correct. You will also have to make sure that you have selected the right codecs for the deck that you are using in the software. I am speaking as a Final Cut Pro user so only offer this as a suggestion as these are the things that work from out of Final Cut.
Good luck. It can be very frustrating, but awesome when it all comes together and works right!!!
Helen
Oct 24, 2007 | Panasonic AJ-D230H DV/Mini DV VCR
Panasonic AG-DVC200 DV Digital Camcorder Logo
339 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
