Question about Craftsman 17765 Canister Wet/Dry Vacuum
I have a craftman shop vac model 500A , 5GAL.,1.25hp. why does Sears say that's not the model num. IT'S THE ONLY MODEL NUM. ON IT!!! IF IT'S AN OLD MODEL,WHY DONT THEY SAY IT IS THE SAME AS MODEL#***** AND WHY DOESEN'T THE FILTER,BAG'S ect.SAY, WILL ALSO FIT MODEL 500A
2 Suggested Answers
Richie_asg1
  • 1036 Answers
SOURCE: old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Posted on Sep 22, 2009
Shop-vac model 500A 52713-75
what is the problem ?
God bless you
if if suction, test the hose blockage 2) belt drive is worn 3) power brush dirty, clean or replace, 4) test the motor for repair, clean, and lube.
see the diagram
Sep 06, 2012 | Shop Vac Vacuums
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 | Vacuums
I have an older model Bissell rug shampoo machine, model # 1631. I have several bottles of Bissell 5 One carpet formula to use in this machine, however I have lost the measuring bottle that tells me the...
I have a older mod. Bissell carpet machine plus mod. 1630-5 and need a floor nozzle part num.013-6194 and grip tube w/button part num.014-4181 and trigger part num.010-9406 and tube
Mar 22, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Which new model replaces this model #11622612200
Ron, Kenmore assigns model numbers pretty much sequentially as they receive new inventory. There is no cross reference anywhere in the industry for their product except in their catalog. If you want to compare features you must do it that way to find a similar vac. If you are very luck you may find an experience Sales rep at Sears.
If this is a Kenmore canister , as they age the hose and wheels and wand connections break down. For a better designed or improved vac, look at a professional vac shop and look at all the spots which broke down on your old one. If there are feateures you like make note of them too and you should find similar features on a pro brand or at Sears.
One more thing, don't buy a new vac based on amperage. Amperage is consumption of power NOT output but its a big deal to advertise that way. it's only a numbers game. A 12 AMP vac motor with its suction fans removed is still a 12 amp motor, it just has no suction. Anyone who tries to sell you a vac based on amperage does not know there business. Best of luck. For a lighter easier running vac,better design look at Sebo , Miele, etc, as well. The Europeans are far ahead in design and filtration and durability
Oct 27, 2009 | Kenmore Vacuums
Old shop vac
Sears stock it -
CRAFTSMAN FILTER
Sep 22, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
The switch/lever that adjusts brush broke
yes this is a replaceable part, but you are going to have to order the button as well as the carpet/hardwood setting cam thats just below the button on the inside of the machine, under the hood. the best bet would be to go by your local vac shop or to see if you can order these item's online from hoover. i have checked for you and on there web site i cannot find the part num. for you. i'm sure that someone can help you at hoover or your local vac shop.
Aug 02, 2009 | Vacuums
Is there a manual for the hoover windtunnel Mach 3.8? thanks
if you go to hoover.com and look under download manuels. when it asks you for the model num. for your machine, put it in and push enter/search. if it's the pic. that i see and model num. U6437-900, you will need to put U6439-900 instead.( when putting in the model num. you don't have to put the dash in) i've checked for you and your model num. doesn't show, but the one that i have provided will be almost the same one has yours, but maybe a color difference and some tools extra. the manuel should work for you though. hope this helps
Aug 02, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Wind Tunnel U6436-900 power switch is always on. Vacuum will not turn off.
the switch is the problem. if the machine is under it's warrenty take it to your local vac shop if they can do the warrenty. if it's not then you can order the switch and i can walk you through replacing it. you will need to order a switch kit and i beleive the part num. is #40309033 but the num. might have changed
Jul 30, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Cannot find a filter
In a pinch a discarded flannel pajama sleeve can be employed as a filter on your shop-vac. grab up an end and twist it together and fasten with a piece of wire. the open part slips over the cage of the vacuum and fastens with a large flat rubber band. I'll try to find a source for a filter for you and will get back to you.
Oct 01, 2007 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Craftsman 17765 Canister Wet/Dry Vacuum Logo
766 people viewed this question
Top Craftsman Vacuums Experts
Andrew Taylor
Andrew Taylor
Vernon Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
