Question about GE Heating & Cooling
I woke up today and my air conditioner wasn't working! I tried unplugging it and hitting the reset button and nothing works. The power light on the plug still lights up green whenever it's plugged in, but it will not power on. What should I do? Model Number: AEW08FMG1
  • GE Master
  • 8,220 Answers
There MIGHT be a small fuse in the control. You would be fortunate if that was the case. Most of these controls just die. If you don't feel like putting a lot of money into fixing the machine I wrote a short article on bypassing that control.
Posted on Aug 30, 2010
While running in a screw to install a new electrical outlet cover, the outlet made a small pop and the lights flickered but immediately came back on. I plugged in the unit to see if it worked and nothing...
You say the unit is 220 volt, but the plug you installed has a white wire which is normally on a 120 volt outlet. A 220 volt outlet would have 2 black wires and ground. If you do have 220 there, and the reset does no good, I've seen those resets(they are basically built in GFI) blow out and had to bypass/put different chord on. there are fuses on the control board but I would check that last
Jun 24, 2011 | Frigidaire FAS257S2A WallWindow Air...
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
Fan works, cooling doesn't
check your condensor for dirt and any resets
Apr 08, 2010 | Amcor PLM-14000E Portable Air Conditioner
The went out in my condo and I have 3 samsung air
Unplug all the units, and wait for about a minute and plug it back. This is to reset all the units back to the
original condition. Hope this works.
Jan 05, 2010 | Heating & Cooling
Haier 8000 btu thru the wall ac wont come on
try ot unplug for 2 minutes,,, and try again may have fuses inside also
Jul 03, 2009 | Haier hwr10xc6 Air Conditioner
No power from the plug at all
GLAD TO HERE THAT YOU SOLVED YOUR PROBLEM..
Jul 08, 2008 | GE AGM24DJ Electronic Room Air Conditioner
Fujitsu Inverter ASTA09LCC - heating not working
Use a pen to hit the reset button on the remote.
Feb 09, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
167 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
