Question about Kenmore 22422 Top Load Washer
Spin cycle on washing maching
We have a Kenmore washing machine and it does not spin out the clothes. I can hear the motor and the
water is plumped out but the spinning does not happen.
Can anyone give any suggestion as to what the problem might be.
  • 5,911 Answers
It sounds like you could have a defective motor coupling. This is a common problem for this model washer and is easily repaired. The parts are not expensive and not too difficult for the average do-it-yourselfer. If you wish to repair yourself, click on the link below for step-by-step instructions.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Parts are available at searspartsdirect.com. Just type in your complete model number (located around the wash tub opening) in the "Search by Model Number" block and look for item 13 under the heading for the motor, clutch and pump assemblies. This part should only be about $15. I hope this helps you. Let me know if you have further questions.
Posted on May 08, 2008
Our washing machine is being placed in storage, but we can still hear water in the bottom of the machine (not in the tub). Is this normal? It seems like we should get all the water out before storin
If its a front loader there is liquid inside the drum put there by the manufacturer for balance and stability when the machine is running, that's probably the water sound you hear when you move it around.
Feb 16, 2015 | Kenmore Washing Machines
Clothes too wet after spin cycle
could be the clutch slipping not releasing the brake allowing it to get upto full speed
Feb 28, 2010 | Kenmore Washing Machines
Kenmore warsher, Model num 110.14202300, not drain or spin
The clothes too wet after spin cycle tells me that the water ump is functioning. If it wasn't, there would still be lots of water in the machine when the cycle ended. These Kenmores have the water pump mounted on one side of the electric drive motor and the transmission, drive shaft, and agitator on the other side. The transmission is fastened to the motor by a "coupler", a three piece assy that often breaks. This common failure allows the machine to complete a cycle, however, because of the broken coupler, there is no drive to the tub and no spin or agitate. The clothes seem wet because the spin motion is supposed to provide the force to extract the excess moisture. Leave the lid open and verify that there is no agitate or spin.(During spin cycle use a pen to press down on the safety interlock, a small opening on the the of the machine, toollow the unit to spin with the lid open). If you verify this, flip the machine over and locate the coulper on one side of the motor. One side will be cracked along the shaft. Sears parts stores carry the coupler in stock. ($18.50) Hope this helps.
Jan 18, 2010 | Kenmore 22422 Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Kenmore 44092/spin cycle
It turns out that there was a sock stuck within the pump in the washing machine. I removed the back cover and removed all the excess water, because once the sock was removed, the water was free to escape. I just removed the hose that connects to the pump and felt the sock, and was able to remove it. Once I hooked everything back up, the washing machine ran great.
Apr 17, 2008 | Kenmore Energy Star 44092 Front Load...
Washer spins but not enough to extract water from clothes or tub.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 31, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
