Question about Sony Televison & Video
I have a Sony Bravia KDL32S2530 linked to a Pace Sky+ box(TDS47ONB) all of a sudden the sky + remote controller has stopped controlling the sound level on the TV, everything else works ok with the controller. I have an old sky standard remote so I tried that and it operated the sound level on the TV. So thinking the Sky+ controller was faulty I purchased a new one, and to my dismay I found the same problem. The sound level is controlable with the switch on top of the TV and also the Sony remote, and the old Sky standard remote. The Sky+ remote does everything it should except the sound level. Any ideas please ? in anticipation Nick Pearson
    Top Expert:
  • Sony Master
  • 75,032 Answers
Check the speaker/s of the TV. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Apr 07, 2017
  • 326 Answers
SOURCE: Bush id tv
Dear Sir, unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution. This job definitely requires a professional technician Best regards, Arpi
Posted on Jun 17, 2007
SOURCE: Remote code required for UK Bush tv model WS6680SIL/C7
Found the correct code for my TV & Sky remote... I searched a fair bit more on google for... "WS6680SIL/C7 code" and found... which the correct code for my Bush TV - 0742. Others you may want to try are Bush 0157 246, 263, 377, 037, 064, 065, 310,300,383, 399, 391, 402, 339. or Beko 0125 514, 398. Further, Alba Group are the firm whom own Bush brand amongst others. Google Alba Group to get their site and links to Bush sites.
Posted on May 20, 2008
SOURCE: Sky remote control code for Bush TV
your code is 1239.
Posted on Sep 02, 2008
SOURCE: archos dvr station remote control
It sounds simple, but the archos must be facing the sky+ box. I spent hours messing around with archos support and qvc and in the end it was simple. I put the archos 6" away from the sky+ box, facing it, selected thomson, in the loist of sat receivers and it was code 15 of 16, good luck.
Posted on Feb 11, 2009
  • 79 Answers
SOURCE: remote control code
Television Direct Codes for Sky remote:
Goldstar 065, 405, 318, 245, 275, 037, 060, 391, 137, 459
Here are the codes for GoldStar which became LG. They might be the same.
Good luck,
Posted on May 09, 2009
What is the remote control code for Sony Bravia TV KDL-37EX503
Please provide the make and model number of the remote you need the code for.
Mar 03, 2015 | Sony Televison & Video
I need a code for grundig 7 in 1 remote to operate sky plus (not hd) box. it is a Pace manufactured sky plus box.
0027,0048,0091,0063 are the codes to check with Sky Plus. If you wish to get more, check these sites.
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 24, 2013 | Grundig 7 In 1 Universal Remote Control -...
My sky remote control does not work with a secondhand skyplus box. what is wrong
see the diagram attached:
1) retight the spring contacts batteries with pliers for good contact
2) clean the contacts batteries with contact cleaner
3) resolder the wires contact batterires
4) open the r.control for clean the contacts for dirty, corrrosion, oxide, test with continuity, remember they send infrared signal to the microcontroller receiver.
5) if you can do it, go to the repair shop TV for fix it.
God bless you
Jul 16, 2012 | Televison & Video
Need a remote contol code for sony bravia kdl 37U4000 for skyplus HD remote control
Remote codes for Sony TV with Sky Plus remote are:
533 038 039 064 102 130 505
Jul 06, 2011 | Sony BRAVIA KDL-37U4000 37 in. LCD TV
I have lost volume on my sky remote tv is sony bravia kdl40v2500 any suggestions, I have tried 0533 and 1799 and no joy
Reset ur sky box,by unplug,replug it an hour later,let the box bootup,and upgrade it software should be back to normal.Not than ur remote CPU is shorted,some of the functions are dead.
Apr 17, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have got a new sky+box and remote. can i use a previous sky remote with my new sky+box and if so, how do i sync it? thanks.
you can only use a previous remote if it is a sky+ remote, original sky remotes will not work with the sky+ box. vice versa
Nov 13, 2009 | Pace Type 30-0060 1121-0369 D1 .060 D2...
Sky remote will not control the sky box
Try unpluging the unit from the mains for about 1min,then try.
Oct 16, 2009 | Pace Type 30-0060 1121-0369 D1 .060 D2...
Volume not working on sky remote
You will need a code in order for the tv functions of you sky remote e.g volume to work.
Click here to find out what remote control version you have.
If you have a remote control was produced after 2002 or there is no sticker
click here to use Sky's code look up tool.
Most SKY+HD Remotes are produced after 2002
Mar 21, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Remote code needed (sky+) to sync with Sony bravia kdl32v2000
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Sony Code: 0000
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sky remote codes
I'm having probs too with a new sony bravia 40 inch
Dec 23, 2007 | Televison & Video
Televison & Video Logo
89 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
